Premium Audio Upgrade for less than $250
Discussion in 'Audio & Video' started by bshammer0, Sep 14, 2017.
  1. Oct 12, 2020 at 4:24 PM
    #4241
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    They are if you got the adapters that are suppose to come free with the purchase of the speakers.
    boston23 likes this.
  2. Oct 13, 2020 at 9:03 AM
    #4242
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Thanks for the reply. It did come with the adapter. Now I am wondering if I need to run an amp as well or if i can just swap out the door speakers
  3. Oct 13, 2020 at 9:08 AM
    #4243
    oostroma
    oostroma (Boomer)
    Ontario
    Amplifying the speakers is always beneficial because the aftermarket speakers will handle it.
    I replaced all mine with Infinity the weekend after I got my Taco. It took awhile for them to break in but the quality improved greatly just by replacing the paper OEM ones. amplification will be my next step.
    One thing I think people are not doing along with upgrading the speakers is acoustically insulating the plastic door panels as well as insulating the doors.
  4. Oct 13, 2020 at 10:01 PM
    #4244
    mosccat
    mosccat Well-Known Member
    Mark
    Currently in Bend, OR
    2020 OR
    @TacoJon2020 found this whilst browsing Amazon... https://www.amazon.com/gp/product/B087Z1794K/ref=ask_ql_qh_dp_hza
    I spoke to tacoma toones and the do have the harness for $75.... tps://*********.com/shop/toyota-tacoma-audio-products/double-cab-audio-products/plug-play-wire-harnesses/tacoma-plug-play-amp-harness-installation-kit/
    I'm going to ask in the harness thread if this is what we need... fingers crossed
    EDIT: those that know confirmed the Amazon link above will not work for the kicker. So Tacoma tuunes is the only way right now...
  5. Oct 14, 2020 at 3:01 PM
    #4245
    mosccat
    Mark
    2020 OR
    Hey buddy, should I get the amp wiring kit from crutchfields? or can you draw power from the HU like pre 2019's seem to do?
  6. Oct 14, 2020 at 3:15 PM
    #4246
    DamGuide
    DamGuide Well-Known Member
    Nooga, TN
    2020 TRD Offroad
    Wiring is super easy with that camry kit I purchased, are you wanting to add a sub?
    I didn't add a sub.
    This is what I did, I cut the camry kit in two. I left the more length on the side that attaches to the terminal that goes to the speakers vs the other side that plugs into the HU.
    So you take the HU portion you just cut off and you solder all 8 wires to one of the harnesses that comes with the key. Its the one without the power and ground. Soldering is easy to figure out because the wires on both harnesses are the same colors 4 different colors and there are lines on one of the pairs of the same color to make the pairs easy to see which to wire together.
    Do the same on the other two harnesses you have left now, connection that goes to speakers from the camry kit gets wired together to the harness that wires to the kicker harness that has the power wires on it too. Same setup with 8 wires with 4 colors to choose from type deal where pairs of colors are easy to see the difference with one have a different color line. Red wires goes to your power, black wires go to your ground.
    Blue wire isn't wired up, at least I don't know how to wire it up and I wasn't able to find someone on here to tell where I could use that wire. You can turn this option off with the flip switches on the key. That's something else you want to look at here. I think I talked to dustinmeeks in one thread on here about it.
    Sub is added in with the really long wires that come with the camry kit. I cut those off because I have no plans to add a sub.
    You are just basically splicing into the middle of the camry harness.
  7. Oct 14, 2020 at 3:34 PM
    #4247
    mosccat
    Mark
    2020 OR
    Dude... thanks so much. I may actually be able to do this ;)
    It will make more sense once I get everything in front of me...
    Stuff is ordered and will be with me next week!
  8. Oct 16, 2020 at 9:08 AM
    #4248
    boston23
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Man i have an SR5 and just got the front door speakers delivered. Think its not worth the trouble to install then? Got me thinking i should just return them
  9. Oct 16, 2020 at 9:28 AM
    #4249
    oostroma
    oostroma (Boomer)
    Ontario
    Installation is quite easy. Just be careful when removing the triangles at the front of the door. The white clips can fall inward if you are note careful removing them with needle nose pliers. Any speaker replacement from the crappy paper OEM speakers will be an improvement.
    boston23[QUOTED] likes this.
  10. Oct 16, 2020 at 11:40 AM
    #4250
    DamGuide
    Nooga, TN
    2020 TRD Offroad
    I thought the fronts were a nice upgrade on my non premium TRD OR, the backs weren't noticeable, the kicker definitely improved it a lot, especially the back speakers.
  11. Oct 16, 2020 at 11:53 AM
    #4251
    mosccat
    Mark
    2020 OR
    Do you know what HU you had? My 2020 OR has the base 8” of the 4 options available in the Tacoma. I would have really thought it would have had at least the ‘audio plus’ upgraded HU, but nope.
  12. Oct 16, 2020 at 11:56 AM
    #4252
    mosccat
    Mark
    2020 OR
    It all depends on the HU, do u still have the window sticker? It’ll say...’audio’...’audio plus’...’premium’...’premium jbl’ depending on which HU u have...
  13. Oct 16, 2020 at 12:27 PM
    #4253
    boston23
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Yeah its just the basic head unit, im about to rewatch the unstall video and take this door apart
  14. Oct 16, 2020 at 12:30 PM
    #4254
    Cessna108
    Cessna108 Member
    Darci
    2017 Tacoma TRD
    Icon w resi, add a leaf, upper control arms, lights, wheels w 33’s
    So helpful! Thanks for taking the time to write this!
  15. Oct 16, 2020 at 1:54 PM
    #4255
    DamGuide
    Nooga, TN
    2020 TRD Offroad
    probably the audio plus then because I just have the base TRD OR with 8” and only LED headlights as an option.
  16. Oct 16, 2020 at 7:18 PM
    #4256
    boston23
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    My sticker says I have “etune audio plus with 6.1” touch screen”
    Think i’ll have enough power for the kicker door speakers?
  17. Oct 16, 2020 at 7:53 PM
    #4257
    mosccat
    Mark
    2020 OR
    My 2020 Trd OR with led and tech package only had ‘audio’ HU lowest of the low. Gonna be fixed soon with the kicker key 200 amp :)
  18. Oct 17, 2020 at 4:59 AM
    #4258
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    They will work but won’t sound great
  19. Oct 17, 2020 at 3:17 PM
    #4259
    boston23
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Hmm well now im leaning toward buying an amp to instead of returninf these speakers.
    Any suggestions on a decent budget amp? Not looking to spend too much more on the audio system
  20. Oct 17, 2020 at 3:42 PM
    #4260
    mosccat
    Mark
    2020 OR
