Premium Audio Upgrade for less than $250
Discussion in 'Audio & Video' started by bshammer0, Sep 14, 2017.
  1. Aug 18, 2018 at 12:54 PM
    #2921
    Nettleberger
    Nettleberger Well-Known Member
    2017 Tacoma TRD Pro DCSB Super White
    I've been running that exact setup now for a week or two and it rocks, sounds perfect (albeit a lot of tweeters). I even called kicker to ask them about that concern and the tech said while he can't from the company's point of view say it is correct he said not representing the company there's basically next to zero issues given the Tweeters pull so very little power at such a higher frequency that there should be no problems.
  2. Aug 19, 2018 at 12:25 PM
    #2922
    righty
    righty Well-Known Member
    2015 Access Cab i4 4WD
    BFG K02, Ultra Vagabond wheels, Truxedo Lo Pro Q Tonneau cover, Pop lock
    Sorry too many pages to find it all. I appreciate the op and all their effort here. 2nd Gen doesn’t seem fully addressed. Do the Subaru tweeters work with a 2nd gen 2016 with Entune “plug and play”? If not what tweeters could I get?
  3. Aug 19, 2018 at 12:57 PM
    #2923
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Tweeters in this post will not work with 2nd gen I believe.
    You’d be looking at the kicker 43CSS694 component set. This will come with the woofer and the tweeter
  4. Aug 20, 2018 at 3:36 PM
    #2924
    krshome
    krshome The sale of the Porsche bought my Taco
    Kurt
    Virginia
    TRD Off Road DCLB
    stereo upgrade, LEER Cap
    One more Question and hopefully the last. Im making a T-harness to add the kicker key to the radio and the to parts I got don't match up. The Metra 71-1761 & Metra 70-1761.The picture shows the rear speakers part. One connector has an orange wire with a black strip, the other one has no wire to run back to the trucks harness. What is the orange and black stripped wire for and do I need it in a 2018? FYI I have not pulled the radio yet, so I have no idea if the harness even has a wire in that slot.
  5. Aug 20, 2018 at 9:02 PM
    #2925
    destin_meeks
    Destin
    Tuscaloosa, AL
    You won’t need that wire. De-pin it, cut it off, cap it, whatever you want
  6. Aug 23, 2018 at 9:16 AM
    #2926
    nevadawolf03
    nevadawolf03 Well-Known Member
    PNW
    2016 SR5 DCLB
    SR wheels, side marker black-out, Clazzio's, Tweeters, Tailgate inserts, interior vinyl inserts
    I have a sound deadening question. Can you put sound deadening foam over the Noico mat? Or is this just total overkill? I was thinking of doing this on the back wall since that is where a ton of road noise comes from.
  7. Aug 23, 2018 at 9:17 AM
    #2927
    CoastieRon
    CoastieRon Hammocking Fool
    Ron
    Nashua
    Lil' Silver
    Too much.
    Yes you can
    I'm replacing everything with Morel. Not in this budget range, but great components. Going to see if the kicker tweeters fit in my BIL's 2010 Tundra. Pretty sure the will work exactly the same.
    nevadawolf03[QUOTED] likes this.
  8. Aug 24, 2018 at 3:11 PM
    #2928
    cobracube
    cobracube Active Member
    Eric
    2017 Inferno Tacoma Sport
    Bed Cover, Predator Tubes, Bed Step
    I used this thread to build my own "Budget"Set up as it has some amazing info, advice and suggestions. Thank you to all the experts as well as enthusiasts on here who literally helped me make decisions just based on their own experiences and posts which helped me learn from their infinite wisdom.
