Premium Audio Upgrade for less than $250
Discussion in 'Audio & Video' started by bshammer0, Sep 14, 2017.
  1. Oct 9, 2021 at 8:05 PM
    #4521
    KoalaTACO
    KoalaTACO Active Member
    PA
    21' TRD OR DCSB
    Nothin crazy yet...
    Exact issue I'm having now! Just replaced the tweeters and...WOAH, does it "amplify" the poorness of the rest of the stock!
    I'm likely gonna go with the OP and grab Kicker all around (6x9 & 6.75) - can't wait to hear channel 23 then!
  2. Oct 30, 2021 at 7:22 PM
    #4522
    DustyMcTaco
    DustyMcTaco Well-Known Member
    2018 Tacoma TRD Sport
    Meso Taillights and other Meso stuff
    fuckin genius. i love it
  3. Nov 1, 2021 at 11:50 AM
    #4523
    KoalaTACO
    PA
    21' TRD OR DCSB
    Nothin crazy yet...
    I saw a similar mention earlier (unless of course you amplify them...).
    I'm planning my front 6x9 install this Friday. I did grab some sound dampening, but wondering if it's worth the trouble...any insight is appreciated!
    If I do decide to rip out the vapor barrier, is it worth trying to do so carefully and re-using it after the sound dampening...or just cut it and grab some new plastic sheeting to make a new one?
  4. Nov 1, 2021 at 12:33 PM
    #4524
    pochoboy
    pochoboy Well-Known Member
    I sound deaden one door yesterday and reattached the stock vapor barrier over the newly installed deadening material just because I wanted to but it doesn't make any sense at all, imo
  5. Nov 5, 2021 at 10:51 AM
    #4525
    KoalaTACO
    PA
    21' TRD OR DCSB
    Nothin crazy yet...
    Thanks!
    I decided to not deaden...just returned it and now have 50 bones to use some other way.
    The Kicker 6x9s sound SIIICK, by the way!
    Very happy I did that upgrade
  6. Nov 6, 2021 at 9:59 PM
    #4526
    MrGooch
    MrGooch Well-Known Member
    2021 Black TRD Pro
    I have a 21 pro will those speakers work for me too? You won't have to replace the amp? Is it plug n play?
  7. Nov 7, 2021 at 2:22 AM
    #4527
    KoalaTACO
    PA
    21' TRD OR DCSB
    Nothin crazy yet...
    @MrGooch
    As long as you do NOT have the JBL setup, this should all be plug and play. I'm not sure why the JBL stuff is different, but from all the talk on here, it is a big deal. I have a 21 TRD OR (non-JBL)...and it worked perfectly.
    That said, it's best to buy everything from Crutchfield because they include the front 6x9 & rear 6.5 brackets and wiring harnesses for free...if you're doing both...that equates to almost $70. I was SUPER pleased with them.
    Based on the low power of the factory HU, I opted to only replace the front 6x9s and tweeters for now...and did that without adding an amp. Down the road, I may punch up the output, and add the rears...but for me, this made sense.
    If you're like me, it's been a MINUTE since you were ripping door panels off and installing a system! YouTube is awesome for how to go about doing all this.
    Good luck man!
  8. Nov 7, 2021 at 4:47 AM
    #4528
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    Yup, they are only mostly for some filler for the passengers. The sound stage should be from the front, but it is also personal preference as some like that surround sound type of sound rather than rock concert from the front stage
  9. Nov 8, 2021 at 7:21 AM
    #4529
    MrGooch
    2021 Black TRD Pro
    All the 21 pros are JBL so I'm f'd
  10. Nov 8, 2021 at 7:30 AM
    #4530
    Barrister
    Barrister Well-Known Member
    Dennis
    Mesa, Arizona
    2023 TRD Pro, Solar Octane, 6 speed Manual
    Predator Steps, OEM Tonneau
    I’m not sure, but if the 6MT Pro follows a the same configuration as true TRD OR 6MT, it will have non-JBL Premium sound.
  11. Nov 30, 2021 at 2:26 PM
    #4531
    tigernut
    tigernut Member
    Texas
    2022 Tacoma Off-Road MT
    I just got done upgrading all my speakers and I wish I had read through this entire posting before ordering. The upgrade is a huge improvement as has been stated. I would not have spent the money to replace the rear speakers in my double cab though. They are terribly underpowered by the factory radio and the sound output on them is very low to the point of being quiet.
