Premium Audio Upgrade for less than $250
Discussion in 'Audio & Video' started by bshammer0, Sep 14, 2017.
  1. Sep 14, 2017 at 11:56 AM
    #41
    CleanWilly
    CleanWilly Well-Known Member
    2017 Access Cab Offroad
    I looked on Crutchfield and yes they fit both Double and Access.
    Thanks for the post OP
    Taco Fan and bshammer0[OP] like this.
  2. Sep 14, 2017 at 11:57 AM
    #42
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    Ordered it all, thank you very much!
    I saw the tweeters weren't prime on Amazon so I jumped over to Ebay and saw them about 8 bucks cheaper there so here's the link for a slightly better price.
    http://www.ebay.com/itm/112408475945
    For the adapters and/or speakers, did you apply any foam tape to the surfaces that mount together? Think that's needed?
    #42
    bshammer0[OP] and James_Bond like this.
  3. Sep 14, 2017 at 12:01 PM
    #43
    James_Bond
    James_Bond Well-Known Member
    Southern California
    '16 TRD Sport DCLB
    All stock
    If you are going to buy speakers, I have yet to find better deals than Cruchfield. They throw in all the adapters and installation adapters/ tools screws needed to do the job for free.
    #43
  4. Sep 14, 2017 at 12:12 PM
    #44
    EPH
    EPH Well-Known Member
    Mission Viejo, Ca
    16' TRD Sport 4x4
    I replaced the tweeters a few months back and noticed a big difference but wasn't quite ready to spend a bunch more cash to continue upgrading the stero. This is exactly what I was looking for as far as upgrades. Simple, inexpensive, and no cutting or splicing.
    Just completed my crutchfield order! And I had some points to use, so $120 shipped to my house isn't bad. Thanks OP @bshammer0
  5. Sep 14, 2017 at 12:13 PM
    #45
    EPH
    Mission Viejo, Ca
    16' TRD Sport 4x4
    @msegal55 get on this while this stuff is still on sale!!
  6. Sep 14, 2017 at 12:20 PM
    #46
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I think I'm gonna have to order too while it's on sale.
    bshammer0[OP] likes this.
  7. Sep 14, 2017 at 12:23 PM
    #47
    Scooby24
    Greg
    2017 DCSB OR 4X4
    Yeah, with the sale, my total cost was like 224 shipped with everything. That's a hell of a price for what sounds like a great upgrade. Looks like the factory 6x9 is a single way and it's probably only getting the lower frequencies...in my experience going to a 3 way there reduces the overall punch so I hope that doesn't happen here, but based on bshammer's review that doesn't seem to be the case so fingers are crossed.
    James_Bond and goose443 like this.
  8. Sep 14, 2017 at 12:47 PM
    #48
    cafereef
    cafereef Well-Known Member
    2017 MGM Tacoma TRD Sport
    TRD Sport Exahust, OEM roof Rack, Predator Pro side steps.
    following
  9. Sep 14, 2017 at 12:50 PM
    #49
    goose443
    goose443 Well-Known Member
    Austin
    Texas
    2016 Tacoma TRD Off Road 4x4
    This is my main concern as well...
    The factory speakers have pretty good bass. I hope I don't lose that
  10. Sep 14, 2017 at 1:15 PM
    #50
    mhtacoma
    mhtacoma Well-Known Member
    Columbus, Ohio
    2016 DCSB MGM TRD Sport
    I am going to try the 2-way for the front door. Another option is the component system for 100 and not use the tweeter if you want to keep kicker. Going to compare pricing on others not on sale.
    CoastieRon likes this.
  11. Sep 14, 2017 at 1:31 PM
    #51
    FISHTACO17
    FISHTACO17 New Member
    AJ
    Long Island, NY
    17 QUICKSAND DCSB SR5
    Anyone know if this upgrade is compatible with the Entune Audio Plus that comes with the SR5? Thanks!
  12. Sep 14, 2017 at 1:34 PM
    #52
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    Anyone know what the difference is between the 43DSC69304 and 43CSC6934 speakers are? The DSC is $20 cheaper and has the same specs except they are 4 ohm vs 3.5. Peak power handling is also down, but sometimes higher peak power handling means less useful sound output per watt right??
    https://www.crutchfield.com/p_206DSC6904/Kicker-43DSC69304.html?tp=105
  13. Sep 14, 2017 at 2:00 PM
    #53
    dg108
    dg108 Well-Known Member
    2016 MGM Tacoma TRDS AC MT
    Those are what I ordered, installing tomorrow. The Crutchfield website sometimes has an issue with which speakers go front and back. I believe both cab styles are 6x9 front and 6.5 rear but you can go 6.75 if you want.
  14. Sep 14, 2017 at 2:43 PM
    #54
    James_Bond
    Southern California
    '16 TRD Sport DCLB
    All stock
    It looks like DSC are their OEM replacement line vs the CS which are competitive series that are usually paired with an amp.
    They both give you the same frequency response. I guess you can cough up the extra $20 to get a better built speaker.
    I would pay the extra and get the better voice coil that can take a beating.
    Granted the you will get more out of the more expensive ones when you crank up the volume on them.
    Either way, both are at a reasonable price.
  15. Sep 14, 2017 at 2:57 PM
    #55
    goose443
    Austin
    Texas
    If I'm not mistaking, I think the 3.5 ohms might result in a little bit more volume than the 4 ohm speakers
  16. Sep 14, 2017 at 3:09 PM
    #56
    James_Bond
    Southern California
    '16 TRD Sport DCLB
    All stock
    You would hope so but what you have to see is the frequency response per watt graph for each speaker... both are rated at 90-91dB/1watt so they essentially will give you the same volume/watt.
    goose443[QUOTED] likes this.
  17. Sep 14, 2017 at 3:11 PM
    #57
    Scooby24
    Greg
    2017 DCSB OR 4X4
    Not sure if these will make a difference but I called Crutchfield to ask about whether or not it would be worth using a different series or 2 way vs. 3 way speaker and they said no, using a stock head unit, you wouldn't see a difference...However, he recommended I buy baffles to get some additional bass response. Here's what he ordered for me, indicating they were compatible with truck/speaker selection for the CS Kickers. He suggested cutting out a quarter sized hole in the back.
    https://www.crutchfield.com/p_696B0...line-3-1-2-depth.html?tp=2809&omnews=13792322
    https://www.crutchfield.com/p_696B0...lim-line-3-depth.html?tp=2809&omnews=13792322
    bshammer0[OP] and speedtre like this.
  18. Sep 14, 2017 at 3:23 PM
    #58
    Tunngavik
    Tunngavik Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
  19. Sep 14, 2017 at 3:47 PM
    #59
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    Are the Subaru tweeters available from Crutchfield? I'm having trouble finding them
  20. Sep 14, 2017 at 3:57 PM
    #60
    slowboater
    slowboater Well-Known Member
    How much of a pain is it to replace the door speakers?
    EPH likes this.
