Premium Audio Upgrade for less than $250
Discussion in 'Audio & Video' started by bshammer0, Sep 14, 2017.
  1. Jan 24, 2018 at 1:25 PM
    #1681
    IndyFastlane
    IndyFastlane Well-Known Member
    Did you replace the dash tweeters with the Subaru Kicker tweeters? The reason I ask is because the door (front door at least) speakers are wired in series with the tweeters. If the tweeters are unplugged, the door speakers go silent. Is it possible that the new tweeters didn’t get plugged in all the way? Just something else to help troubleshoot.
  2. Jan 24, 2018 at 2:10 PM
    #1682
    bshammer0
    bshammer0 [OP] Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Most have gone w/ the Kicker set on the OP but I've seen several different brands tested with various results - mostly positive. I don't think you can go wrong w/ the Kickers unless you are loyal to a particular brand like Rockford, Infinity, etc., and plan on doing a more extensive setup w/ an amp/sub. The 6x9 kickers have a lot of bass for MOST tastes, and the 3-ways while it may seem would be too much treble generally does a great job of delivering crisp highs, the rears aren't "loud" but serve as a great "surround" filler. Anything will be an upgrade from the OEM paper speakers, so you can't really go "wrong" :)
    Good luck!
  3. Jan 24, 2018 at 5:28 PM
    #1683
    Bmore_inferno
    Bmore_inferno Member
    Columbia, MD
    2017 Inferno Tacoma, TRD Sport
    3" ReadyLIFT Fuel Off-Road Vapor 18" Rims BF Goodrich KO2's (285/65/18) Nfab 3" nerf bars Black Toyota Emblems
    Thank you for this thread and original post! Bought my 2017 TRD Sport Inferno a few weeks ago and it came with pretty much everything I wanted, except the upgraded JBL Sound System.
    Found this thread, ordered my Kicker Tweeters on Monday from Amazon...they arrived today and I installed them tonight. I'm going to just stick with the Tweeter's now and not mess w/ the door speakers.
    Tocamo likes this.
  4. Jan 24, 2018 at 5:32 PM
    #1684
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    Do the doors. So much better.
  5. Jan 24, 2018 at 5:35 PM
    #1685
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    It's some work, but do the doors and back wall with dynamat or similar, it'll feel like a different truck.
    bigfoote13 likes this.
  6. Jan 24, 2018 at 5:41 PM
    #1686
    Bmore_inferno
    Columbia, MD
    dangit... guess i gotta do the door speakers. lol
    i need to watch the video 20 more times on taking the door apart to make sure i don't screw it all up. also need to wait for some warmer weather to be outside gettin this done.
    shakerhood likes this.
  7. Jan 24, 2018 at 5:45 PM
    #1687
    CoastieRon
    CoastieRon Hammocking Fool
    Ron
    Nashua
    Lil' Silver
    Too much.
    You can do it. Take your time. If you don't use sound proofing, takes about 15 minutes per door. As long as you order from Crutchfield, you'll get all the adapters and plugs you need.
    bshammer0[OP] and bigfoote13 like this.
  8. Jan 24, 2018 at 5:49 PM
    #1688
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    Do the sound deadening too. I bought a small quantity and the roller. Took maybe an extra ten minutes. Do around the speaker opening and just behind the speaker.
    Honestly these are the most simplest doors i have ever removed.
    CoastieRon likes this.
  9. Jan 24, 2018 at 6:01 PM
    #1689
    Bmore_inferno
    Columbia, MD
    alright, that all sounds good. i appreciate the encouragement and details. the video tutorial seems really helpful, so i should be good to go once i order the speakers. will def order from Crutchfield to get the adapters. as far as the "plugs", is there any new wiring that needs to be done, or are the door speakers "plug and play" too, as easy as the tweeters were?
    I can look back at the video, but i didnt really pay much attention to the door part of the video cuz i didnt plan on doing it.
  10. Jan 24, 2018 at 6:06 PM
    #1690
    Malibu7tss
    Malibu7tss Can' t think of anything to type here right now.