    The only other thing that frustrated me was the "sail panels" on the four doors and the plastic retainers. Pulling the panels off was easy, but the retainers remained in the door and I foolishly left them there on three of the panels when putting the panels back in place. This caused the cheap retainers to be pushed into the door and fall down inside the door. So now I need to order a few spare retainers to replace all the missing ones. On the last panel, I pulled it off, then carefully pulled out the retainers and placed them back on the panels before re-installing. Didn't lose a one that time.
    Here is what I installed, all from Crutchfield, ~ $240 with tax.
    Metra 72-8110 Speaker Wiring Adapters
    Metra 72-8104 Speaker Wiring Adapters
    Metra 82-8146 Speaker Mounting Brackets
    Metra 72-8109 Speaker Wiring Adapters
    Metra 82-8148 Speaker Mounting Brackets
  12. Nov 30, 2021 at 2:32 PM
    #4532
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    Live and learn regarding those white clips.
    I covered the holes with electrical tape and then cut a small slit. This will help keep them from falling inside the door the next time you pull those little panels off for the next mod requiring your door panel to be removed.
    tigernut[QUOTED] likes this.
  13. Nov 30, 2021 at 2:38 PM
    #4533
    tigernut
    tigernut Member
    Texas
    That's a brilliant idea, thank you.
    Just ordered some replacements from Amazon:
    https://www.amazon.com/Rexka-Moulding-Compatible-67771-58010-Highlander/dp/B08R247XX6
  14. Nov 30, 2021 at 2:47 PM
    #4534
    ryanvar42
    None
    We live and learn!! But glad you're enjoying it even if the rear ones didn't do much for you. Typically they are just for the passengers or rear fill as mentioned. I've thought about replacing my front door speakers but am pretty happy so far just with the tweeter replacement and the powered subwoofer I added. Not sure if it's really worth it to do the front door speakers
  15. Nov 30, 2021 at 3:55 PM
    #4535
    pochoboy
    on the rear door speaker wire adapter# 72-8109, did you notice the wire female connectors were reversed for the pos/neg speaker terminals? I thought they were plug n play and didn't pay attention to the color of wires and just attached which ever way so that both fit on properly. But found out later the speakers were out of phase.
    I used these on a '20, don't know if it's my model or Metra had the wiring messed up.
    Yeah, I understand the stock radio don't put out much for the rear doors but I added the Key amp and still the rear doors did not shine(nor the front speakers).
    I added an amp without knowin my rear speakers were out of phase and my system still didn't sound full so to say. I swapped the rear speakers wiring to fix the out of phase and sound deaden the inner and outer door panels and it really made a difference. Prior I had hardly any mid bass and with the fix and deadning i have more mid bass, it made a difference. Not saying it's going to work for you but it did in my case
  16. Dec 4, 2021 at 9:59 AM
    #4536
    ryanvar42
    None
    Was looking into doing the front door speakers as I recently did the subaru tweeter upgrade and put in a little powered sub. Should I just replace with a 6.5 speaker and not a 6x9? I don't need the bass from a 6x9 as I put in the little sub. Is that the correct way to go about it?
    Wicker24 likes this.
  17. Dec 4, 2021 at 10:06 AM
    #4537
    Wicker24
    Wicker24 Well-Known Member
    2018 TRD Off Road
    Dealers choice, won't make too much of a difference especially if you don't plan on adding a Amp to the door speakers.
    MGMDesertTaco likes this.
  18. Dec 4, 2021 at 10:17 AM
    #4538
    ryanvar42
    None
    My thinking of was for SQ. Maybe it would produce a better mid and high with the 6.5 since I don’t need extra bass from the 6x9. I will not be adding any more equipment besides just the door speaker. Is it not worth it to upgrade the door speakers in the front only? I thought this thread said it made a difference
    Wicker24[QUOTED] likes this.
  19. Dec 4, 2021 at 10:58 AM
    #4539
    Wicker24
    2018 TRD Off Road
    Oh it will make a difference over stock speakers for sure. You just may not notice a difference between 6x9 or 6.5 until amplified. I personally went with 6.5 myself
  20. Dec 4, 2021 at 11:04 AM
    #4540
    ryanvar42
    None
    Okay. I think you’re missing what i am trying to do. I added a sub and amp. I don’t need extra bass. That is why i was thinking 6.5 over a 6x9. There’s 6x9s in the door to add bass because stock stereo doesn’t have a sub. But i do. The 6.5 will be mids and highs and a 6x9 will have mids, highs and lows. There should be a difference
