Premium Audio Upgrade for less than $250
Discussion in 'Audio & Video' started by bshammer0, Sep 14, 2017.
  1. May 1, 2018 at 8:36 AM
    #2401
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
  2. May 1, 2018 at 8:44 AM
    #2402
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    Those speakers are a woofer and a tweeter, and no mid-range unit. So if your goal is to avoid having too much tweeter up front, this isn't the answer.
  3. May 1, 2018 at 9:21 AM
    #2403
    toyotatacomaTRD
    I ordered the ones from the original post. They're on sale for $79 right now. Also got the rears for $55.
    zepolnat and bshammer0[OP] like this.
  4. May 2, 2018 at 5:11 PM
    #2404
    Old Tundra Guy
    Old Tundra Guy Well-Known Member
    SW Ohio
    Thanks for the heads up,just ordered.
  5. May 3, 2018 at 8:33 AM
    #2405
    zepolnat
    zepolnat Active Member
    Orange County, CA
    2017 Black Toyota Tacoma SR5 - Double Cab Long Bed
    Thanks for the heads up for sure. Just ordered the ones from the OP as well. Not a bad deal at all. Already installed the tweeters about two months back and they made a vast improvement, so I'm looking forward to getting these bad boys in!
    bshammer0[OP] likes this.
  6. May 4, 2018 at 1:02 AM
    #2406
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    If the powered sub or amp accepts high level inputs you can just tap the speaker wires and wont need a LOC or LC2i. I'd have to check my saved threads but I saw someone built a harness with a male and female end that they plugged into the head unit. This basically allowed them to tap into the wires on the harness so that they dont modify the stock wiring, as well as give them an easy remote wire to use for the amp.
    Looks like the post Im referring to is #2383 in this thread and here as well:
    https://www.tacomaworld.com/threads...de-to-the-250-3rd-gen-premium-upgrade.541375/
    You could add the LC2i later if you feel like the bass diminishes too much as you turn up your volume. Some stereos decrease low frequency voltage as the volume is turned up, the LC2i has a feature to reverse that. Im not sure if the stock tacoma stereo does this though.
  7. May 4, 2018 at 7:27 AM
    #2407
    Murdoch33
    Murdoch33 Well-Known Member
    2018 Black TRD Pro
    Thank you kindly for the info! I’m going to be scouring this thread and a couple others so I’m well informed before installing.
  8. May 4, 2018 at 11:42 AM
    #2408
    Docoma Pro
    Docoma Pro Well-Known Member
    Ken
    Rochester, NY
    2018 Tacoma TRD Pro Cavalry Blue
    OVtuned 1.05 93 Perf,Undercover Elite LX, Subaru/Kicker tweeters
    Finally got around to installing the Kicker tweeters this afternoon (been sitting in a box for 3 months!) and WOW! 20 minute job, big improvement! I'll live with just the tweets for now but I see the doors and sub upgrade in my future! Thanks to the OP and all who have commented and advised on this thread. Well worth it!
    ksj, Mod fan and bshammer0[OP] like this.
  9. May 5, 2018 at 10:34 AM
    #2409
    ksj
    ksj Well-Known Member
    Pacific NW
    2018 Cavalry Blue TRD Pro
    265/70-17 KO2
    I just put the fronts in this morning. Didn't even have to remove the door or use a bungie. When I pulled the bottom up the top stayed in place, so I just reached underneath, pulled the old one and put in the new. Wrapped the connector in foam and taped it so it wouldn't rattle. Took about 45 minutes I guess. Well worth it. Like many I mainly didn't listen to music while driving. To me it was tiring because my brain was listening for things I knew were there, but were so muddled you could barely hear them. I am very happy with how it sounds now.
    It's very well worth the $, time and effort, though if you have to choose, get the tweeters first.
    Edit - I just realized it was about 30 minutes for the install and 15-20 minutes listening and driving around after I was done. So it really didn't take long and was super simple to do.
  10. May 5, 2018 at 11:41 AM
    #2410
    Huntersway
    Huntersway Active Member
    2016 TRD Sport
    I finally got around to this.I missed the sale on the Kickers so went with Rockford Fosgate Prime 6×9 and 6.75's 2 ways for $40 a pair with the Subaru tweeters.Huge difference, I am really happy with the volume and clarity of sound now.
  11. May 5, 2018 at 11:42 AM
    #2411
    Mod fan
    Mod fan Well-Known Member
    Just placed our order. Will post up...
  12. May 6, 2018 at 11:39 AM
    #2412
    Rat_Bastard
    Rat_Bastard Well-Known Member
    Brian
    Tucson AZ
    2016 OR
    Do you have the link to where you go the harness? :thumbsup:
  13. May 6, 2018 at 2:43 PM
    #2413
    Old Tundra Guy
    SW Ohio
    Did the fronts today,tweeters the other day. Clarity I would say is excellent , bass is Good. Obviously a sub would help,I don't need it.May do the rears, but as of now i'm very happy.
  14. May 6, 2018 at 2:46 PM
    #2414
    Mod fan
    You remove the whole door panel ? Or just move out of the way
  15. May 6, 2018 at 4:10 PM
    #2415
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Yes capacitors are cheap for this size.. about $.25, a quarter or so.
    OK did the door speakers today.
    I have a few things that make this process REAL easy.
    1st thing it's much easier to take off the door lock/window switch panels off the door and unplug them first. Instead of trying to do it after you take the door panel off. WAY easier.
    2nd thing - the trim covers behind the rear view mirrors... take them off and then you take the white retaining clips out of the hole they are in and attach to the trim panels before you put them back on. leaving them in place is not the proper way to install them. Take them off and install them on the trim piece then they snap in place. There are the trim pcs behind rear mirrors on the front door and there are trim pcs with the same hardware on the rear door. The little white grommet things will just press thru and into the door and you are fucked without them if you try and push the trim pieces back into place without removing the grommets and re-installing them on the trim pcs before re-install.
  16. May 6, 2018 at 4:19 PM
    #2416
    bobrown14
    Bob
    Philadelphia
    Gen 3
    Yes remove the door panels - very easy took me 1.5 hrs to remove and install all speakers.
    Trick on the trim pcs I just posted and there's a vid on youtube that gives you the rest.
    Basically all you need is a electric screw driver with phillips and a few door trim tools. I only needed 1 small flat edged plastic too could have put electrical tape on a big flat head screw driver in a pinch.
    It's much easier to disconnect wires for the locks and windows by taking that panel off the door first and you can use both hands to with the wire clips.
    Then remove the door - 2 screws and pull the btm front corner on the rear door, and pull the back corner on the front doors. Just give it a good yank... unclip and lift up and off. Really takes about 10 minutes per door and the speakers (if you wanna call them that) are held in place with 4 phillips/10mm screws up front per speaker and 3 phillips/10mm screws on the rear speakers. Skip using a 10mm ratchet. An electric screw driver is MUCH faster. You could use a 10mm on a electric driver as well. Just not a ratchet.. I'd still be there working on it.
  17. May 7, 2018 at 9:14 PM
    #2417
    Lithium177
    Lithium177 Member
    Would my stock 2016 trd sport benefit from this or am I in the sr5 boat? I believe I have entune. I have navigation built in but no jbl
  18. May 7, 2018 at 9:15 PM
    #2418
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Do you have entune?
    Do you have the JBL upgraded speakers?
  19. May 7, 2018 at 9:25 PM
    #2419
    Lithium177
    Lithium177 Member
    Not sure about the entune but I know I don't have jbl
  20. May 7, 2018 at 9:28 PM
    #2420
    TXTaco13
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Are your radio knobs at the bottom of your radio?