    I Ended up with a 10 Inch Sub, box, amp, 6x9 Front Door Speakers, 6.5 Rear Door Speakers, all the Adapters and Wireharness Adapters, the line converter as well as Amp kit which included the necessary wires to power and hook up the sub for $315. It is basically a complete plug and play system with no major modifications such as removing the storage panels behind the back seats or taking the seats out of the car or anything like that. Speakers are all Pioneer (Doors are 3 way) and the only thing I have not even looked at yet is the tweeters. I hooked up the SUB already and that alone gave me enough bass to feel it in my chest but not enough to show up at the car show and try to be competitive...lmao! It was an overall noticeble difference already and I plan to install the Door speakers this weekend.
    ToyoDrew likes this.
  9. Aug 24, 2018 at 7:14 PM
    #2929
    SoCali_Guy
    SoCali_Guy Well-Known Member
    California
    TRD OFF ROAD
    Without going through this whole feed.. where are the most important spots to put the sound deadening on without wallpapering the whole door.. sorry if this has been answered before..
  10. Aug 24, 2018 at 8:47 PM
    #2930
    itsmike
    itsmike Well-Known Member
    SoCal
    The inside skin of the door is probably the one more important area.
    SoCali_Guy[QUOTED] likes this.
  11. Aug 24, 2018 at 8:55 PM
    #2931
    SoCali_Guy
    California
    TRD OFF ROAD
    itsmike likes this.
  12. Aug 25, 2018 at 4:42 AM
    #2932
    destin_meeks
    Destin
    Tuscaloosa, AL
    Road Kill 3 piece fast rings on the speakers and deadening material front and back around the speaker opening
  13. Aug 25, 2018 at 6:47 AM
    #2933
    ToyoDrew
    ToyoDrew Well-Known Member
    Texas
    17 Inferno TRD-OR DCSB 4x4 (SOLD)
    OVTune, Hertz spkrs & JBL MS-8 DSP, Turn-as-Tail mod, LEDs everywhere, MESOJDM Turn Signal, Bakflip Revolver X2, Pop-n-Lock, Yakima roof rack, & many minor mods
    Doing the inside skin of the door will also have the side effect of improving the speaker's response if you seal most of the gaping holes with the sound deadener. It usually improves the midbass frequencies of the woofers a bit.
    Also, a few people have said that sound deadening the rear wall (behind the rear passenger seats) has had surprisingly good results.
    Lastly, if you're in a place that gets a lot of rain, then I'd also suggest doing the roof. That roof has almost NO support and it magnifies each drop more so than any other panel does on the truck.
    bshammer0[OP] and SoCali_Guy like this.
  14. Aug 25, 2018 at 1:55 PM
    #2934
    SoCali_Guy
    California
    TRD OFF ROAD
  15. Aug 26, 2018 at 10:00 PM
    #2935
    SoCali_Guy
    California
    TRD OFF ROAD
    @Tacosrus do you have the link for the Alpine power pack and metra adapters.. and how hard was it to install? I did the kicker speakers I just want some power behind them now
  16. Aug 26, 2018 at 11:54 PM
    #2936
    Tacosrus
    Tacosrus Carpe Diem
    Northern California
    2018 Blazing Blue Pearl SR5 DCSB
    I bought the power pack open box from Best Buy. And the Metra Adapters also. The adapters are cheaper online but they had em in stock. Just get in touch with the installer at your Best Buy or Maybe Destin Meeks will chime in. He's an installer.
  17. Aug 27, 2018 at 12:15 AM
    #2937
    SoCali_Guy
    California
    TRD OFF ROAD
    @Tacosrus what Alpine power pack did you buy bro? model brand? cause I see they have a few open box ones in my area
  18. Aug 27, 2018 at 1:17 AM
    #2938
    destin_meeks
    Destin
    Tuscaloosa, AL
    The only two worth getting (in my opinion) is the alpine 445 or the kicker key. And I much prefer the kicker. Especially if you are keeping the stock head unit.
  19. Aug 27, 2018 at 6:25 AM
    #2939
    SoCali_Guy
    California
    TRD OFF ROAD
  20. Aug 27, 2018 at 7:25 AM
    #2940
    destin_meeks
    Destin
    Tuscaloosa, AL