    Central pa.
    2016 trd sport dcsb 4x4 bbp 6spd manual
    Old man emu with 888's and headstrong off road progressive aal, trd pro wheel, Cooper Stt Pros 285/70r17
    Nope no additional wiring. Where at in Maryland are you. Might be close enough for me to lend a hand if you need it.
  11. Jan 24, 2018 at 6:21 PM
    #1691
    Bmore_inferno
    Columbia, MD
    thanks man, appreciate it. Columbia, MD here. little hike between here and Mechanicsburg.
    Nice Taco btw. I previously had a Navy Blue Taco before, and was bummed they switched the shade of blue to a more bright blue, but urs looks awesome w/ the black grille and black rims...it also doesnt look as bright streak blue. very solid!
    Malibu7tss[QUOTED] likes this.
  12. Jan 24, 2018 at 6:22 PM
    #1692
    CoastieRon
    Ron
    Nashua
    Lil' Silver
    Too much.
    As long as you order from Crutchfield, select your model truck on the site, and mark the front speakers and rear speakers correctly in your order, Crutchfield will supply what you need to make them plug & play.
    Bmore_inferno[QUOTED] likes this.
  13. Jan 24, 2018 at 6:53 PM
    #1693
    Charles135
    Charles135 Well-Known Member
    LA-Orange county
    19 cement trd
    I replaced the door tweeters with a different brand. I'm in a 14 so the kicker tweeters wouldn't fit. I only changed the tweeters and upgraded doors to the kicker 6x9's from the OP.
  14. Jan 24, 2018 at 7:01 PM
    #1694
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    Crutchfield said the kicker 6x9 wouldn't fit in my 15.
  15. Jan 24, 2018 at 7:23 PM
    #1695
    IndyFastlane
    Ok. Gotcha. I missed the part that you were working on a 14. Hope you get it sorted out soon! :thumbsup:
  16. Jan 25, 2018 at 3:53 AM
    #1696
    Malibu7tss
    Central pa.
    Yes. Definitely a hike. You will be ok. Take your time and follow the video. It’s a 2 on a scale of ten. Your truck looks awesome too. I was back and for between the blue and the inferno.
  17. Jan 25, 2018 at 6:42 AM
    #1697
    derf77
    derf77 Well-Known Member
    Fred
    South Chesterfield, VA
    2017 TRD DCSB OR MT Silver
    6112's 2.75 in. lift front, Icon UCA's, 5160s w/res, Deaver mini pack in the 1.5 in rear lift, TJM Rock Crawler front Bumper, Baja Squadron Sport lights, TJM Rock crawler lights, SPOD w/touchscreen, Rokblokz rear mud flaps, Method NV Wheels, 285/70R17 Nitto Ridge Grapplers
    I didn't need to... just mounted the speakers to adapters, used the adapter connector from Crutchfield and mounted the whole set up to the door and it worked beautifully. A little tinny at first with a decreased bass response, but now after a couple off weeks I'm really debating if I really need an amp or sub. It sounds that good with deep clean bass.
  18. Jan 25, 2018 at 8:39 AM
    #1698
    TXTaco13
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    How'd it sound with just the tweeters?
  19. Jan 25, 2018 at 9:32 AM
    #1699
    CoastieRon
    Ron
    Nashua
    Lil' Silver
    Too much.
    With just switching out the tweeters, the sound is improved in the high end, with clearer vocals/high notes. A good amount of the muddiness goes away.
    TXTaco13[QUOTED] likes this.
  20. Jan 25, 2018 at 5:35 PM
    #1700
    Bmore_inferno
    Columbia, MD
    agreed. definitely a sharper, clear sound. i do kinda feel like they overtake the door speakers a bit too much, or there isn't the best crossover mix between the two, but that may just be a mental thing since i know only the tweets have been swapped. i turned the treble down a notch or two now, and it balanced out a bit.
    overall the sound is more crisp and it works for me. i won't be disappointed just sticking with the tweeter replacement for now.
    TXTaco13 likes this.
