Premium Audio Upgrade for less than $250
Discussion in 'Audio & Video' started by bshammer0, Sep 14, 2017.
  1. Sep 19, 2017 at 1:32 PM
    #281
    bshammer0
    bshammer0 [OP] Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Nope things lined up well - I only used 4 screws (top/bottom/sides). Not much bass comes from the rears as the low-end comes from the 6x9s so I didn't feel the need to be too OCD back there.
    shakerhood[QUOTED] likes this.
  2. Sep 19, 2017 at 1:55 PM
    #282
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    5 months since full Kicker upgrade. Still sounds awesome.
  3. Sep 19, 2017 at 2:22 PM
    #283
    techman993
    techman993 Well-Known Member
    Allen
    Pittsburgh, PA
    2018 Cement Tacoma TRD OR
    Tinted Windows B-pillar vinyl delete Tyger Step-Tubes Tailgate decals (Thanks @rrentop!) Boss 2" lift 285/70/R17 Nitto Terragrapplers TRD PRO Rims
    Got the tweeters hooked up last night. Took about an hour. But I had never done this before. Can someone refresh my memory as to whether I should place the adapters on the door before I screw in the speakers or vice versa?
  4. Sep 19, 2017 at 2:25 PM
    #284
    mrproduxn
    steve
    Retired DoD SE VA
    Take the door speakers out. Set them on a bench. Assemble the new speakers and adapters so they look the same as the originals. Install. If new at this just do 1 speaker at a time.
  5. Sep 19, 2017 at 2:33 PM
    #285
    techman993
    Allen
    Pittsburgh, PA
    Thanks bud.
  6. Sep 19, 2017 at 2:35 PM
    #286
    mrproduxn
    steve
    Retired DoD SE VA
    Will save you from assembling upside down and having to take them back out. On my speaker adapters I had to open up the square hole a little so the wire adapters went in easier. Do this before you attach the speaker.
  7. Sep 19, 2017 at 2:38 PM
    #287
    techman993
    Allen
    Pittsburgh, PA
    Did you have the issue of the screws being too long?
  8. Sep 19, 2017 at 2:43 PM
    #288
    mrproduxn
    steve
    Retired DoD SE VA
    Not that I recall. I really cannot remember. I keep tons of hardware so I may have used different screws.
  9. Sep 19, 2017 at 2:47 PM
    #289
    techman993
    Allen
    Pittsburgh, PA
    I will hope I can find some in my random assortment.
  10. Sep 19, 2017 at 2:50 PM
    #290
    Deucer01
    Deucer01 Well-Known Member
    North Georgia
    2023 Tacoma ORDCSB 4x4, 2024 4runner TRD ORP
    Got the Kicker tweeters installed, took less than 20 minutes. Door Kickers arrive tomorrow but already a significant improvement over stock.
    bshammer0[OP], speedtre and mrproduxn like this.
  11. Sep 19, 2017 at 4:16 PM
    #291
    bshammer0
    Brandon
    Nashville, TN
    YES - the screws with the mounts were too long, the screws with the speakers fit the mounts just fine for me and were shorter. I totally forgot about that piece as I used the long ones initially and couldn't get the speaker to fit properly and opted for the shorter ones
  12. Sep 19, 2017 at 4:19 PM
    #292
    bshammer0
    Brandon
    Nashville, TN
    You want to mount the speaker to their mounts before bolting the mounts to the door, but either do what was suggested in laying them out so you can ensure you have the orientation properly or just do a quick check by lining up the mounts to the spot you'll place them in the door to make sure the holes are aligned. Either way just check before - not a huge deal, just a bit of prep ;)
    techman993[QUOTED] likes this.
  13. Sep 19, 2017 at 4:28 PM
    #293
    jsey21
    jsey21 Well-Known Member
    2016 Black Tacoma Sport DCSB V6 4x2
    OVTuned https://www.tacomaworld.com/threads/rear-diff-vent-behind-the-tail-light-mod.286097/ https://www.tacomaworld.com/threads/rust-on-frame-with-a-c-drain-mod-fix.444138/ https://www.tacomaworld.com/threads/ultimate-led-turn-signals.486423/ https://www.tacomaworld.com/threads/premium-audio-upgrade-for-less-than-250.510424/
    I had some of those that were messed up when I took the door off. I had to replace one in three out of four doors. Not saying everyone will have that issue, but I would recommend having some extra just in case. You can tell they just pounded the door on during assembly and didn't care of some of the door clips got screwed up.
    goose443[QUOTED] likes this.
  14. Sep 19, 2017 at 4:30 PM
    #294
    speedtre
    speedtre Well-Known Member
    DirtySouth
    '17 DCLB TRD OR AT 4x4
    Ok...speakers all delivered, shooting for a weekend install...still debating on the sound deadening material. I have till Thursday to order it and have it be here by the weekend so @bshammer0 let me know what you think of yours if you get it installed by then. :thumbsup:
    bshammer0[OP] likes this.
  15. Sep 19, 2017 at 4:31 PM
    #295
    speedtre
    DirtySouth
    Do you happen to have a part # for them?
  16. Sep 19, 2017 at 4:34 PM
    #296
    jsey21
  17. Sep 19, 2017 at 6:53 PM
    #297
    tacopromatt
    tacopromatt Matt's Pro Taco (SOLD)
    Austin, TX
    2017 Cement Tacoma TRD Pro AT
    Just finished installing all 6 speakers. Posted some pics on my IG. Someone commented with:
    "So you put a coax speaker in place of a component and still connected the tweeter in the dash? The tweets on the coax shouldn't be working because of the inline crossover before the mid(6x9)."
    Thoughts?
  18. Sep 19, 2017 at 6:58 PM
    #298
    SilverTacomaGuy
    SilverTacomaGuy Well-Known Member
    Cody
    Central Oregon
    2016 TRD OFF-ROAD
    Little tree air fresheners. Clazzio black leather seat covers.
    Speakers are all ordered and will be here Friday! Looks like my Saturday is booked up. Looking forward to getting rid of the crappy sounding stock speakers.
  19. Sep 19, 2017 at 7:01 PM
    #299
    mrproduxn
    steve
    Retired DoD SE VA
    My reply to that statement would be duh WTF are you talking about. The stocks are not what would be called component speakers. Mine sound freekin awesome by simply swapping to 3 way s front coaxial rear and dash tweeters. Crossover smoshover.
    bshammer0[OP] and tacopromatt like this.
  20. Sep 19, 2017 at 7:09 PM
    #300
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    I think he's correct...that the 3 way 6x9 are not utilizing the tweeters and at best are producing low and mids due to the head unit or other crossover only feeding those frequencies...which is why I was thinking a 2 way would be better but at the price point probably doesn't really make much of a difference.
