Premium Audio Upgrade for less than $250
Discussion in 'Audio & Video' started by bshammer0, Sep 14, 2017.
  1. Dec 7, 2017 at 4:53 AM
    #1361
    DeathsArrow
    DeathsArrow Well-Known Member
    It took me nearly 2 months to install and wire the powered subwoofer I bought. Take your time, do a little at a time, it'll get done.
  2. Dec 7, 2017 at 5:19 AM
    #1362
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    Not that I've seen, but if I run across one I'll post it up here.
    dziner likes this.
  3. Dec 7, 2017 at 9:12 AM
    #1363
    Pikestaco
    Pikestaco Newbie
    Los Angeles
    2017 Quicksand 4x4 TRD Sport DCLB
    need to learn more about this stuff
    Check my posts. Newbie and tried to explain it in detail. Give yourself 6-7 hours if you’re doing it.
  4. Dec 7, 2017 at 9:24 AM
    #1364
    jsey21
    jsey21 Well-Known Member
    2016 Black Tacoma Sport DCSB V6 4x2
    OVTuned https://www.tacomaworld.com/threads/rear-diff-vent-behind-the-tail-light-mod.286097/ https://www.tacomaworld.com/threads/rust-on-frame-with-a-c-drain-mod-fix.444138/ https://www.tacomaworld.com/threads/ultimate-led-turn-signals.486423/ https://www.tacomaworld.com/threads/premium-audio-upgrade-for-less-than-250.510424/
    I used JBLs: GT7-96 & GT7-6
    https://www.crutchfield.com/p_109JBLG796/JBL-GT7-96.html?tp=91
    https://www.crutchfield.com/p_109JBLG76/JBL-GT7-6.html?tp=94
    Awesome sound... love them and am very happy w/ what I have in the truck. They are extremely efficient and fit great. These are the speakers the tech at Crutchfield suggested for me as I was first looking at Infiniti speakers. He noted on those that the Infiniti speakers would not sound great without a separate amp to push them. I did not want to go that far, so these were a great substitution.
    I said this somewhere else - you could probably go to Wal-Mart and get some cheap Pioneer speakers from there that would sound better that what is in the truck.
    Friedtacolover likes this.
  5. Dec 7, 2017 at 9:45 AM
    #1365
    CodyH.
    CodyH. Well-Known Member
    Cody
    Arizona
    '17 Inferno TRDORDCLB4x4, '99 SC 4x4 5 spd
    If you'e referring to me, I read your posts yesterday. I've read literally every post in this thread. Yeah I think I will need at least that much time, if not more. I tend to take my time with most stuff, especially since I'm gonna be trying to be super careful
  6. Dec 7, 2017 at 3:00 PM
    #1366
    jholc21
    jholc21 Well-Known Member
    Colorado
    2017 White Tacoma TRD OR
    Bilstein 6112/5160 w/Dakars Leafs 255/80/R17 Cooper ST MAXX Skinnies 4.88 Gears TRD Pro Fog Lights Cali Raised 5D Combo Leather Seats LED Bed Lighting ARE Overland Shell
    What do you think made the biggest impact on road/wind noise in the cabin, the doors or the rear wall? I've done the front doors and noticed an improvment but have not yet had time to do the rear doors or rear wall. Probably gonna do the rear wall first.
  7. Dec 7, 2017 at 3:48 PM
    #1367
    DeathsArrow
    It's hard to tell. The rear wall lets a lot of road noise through. I had my rear seats and bins out for a week while I was working on the subwoofer mount and the rear wall noise was awful, especially on the highway.
  8. Dec 7, 2017 at 3:51 PM
    #1368
    jholc21
    Colorado
    did you mess with the vent at all? It seems like most of the noise is coming from that passenger side vent. saw pics of a guy who actually pulled the bed off the truck so he could get to the vents from the outside.
  9. Dec 8, 2017 at 4:08 AM
    #1369
    DeathsArrow
    No, there's no need as long as the seats and bins are in.
    jholc21[QUOTED] likes this.
  10. Dec 8, 2017 at 6:07 AM
    #1370
    sbmon
    sbmon Well-Known Member
    Big thank you for the OP and other supporting members here with this thread. Upon reading this and all the positive comments I too picked up all the items exactly as detailed in the first post. The results were really good for the money and totally worth it imo. While I did get the sound suppression material noted in the first post I did not install it. I took one look at the extra work involved at the time and was pressed for time so I figured I would do the speakers alone first then decide later when I have more time if I want to go back and add the material. As of now I don't plan on going back to add the material.
