Premium Audio Upgrade for less than $250
Discussion in 'Audio & Video' started by bshammer0, Sep 14, 2017.
  1. Jul 26, 2019 at 6:52 AM
    #3521
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Just depends on the type of upgrade you want and your budget.
    If you want better than factory and cheap, then yes! Great option.
    If you want better than factory and are willing to spend a little more (maybe $500?) then I’d add an amp like the Kicker Key and upgrade to better speakers like the Kicker KS or other component speakers with a bit smoother sound
  2. Jul 26, 2019 at 7:04 AM
    #3522
    Brobrady
    Brobrady Well-Known Member
    Ok. Thanks. If I do the CS upgrade will I loose my current level of bass?
  3. Jul 26, 2019 at 7:06 AM
    #3523
    destin_meeks
    Destin
    Tuscaloosa, AL
    People have reported a bit of bass loss. This is because it is a much stiffer cone, a much thicker voice coil, bigger magnet, etc. Basically, It’s harder to move than the cheap paper factory speaker.
    This can be solved typically with a bit of a bump in the bass EQ setting.
  4. Jul 26, 2019 at 7:31 AM
    #3524
    mlr69
    mlr69 I had a savings account before I joined TW
    South Carolina
    2018 TRD Sport 4x4 DCSB
    2" ToyTec/Eibach Pro Sport Lift Kit -SparksParts.com 3/4" ToyTec Front Top Plate Spacer Kit -SparksParts.com SPC Performance Upper Control Arms -SparksParts.com Nitto Ridge Grapplers 285/75/17 (34") -SparksParts.com 1.25" Spidertrax Wheel Spacers -SparksParts.com Hypertech Speedometer Calibrator -hypertech.com Predator Tube Steps -SparksParts.com BAKFlip G2 Tonneau -SparksParts.com OEM Rubber Bed Mat -SparksParts.com OEM All-weather Floor Liners -SparksParts.com Gentex Frameless Mirror with Homelink @RJP869 Subaru/Kicker Tweeters -amazon.com Kicker Door Speakers (x4) -crutchfield.com Radio Knobs @Tacowiede Vehicle OCD Glove Box Organizer -amazon.com ‎JoyTutus Center Console Tray -amazon.com FormulaOne Pinnacle Window Tint -SparksParts.com ACDF Horn Kit @BartMaster1234 Total Tail Light S1 Kit @MESO ECT Button Relocation Kit @Tacowiede Minimalist Key Fobs @MESO Ultimate Map & Dome Lights @MESO Fortin EVO-ALL Remote Start w/Cell Module @jmeitz Coin Bucket with Lid @MESO GermesLab Camera Control System @FreshMexicanTaco Natika Front View Camera -amazon.com VLEDS LP Reverse Light System -vleds.com LIFTd Customs Fuel Cap Cradle @JIMMEISTER OEM Power Tailgate Lock -SparksParts.com OEM 2022 Limited Grille -SparksParts.com OEM 2022 Limited LED Headlamps -SparksParts.com LED Headlight Conversion Harness @daveeasa Headlight Trim Plates @MESO OEM Door Sill Protectors -SparksParts.com Diode Dynamics Elite Fog Lights @memario1214 Fog Light Backlighting PNP Harness @daveeasa TacomaTime Dash Cubby Drawer -etsy.com FPE Fogs + High-Beam Module @memario1214
    I have done the Subaru-Kicker tweeter / Kicker CS upgrade, if there is any bass loss, I certainly have not noticed it. With no sub and no amp, I am very happy with the bass I get. At higher volume (20+) when certain songs come on, the truck vibrates quite a bit from the bass. Do the upgrade, adjust your EQ, and allow some time for the speakers to break in. You wont be disappointed.
    Rett72 and bbartol like this.
  5. Jul 26, 2019 at 8:32 AM
    #3525
    Brobrady
    Good to know. Did you do component 6x9’s in the front and 6.5’s in the rear?
  6. Jul 26, 2019 at 9:29 AM
    #3526
    mlr69
    South Carolina
    Not component. The fronts are 6x9 3-way and the rears are 6.75 2-way, same as OP.
  7. Jul 27, 2019 at 8:46 AM
    #3527
    CemenTaco2019
    CemenTaco2019 Active Member
    2019 DCSB SR5
    None yet
    Just did the tweeters....holy shitballs it makes a difference! If you’ve been lurking and on the fence to do this get moving already. On to save some money up for front and rear speakers now!
    destin_meeks likes this.
  8. Jul 29, 2019 at 8:08 PM
    #3528
    NWBoon
    NWBoon Well-Known Member
    Puget Sound, WA
    2019 TRD OR DCSB Cement
    Thanks OP for starting this thread. I installed the recommended 6 speakers this past weekend and there’s a noticeable improvement over the stock speakers. I also added the Noico sound deadening product in the speaker holes on the interior of the outer door and around where the speaker mounts to the door. When I have more time, I’ll try to properly do all the doors.
