Premium Audio Upgrade for less than $250
Discussion in 'Audio & Video' started by bshammer0, Sep 14, 2017.
  1. May 26, 2018 at 9:00 AM
    #2561
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    Kicker hideaway powered sub.
    DubfromGA likes this.
  2. May 26, 2018 at 11:55 AM
    #2562
    Cerveza1980
    Cerveza1980 Well-Known Member
    2018 TRD Off Road 4x4 White
    None yet
    Damn, just finished installing the door speakers now. 1.5 hours total and then some tuning. Really great sound. At max volume my drivers side door sounds like its going to rattle apart though lol!
    bshammer0[OP] likes this.
  3. May 26, 2018 at 11:57 AM
    #2563
    Cerveza1980
    None yet
    Does the entune deck have pre-outs for the Kicker Sub? Or would I have to go with a aftermarket deck?
  4. May 26, 2018 at 1:23 PM
    #2564
    Exracer2
    Colchester Ontario
    https://www.tacomaworld.com/threads...de-to-the-250-3rd-gen-premium-upgrade.541375/
    All of install updates are in the first post.
    No pre-outs required. I strongly suggest using the Metra pigtail harnesses listed in the above thread. It makes life so much easier and with the exception of the power and ground totally plug and play (aside from soldering the harnesses together with the Hideaway harness). Ground I went under another ground point and power I went right to the battery. If you ever removed the hideaway there will be no hacked OEM wiring.
  5. May 27, 2018 at 1:55 PM
    #2565
    BOSS-DS2
    BOSS-DS2 Well-Known Member
    Sam
    Texas
    2016 Tacoma 3.5L A/T DCSB
    Motofab 3” Spacer lift Spidertrax 1.25” wheel spacers Yokohama G003 M/T 285/75/17 (34”) MBRP 3” Turndown PowerStop slotted & drilled rotors Tekonsha P3 brake controller
    Aha, I have the same Porter Cable drill!
  6. May 27, 2018 at 2:19 PM
    #2566
    Mod fan
    Mod fan Well-Known Member
    Just had Best Buy drop in a alpine power pack. Sounds great! They love the extra power for sure. I think I’ll do the kicker hideaway next... sending the taco tunes kit back ASAP
  7. May 27, 2018 at 3:47 PM
    #2567
    Tacosrus
    Tacosrus Carpe Diem
    Northern California
    2018 Blazing Blue Pearl SR5 DCSB
    Mines on the schedule for Tues. Good to hear you like it.
  8. May 27, 2018 at 3:56 PM
    #2568
    Tacosrus
    Tacosrus Carpe Diem
    Northern California
    It's as good as my buddy's DeWalt . And it was reasonable.
    BOSS-DS2[QUOTED] likes this.
  9. May 28, 2018 at 1:59 PM
    #2569
    Mod fan
    FWIW kicker hideaway can be very easy had refurbished if you search around online for 149.00 or less shipped
  10. May 28, 2018 at 6:20 PM
    #2570
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
  11. May 29, 2018 at 7:29 AM
    #2571
    edummann
    edummann Well-Known Member
    Eric
    Bend, Oregon
    I have already replaced the tweeters, and I just ordered the door speakers. I have read through all 130 pages of the thread and I am still undecided on the sound deadening. If I could skip the $40 and the hassle of doing it would I be ok? Or is it really worth doing?
  12. May 29, 2018 at 7:31 AM
    #2572
    Cardsallday13
    Cardsallday13 Well-Known Member
    2017 DCSB TRD Sport 4x4
    I bought the sound deadening but then opted to not install it . It sounds great highs to lows. For me it wasn't worth the time to install the sound deadening .
    edummann[QUOTED] likes this.
  13. May 29, 2018 at 7:46 AM
    #2573
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    You might get the benefit from the fast rings. I have no idea what it would have sounded like had I not done them, but I'm more than pleased with the bass level and I have zero rattling.
  14. May 29, 2018 at 8:27 AM
    #2574
    edummann
    Eric
    Bend, Oregon
    Are they essentially a foam ring that goes between the mount and the door?
  15. May 29, 2018 at 8:43 AM
    #2575
    msting22
    msting22 Well-Known Member
    Marcus
    Powder Springs, GA
    2016 Quicksand TRD Off Road
    WeatherTech - Floor Mats Black out badges General Grabber AT2 TRD Baja Rims
    I did not do the deadening and I have to problems.
  16. May 29, 2018 at 8:49 AM
    #2576
    toyotatacomaTRD
    Yes, the magnet and the door. Also around the mounting brackets so there is foam between the door panel and speaker so no rattling.
  17. May 29, 2018 at 8:59 AM
    #2577
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I was able to peel the foam ring off of the OEM speakers without damaging it and use it on the replacements, and I wrapped wires with foam as well to avoid rattles. Other than that, no additional deadening.
    edummann likes this.
  18. May 29, 2018 at 9:06 AM
    #2578
    Matt3400
    Matt3400 Well-Known Member
    2007 Lexus GX470
    My thought was I already had the doors apart, adding the Noico literally took about 10-15 minutes per door.
  19. May 29, 2018 at 9:12 AM
    #2579
    edummann
    Eric
    Bend, Oregon
    Did you tear the plastic off or go over it?
  20. May 29, 2018 at 9:15 AM
    #2580
    Matt3400
    2007 Lexus GX470
    Took it off, I also put some on the outer doorskin.