    My question now is would there be a good benefit of adding an amp to this (kicker) setup and how involved (cost, possible products) would that be? What do you folks think?
    Any input is appreciated and thank you again to all the folks here who have helped to promote this worthwhile upgrade.
  11. Dec 8, 2017 at 7:03 AM
    #1371
    Friedtacolover
    Friedtacolover Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
    Disclaimer: the setup i purchased below is by no means a high quality expensive setup. It gets job done reliably and adds tons of value though.
    A few added an amp setup and posted above. The speakers handle 150 and 100 watt rms so there would absolutely be a value to adding an amp. I just returned the very expensive setup i purchased from crutchfeild and went with a 5 channel kenwood amp that pushes 50 watts to each speaker and 300 watts to my sub instead. All you would need for an amp to the speakers would be an amp, with hi level inputs to the amp or the rca connector that plugs and plays listed in a post above but that one has bad reviews. Then a 4gauge wiring kit for 40$ or so. So cost is around 300$ to do it and about 2 hours of work for me since ive done about 10 installs on amps and subs or for a novice about 4 hours. As far as quality, you could do a lc6i and all those things but this isnt the thread for that this is the novice simple install thread the op intended plus a little extra to add to op’s original suggestions.
    Materials:
    50x4 channel amp with hi level input
    4 gauge wiring kit
    9 wire speaker wire and rem bundle to go from amp to speaker wire behind stereo.
    (Optional only) line in converter such as lc6i.
    This is what i just purchased:
    1)Amp https://www.crutchfield.com/p_113X8015/Kenwood-Excelon-X801-5.html
    2)17’ 4 gauge red wire, 5’ 4 gauge black wire, 90 watt in line fuse
    3)(x2)9 strand speaker wire to connect audio from stereo to amp then audio from amp to speakers. https://www.crutchfield.com/p_1429WC1820/EFX-9-Wire-Ultra-Flex-Speaker-Wire-20-feet.html?tp=2917
    Best buy wanted 450$ to install amp when i asked the installer lastweek and local stereo shop wanted 275$ to install. The wiring cost me 90$ and i get to install it how i want it so i chose this route.
    So you have many options, many different 4 channel amps out there, many different components to add to installation if you wanted the “competition sound quality etc.” but in the end all you need is an amp and to have it wired.
  12. Dec 8, 2017 at 7:24 AM
    #1372
    jsey21
    The rear is terrible at letting in road noise. If I ever get where I'm that so bored that I'm game for pulling all the stuff out to get to it, I'd do that in a heartbeat. Anything you add to this truck will help. I think they put in as little as possible and milked all they could out of us in profit on it.
  13. Dec 8, 2017 at 1:09 PM
    #1373
    killthehippies
    killthehippies French Fry Enthusiast
    Joseph
    Southern California
    '16 TRD OR AC 4x4
    quick question. what size speakers are in the rear of an access cab (2016)? i keep seeing people listing both 6.75 and 6.5 for the rear doors.
  14. Dec 8, 2017 at 2:02 PM
    #1374
    small_contraptions
    small_contraptions Member
    6.75 kickers fit just fine.
  15. Dec 8, 2017 at 4:25 PM
    #1375
    pop639
    pop639 Well-Known Member
    Western PA
    16 SR5 DCSB 4x4
    Anyone have any luck installing this setup on an sr5?
  16. Dec 8, 2017 at 4:41 PM
    #1376
    Friedtacolover
    Travis
    Ontario, Ca
    It would be exactly the same wouldnt it?
  17. Dec 8, 2017 at 5:11 PM
    #1377
    pop639
    Western PA
    16 SR5 DCSB 4x4
    I think the head unit is different
  18. Dec 8, 2017 at 5:11 PM
    #1378
    pop639
    Western PA
    16 SR5 DCSB 4x4
    Well...it definitely is different
  19. Dec 9, 2017 at 8:05 PM
    #1379
    beers@1600
    beers@1600 Well-Known Member
    North Carolina (some of the time)
    2017 TRD OR DCSB MT 4x4 MGM
    Finally got to install today, awesome sound. Was really impressed in how clear the music came through at a high volume. Thanks again @bshammer0 :cheers:
  20. Dec 10, 2017 at 9:47 AM
    #1380
    FLdub
    FLdub Well-Known Member
    SRQ FL
    2016 Black Tacoma TRD OR 4x4
