Premium Audio Upgrade for less than $250
Discussion in 'Audio & Video' started by bshammer0, Sep 14, 2017.
  1. Jan 8, 2018 at 11:36 AM
    #1521
    Disco
    Disco Well-Known Member
    Diego
    San Diego
    2018 TRD Offroad 4x4 DCSB Cement
    Looking forward to seeing your sub box, I'd like to put one in as well. Which JBL amp did you get?
  2. Jan 8, 2018 at 11:39 AM
    #1522
    Malibu7tss
    Malibu7tss Can' t think of anything to type here right now.
    Central pa.
    2016 trd sport dcsb 4x4 bbp 6spd manual
    Old man emu with 888's and headstrong off road progressive aal, trd pro wheel, Cooper Stt Pros 285/70r17
    Disco[QUOTED] likes this.
  3. Jan 8, 2018 at 4:03 PM
    #1523
    barcelona7568
    barcelona7568 Well-Known Member
    CO
    16 DCLB, Stock
    If I had a wager a guess, I would say bass will develop as you break the speakers in and wear some of the stiffness out of them. Hopefully.
    JeffB and Malibu7tss[QUOTED] like this.
  4. Jan 8, 2018 at 4:25 PM
    #1524
    ToyoDrew
    ToyoDrew Well-Known Member
    Texas
    17 Inferno TRD-OR DCSB 4x4 (SOLD)
    OVTune, Hertz spkrs & JBL MS-8 DSP, Turn-as-Tail mod, LEDs everywhere, MESOJDM Turn Signal, Bakflip Revolver X2, Pop-n-Lock, Yakima roof rack, & many minor mods
    Yup, what he said! Give it a couple weeks. It won't be significantly louder, but you will find yourself liking it more than you remembered when it was first installed. :D Plus, you may need to re-adjust your eq settings at that point...
    Malibu7tss likes this.
  5. Jan 8, 2018 at 4:48 PM
    #1525
    CoastieRon
    CoastieRon Hammocking Fool
    Ron
    Nashua
    Lil' Silver
    Too much.
    Speakers, assemble!
    bshammer0[OP] and Malibu7tss like this.
  6. Jan 10, 2018 at 10:33 AM
    #1526
    inthebed
    inthebed Well-Known Member
    2010 Tacoma TRD Off-Road Prerunner
    It's more of an issue of isolating the noise coming from the rear of the speaker away from the noise coming from the front of the speaker, at least I think that's the only reason people cover the front of the panel holes.
    bigfoote13[QUOTED] likes this.
  7. Jan 10, 2018 at 10:53 AM
    #1527
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    Noise from the rear of the speaker? I am not familiar with that.
  8. Jan 10, 2018 at 2:58 PM
    #1528
    blewis
    blewis Well-Known Member
    B
    Lakewood Ranch, Fl.
    17 DCSB 4X4
    So I just installed the tweeters & love how plug & play it was. The front/rear speakers are arriving later on the UPS truck. Without having to search through this entire thread- are the speakers as plug & play as the tweeters with the connections included in the Crutchfield kit? I can tell they gave me over $100 of wiring harness & adapters but is that all installed & ready to go? Or do I have to cut & connect some wires to the speakers? I’ll finish everything tonight if it’s that easy, if it’s not I’ll probably wait until Friday afternoon or the weekend. Any info is appreciated.
  9. Jan 10, 2018 at 3:09 PM
    #1529
    Pikestaco
    Pikestaco Newbie
    Los Angeles
    2017 Quicksand 4x4 TRD Sport DCLB
    need to learn more about this stuff
    they are plug and play. but its not as quick because you have to remove all the door parts and disconnect handles and window buttons, etc. you will need to also mount the speakers the the mounts they sent. and it isn't going to be a perfect mount. you'll have to either drill new holes, or screw the screws in diagonally a bit.
  10. Jan 10, 2018 at 3:11 PM
    #1530
    blewis
    B
    Lakewood Ranch, Fl.
