Premium Audio Upgrade for less than $250
Discussion in 'Audio & Video' started by bshammer0, Sep 14, 2017.
  1. Dec 29, 2018 at 1:17 PM
    #3181
    TacoPro18
    TacoPro18 Member
    2018 Tacoma TRD Pro
  2. Dec 29, 2018 at 1:19 PM
    #3182
    TacoPro18
    TacoPro18 Member
    2018 Tacoma TRD Pro
    Your install states you also installed the Subaru teeters. DId you have to splice into the wiring harness or use the supplied Crutchfield harness and your tweeters still worked? Crutchfield telling me that unless I splice it will disable the tweeters. I saw another thread that the subaru tweeters were just plug-n-play. Thanks in advance
  3. Dec 29, 2018 at 1:57 PM
    #3183
    Auroraboy
    Auroraboy Well-Known Member
    Dave
    London, Ont., Canada
    2017 Quicksand DCSB Off Road
    Husky Weatherbeaters, BAK Revolver X2, front bedrail, Salex console tray, Predator Steps
    The Subaru tweeters are a direct replacement for the Tacoma (Non JBL only) tweeters. You just unplug the OEM speakers, and plug in the Subaru tweeters. Nothing to buy from Crutchfield (They do not even sell the Subaru tweeters).
    If you have the JBL system, you would need to do other things to make them work.
  4. Dec 29, 2018 at 3:23 PM
    #3184
    TacoPro18
    TacoPro18 Member
    2018 Tacoma TRD Pro
    I plan on buying the Subaru tweets. I have a 18 PRO, but it is non JBL system (I know Shocker). If I install Kicker 6x9's in the fron with their wire set, will the tweeters in the dash still work? They are sayin have to splice into the wiring to make that happen. Want to know what your experience with the install was. Did you have to do anything special or just plug in and your dash tweets still work? Thanks
  5. Dec 29, 2018 at 6:09 PM
    #3185
    mauidogg
    mauidogg Well-Known Member
    16 DCSB TRDOR
    I got all my goodies in. Is there a particular reason to only use one set of red and black to the crossover? Guessing you don’t want to bridge the wires going in if it’s gonna messup the ohms the thing is gonna get? I got the infinity reference component set for the fronts.
  6. Dec 29, 2018 at 6:38 PM
    #3186
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    So this is where the annoying wiring choice by Toyota comes in
    One set of red/black is what is coming FROM the radio.
    The other set is what is going TO the door speaker.
    So the audio signal comes from the radio, through the tweeter, then to the door.
    Definitely check out their video on YouTube about how to wire everything up.
    https://youtube.com/watch?v=w0RuyxMYP_Y&t=449s
    mauidogg[QUOTED] likes this.
  7. Dec 29, 2018 at 8:42 PM
    #3187
    mauidogg
    16 DCSB TRDOR
    No wonder it didn’t make sense. Thanks a bunch.
    destin_meeks[QUOTED] likes this.
  8. Dec 31, 2018 at 12:47 PM
    #3188
    Tacoma_TTom
    Tacoma_TTom Tys_Taco
    Tyler
    2018 Cement Tacoma TRD OR
    So I finished the install on these yesterday afternoon, I'm very happy with the quality of the sound, but see myself wanting to get an amp to increase the volume.
    Also - this could very well be me hyper-focusing, but I'll occasionally think the passenger side of the truck isn't playing, or even that the driver side is just louder. Has anyone else felt that post-install?
    I've never installed speakers on my own before so I feel I might be paranoid I messed up.:annoyed:
    bshammer0[OP] likes this.
  9. Dec 31, 2018 at 12:49 PM
    #3189
    TEXAS BS
    TEXAS BS Formerly known as MMXVII
    JB
    Texas
    2017 ACLB TRD OR 4X4
    Use your fader controls to test each side of the truck.
  10. Dec 31, 2018 at 12:53 PM
    #3190
    Tacoma_TTom
    Tyler
    I honest to baby Jebis didn't even think of that...to be fair i'm running on next to no sleep. Will try.:bowdown:
  11. Dec 31, 2018 at 1:05 PM
    #3191
    TacoPro18
    TacoPro18 Member
    2018 Tacoma TRD Pro
    Check you balance and fade controls. You will know based on adjusting those, left, right, front, and back. Also, seating position could impede sound. Adjust these controls and you should know and adjust to best sound for your seated position. I am doing mine this weekend and will be doing the same, but have done some installs in past. No expert, but some experience
  12. Dec 31, 2018 at 1:59 PM
    #3192
    destin_meeks
    Destin
    Tuscaloosa, AL
    If your fade/balance is centered, it will 100% sound like the drivers side is louder.
    After all, you're closer to the drivers side.
    You'll see a lot of people in the audio world doing hardcore tuning and time alignment adjustments and all sorts of stuff to make their vehicle sound the way they want. My personal truck is time-aligned so that it sounds like I'm at a concert, center of the audience, with a wall of speakers in front of me.
    It's not super centralized (I've tuned cars where it sounded like there was one speaker in the car, right on top of the gauge cluster) but it is centered to my ears so it sounds like I'm in the middle. Play with your balance and fade till it sounds best to your ears.
  13. Dec 31, 2018 at 2:04 PM
    #3193
    Tacoma_TTom
    Tyler
    That's what I thought too! I guess I was just a little weirder out because the stock ones never did that. But that makes sense. I'll fidget with it today.
  14. Dec 31, 2018 at 7:19 PM
    #3194
    ssjfyr
    ssjfyr Member
    Canada
    2011 Toyota Tacoma Access Cab 4x4 TRD Off-Road
    Crisp and clean with no caffeine! Just did the tweeter install and it is great! I have the Kicker door speakers on order and will be installing them soon.
    shakerhood and bshammer0[OP] like this.
  15. Jan 2, 2019 at 12:07 PM
    #3195
    TacoPro18
    TacoPro18 Member
    2018 Tacoma TRD Pro
    tandemgeek likes this.
  16. Jan 5, 2019 at 4:42 PM
    #3196
    Cardsallday13
    Cardsallday13 Well-Known Member
    2017 DCSB TRD Sport 4x4
    For those who added an amp like the key, after you did the upgrades with the sub...
    Did adding the amp make the door speakers drown out the sub volume?
  17. Jan 9, 2019 at 7:20 AM
    #3197
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Usually those hideaway powered subs have their own volume control, and some can be tuned for gain so you can get the level up, but not sure what you went with. Personally, if I was going to add an amp and a powered sub I'd be looking at a slightly higher end set of door speakers as well, likely with a bit less sensitivity to give better control over volume/clarity. But I would think that there is some tuning you could do to balance things out.
  18. Jan 10, 2019 at 4:34 AM
    #3198
    jack_mTaco
    jack_mTaco Well-Known Member
    Jack
    2017 Tacoma Trd Pro
    Mr Marv working his magic
  19. Jan 10, 2019 at 11:05 AM
    #3199
    joostain
    joostain Member
    Justin
    2016 Tacoma TRD OR
    Stock
    tried searching but does anyone know if it the entune premium-non JBL for the 2016 TRD off-road tacomas are 6" or 7" lcd screens? I know I can go out and measure it but I won't be able to until later tonight since the truck isn't currently with me.
  20. Jan 10, 2019 at 11:08 AM
    #3200
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Where are the radio knobs?