    A question for those that have done the full doors, was it hard to reinstall the plastic vapor barrier using the same putty material that’s used from the factory? Did anyone have to buy new caulk like adhesive and if so, what kind?
    Thanks again everyone who posted their experiences. The project costed $300 for everything - speakers, noico, roller, and plastic door panel removal tools.
  9. Jul 30, 2019 at 11:54 AM
    #3529
    MassAppeal16
    MassAppeal16 Well-Known Member
    Carrollton, KY
    17 TRD MGM DCSB
    I just used the same stuff that was there. Seems to be holding up pretty well after pulling it off and putting it back on 3 times per door.
    NWBoon likes this.
  10. Jul 31, 2019 at 8:18 AM
    #3530
    BadgerBoy797
    BadgerBoy797 Member
    2019 RED TRD Sport
    For everyone doing this upgrade to the Kickers, are you ordering the
    46CSC6934
    since the
    43CSC6934
    from the OP post is no longer available?
    GreyBaldTaco likes this.
  11. Jul 31, 2019 at 12:18 PM
    #3531
    cshrum
    cshrum Well-Known Member
    CO Springs, CO
    17 blue TRD sport DCLB
    If you stay with the Kickers, yes. I am leaning towards another brand, but waiting for a sale or an "accidentally" blown speaker for motivation to buy.
    Good luck with your install. Seems to be pretty straight forward.
  12. Jul 31, 2019 at 3:20 PM
    #3532
    NWBoon
    Puget Sound, WA
    Yes.
  13. Aug 4, 2019 at 8:17 AM
    #3533
    TXTaco211
    TXTaco211 Well-Known Member
    Corpus Christi, Tx
    13 Pyrite Mica TRD Sport DCSB
    Kicker Speakers, 5100's with HS coils and HS AAL, Caliraised 30" LED light bar
    Hi everyone I may be a little dumb as I didn't realize this was for 3rd gens prior to ordering the Subaru tweeters. With that being said does anyone know if there is a pig tail harness that has the Subaru connector for the tweeter that I can splice into the factory tweeter harness for a '13 as the connector for the 2nd gens are not plug and play. :facepalm:I hope I am not the only DA that failed to pay attention. And I am sorry if this has already been discussed somewhere but I have been searching for 2 days now. Any help is appreciated.
  14. Aug 4, 2019 at 9:26 PM
    #3534
    BearWithMe
    BearWithMe Well-Known Member
    2025 OR 6MT Celestial Silver
    Prior: '18 OR 6MT
    I went with the Kicker KS-series for a few more bux (you get rubber surrounds instead of foam -- better longevity, among other improvements). When I first installed them, I was kinda torqued that they seemed to have a lot less bass. Fast forward about a week of playing lots of music, and they've broken in and now I think there's more bass. All in my head? Maybe! Very satisfied now with the speaker swap.
    destin_meeks and siKjiTz like this.
  15. Aug 5, 2019 at 10:28 AM
    #3535
    CodyH.
    CodyH. Well-Known Member
    Cody
    Arizona
    '17 Inferno TRDORDCLB4x4, '99 SC 4x4 5 spd
    Is this with the stock head unit and no amp?
  16. Aug 5, 2019 at 8:23 PM
    #3536
    BearWithMe
    Prior: '18 OR 6MT
    Yep, stock headunit, no amp. Been enjoying this for a few weeks, but (after reading about it) I've noticed just how much the stock headunit nerfs the signal to the rear speakers.
    So now I have a Kenwood DMX906S headunit on the way. 22 watts per channel should be an improvement, especially for the rears.
    CodyH.[QUOTED] likes this.
  17. Aug 5, 2019 at 8:29 PM
    #3537
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    How much of the computer integration will you loose by replacing the stock HU?
  18. Aug 5, 2019 at 9:38 PM
    #3538
    BearWithMe
    Prior: '18 OR 6MT
    Define "computer integration." I don't use the stock headunit for anything except playing music off my iPhone via USB, so for me there's nothing to lose. However, I wanted to keep my steering wheel audio controls so I went with the Metra MRR iDatalink integration box -- which also retains all the Toyota-specific stuff that you could access through the stock headunit.
  19. Aug 5, 2019 at 9:52 PM
    #3539
    oostroma
    oostroma (Boomer)
    Ontario
    For example, The build in GPS will provide next turn info on the centre display between the gauges. The stereo will also display the music info on the centre display as well. What about the cell phone integration with the steering controls that allow connect and hang up function?
  20. Aug 6, 2019 at 12:05 AM
    #3540
    BearWithMe
    Prior: '18 OR 6MT
    I don't have the unit yet, but I've heard the answer is no, maybe, and yes with the Maestro unit. Honestly, those first two things seem so useless -- I have never displayed the music or GPS turns (god the navigation interface is so bad on Entune) other than in the first 5 minutes of owning the truck just to check it out.
    For that matter, I can count the number of times I've used the phone integration on one hand, too.