    17 DCSB 4X4
    Thanks for the quick response. I was aware that taking the doors apart would be time consuming & that’s why if I had to do any wiring I was going to wait. I’ll figure out the mounts & make it work somehow, I just hate messing with wires. I can do plastic, screws & drills.
  11. Jan 10, 2018 at 4:17 PM
    #1531
    CoastieRon
    Ron
    Nashua
    Lil' Silver
    Too much.
    The adapters crutchfield gives you already have slide on clips that slide on to the speaker terminals. Then they become plug and play. No soldering needed
  12. Jan 11, 2018 at 11:41 AM
    #1532
    goose443
    goose443 Well-Known Member
    Austin
    Texas
    2016 Tacoma TRD Off Road 4x4
    How is the Rockville sub holding up? I am considering this as well...
    bigfoote13 likes this.
  13. Jan 11, 2018 at 12:37 PM
    #1533
    siKjiTz
    siKjiTz Well-Known Member
    E
    Oahu, HI
    2017 DCSB TRD Sport Inferno
    TUNED 2.0 Beta 87 Eibach Pro Truck Lift Kit Stage 1 Wheelers 1.5” Progressive AAL Level 8 MK6 17x8 Falken Wildpeaks 265/70/17” Redline Tuning Hood struts Matt Gecko LED Bed lights OEM Roof racks GoRhino RB20 Running boards A/C drain Mod Kicker speaker upgrade w/kicker key amp. MESO Stage 1 Tail light upgrade OEM Bed Mat
    Is it nessesary to disconnect the battery when installing the kicker tweeters? (As shown in the YT video by OEM audio) Tweeters just got delivered. I want to run home and get it installed.
  14. Jan 11, 2018 at 12:48 PM
    #1534
    goose443
    Austin
    Texas
    I would cause it is right there by the airbag in the a pillar
    siKjiTz[QUOTED] likes this.
  15. Jan 11, 2018 at 1:39 PM
    #1535
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    I just did it. I disconnected the negative just for insurance in case the speaker wire touched something it shouldn't have. Also since the airbag is there didn't want something happening. I wanted to put some extra foam backing in the a pillar to prevent future noise/creaking but didn't have the time with the install and it wasn't making noise prior so hopefully it stays that way.
  16. Jan 11, 2018 at 2:46 PM
    #1536
    derf77
    derf77 Well-Known Member
    Fred
    South Chesterfield, VA
    2017 TRD DCSB OR MT Silver
    6112's 2.75 in. lift front, Icon UCA's, 5160s w/res, Deaver mini pack in the 1.5 in rear lift, TJM Rock Crawler front Bumper, Baja Squadron Sport lights, TJM Rock crawler lights, SPOD w/touchscreen, Rokblokz rear mud flaps, Method NV Wheels, 285/70R17 Nitto Ridge Grapplers
    I just pulled the trigger! Tweeters and door speakers will be arriving the 17th!
    I feel confident I can manage the install for tweeters, but who is near Ventura that wants to help me with door speakers install for beer?
  17. Jan 11, 2018 at 2:50 PM
    #1537
    goose443
    Austin
    Texas
    It’s not bad at all!
    derf77[QUOTED] likes this.
  18. Jan 11, 2018 at 3:09 PM
    #1538
    derf77
    Fred
    Right?! Thanks to this forum I am like 6 grand poorer!...But my Taco is becoming one BAD ASS MOFO!
    However I may be divorced soon......(sigh) time to go look at the bumpers again....
    bshammer0[OP] and solscooter like this.
  19. Jan 11, 2018 at 3:29 PM
    #1539
    derf77
    Fred
    ARRGGGHH! I just ordered the tweeters and kickers....WHY did I keep reading?! Now I have to order this as well! I'm getting off before I order an Amp and sub as well!!!
  20. Jan 11, 2018 at 3:30 PM
    #1540
    CoastieRon
    Ron
    Nashua
    Lil' Silver
    Too much.
    I didn't. But meh.
