Premium fuel in non S/C Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WheelinJ91, Mar 30, 2012.
How and if you run premium.
Poll closed Apr 14, 2012.
  1. Premium all the time.
    59 vote(s)
    36.4%
  2. Premium highway only.
    3 vote(s)
    1.9%
  3. Premium highway, reg in the city.
    1 vote(s)
    0.6%
  4. I never run premium.
    73 vote(s)
    45.1%
  5. Have not tried.
    26 vote(s)
    16.0%
  1. Mar 31, 2012 at 3:33 PM
    #61
    Workman
    Workman Well-Known Member
    06 access cab, off road, V6
    Workman always uses 91 octane. Workman gets 21-23MPG, always.
    Workman always chooses gas stations that carry Non ethanol gas.....Workman can't stand ethanol.
    Workman
  2. Mar 31, 2012 at 3:35 PM
    #62
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  3. Mar 31, 2012 at 3:57 PM
    #63
    DanglingFury
    DanglingFury Creeper
    Keith
    Bowling Green, KY/Lake Cumberland, KY
    2006 4Runner 4x4
    Daystar 2.5"/1" lift-level BFGoodrich KO2's
    You can put anything in your tank as long as it's 87 octane gasoline or higher (and more importantly clean) and you're not doing your truck any harm. If I've got the extra 5-10 bucks to fill up with premium I usually do. Anyone who says it's "bad" to run "better" fuel in your truck obviously doesn't know what they're talking about..
  4. Apr 1, 2012 at 3:06 PM
    #64
    ryansummit
    ryansummit Well-Known Member
    NY
    POWERLESS '08 v6 4x4 access cab
    smoke tails, safety rack, coffee stains, caulk, paint, tar, sawdust, foul odor
    when i got my '08 dealer told me to put good(shell,mobil) 87 in it
    no need for premium. i do understand he wants me to come back for a new truck asap,
    and i have no sport or performance anything on my v6.
    so i follow directions well, esp. if they save me money
    the only thing i avoid is no name stations and Stewart's, i dont trust that guy as far as i can throw one of his stale buttered rolls
  5. Apr 1, 2012 at 4:13 PM
    #65
    WheelinJ91
    WheelinJ91 [OP] Well-Known Member
    Edmonton,AB
    2012 TRD DCSB
    Airaid Intake, MBRP Exhaust, Toytec OME 3" lift w/AAL, Flip-kit, LR UCA's, Weathertech Floor mats, hood and window deflectors.
    Haha i would never use what the dealer "tells" me, went with my mother when she bought a KIA and they said "shell", there fleet cards are for shell and it distroyed the engine 4 weeks after she got it...... they tryed to fix it 5 times .....
  6. Apr 1, 2012 at 5:51 PM
    #66
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Shell did not destroy the engine. The engine had a problem from day-1.
    That has been a nasty myth about Shell for over 30 years. "Shell will burn up your engine".
  7. Apr 2, 2012 at 6:07 AM
    #67
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Engine management does not “learn” it has no artificial intelligence it only “adapts” to a lookup table it can’t and won’t respond to any thing out of the range that is programmed into it. Until I am proven different I will say it will not test the waters and inch the timing up because higher timing tends to increase the NOX emissions. It will adapt to engine knock and retard the timing from the preset standard of 87 octane to eliminate the knock so in the case of extreme usage high test will help because the timing will not retard due to knock but the effect will be minimal and only if it detects a knock. Once the knock goes away it will then adapt back to the preset timing. You can teach an old dog new tricks so if any one has "manufactures" information about engine management adaptation I’m all ears there is a lot of wives tails and speculation on this and I would like to hear from the horses mouth.
  8. Apr 2, 2012 at 7:42 AM
    #68
    Darth_Yota
    Darth_Yota I intend to live forever, or die trying.
    Cam-moron
    Somewhere USA
    Dented, broken-down ‘08 hoopty
    Ain’t good’nuff for insta
    Workman should change name to Simon. Unless Simon is already workman's real name...
    Anyway, I don't like this ethanol nonsense.
  9. Apr 2, 2012 at 8:25 AM
    #69
    Creemore
    Creemore Well-Known Member
    Toronto
    Magnetic grey TRD Sport/leather pkg.
    I'm never sure what 'proof' will work in a forum like this. I've even seen people dismiss dyno charts, so the following comment is probably only good for bumping the thread. But here goes...
    I think you're correct that DME's choose from among options that are within a set of parameters. However, it's not a correct assumption that the default maps for every engine are for 87 octane. For a cars that are, premium is a waste of money. But based on Toyota's own numbers for this engine, my suspicion is that its default map is for 91 octane, which means that it's running in an adaptive state on 87. This is, of course, absolutely unprovable, but 12 extra ft/lbs of torque for running premium certainly points that way.
    And, again, every engine is different in this regard. I've owned cars (all German, interestingly) that ran so differently on regular and premium that you could tell which was in it just by looking at the soot in the tailpipe. And I've had others (mostly Japanese, ironically), where even the most hopeful butt dyno could detect zip.
    That's what makes this debate so endless on enthusiast forums. Nobody is ever proven right or wrong. :D
  10. Apr 3, 2012 at 4:46 AM
    #70
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    I guess my point is that the engine was sold as using 87 and some one said that Toyota has dropped the higher figures (I'll have to look at my manual) that leads me to believe that they like other truck makers love to spout off about their HP. The extra figures are a small percentage the actual gains are pretty slim. I have tried in vane to find info on how adaptive the systems are but you maybe right they may start high and go down and there testing was done with the slightly higher timing. The figures I'v seen for the gains of high test still have not convinced me of any savings for the extra expense of 97. To be fair to the OP his question has been clouded with speculation while his answer was simple No it won't hurt to run high test in any thing except maybe your pocket.
  11. Apr 3, 2012 at 6:14 AM
    #71
    Schwinn
    Schwinn Well-Known Member
    Jamie
    Georgina, ON
    2012 TRD Sport with Trail Teams package
    I've always wondered what the difference is between Canadian and US premium. The guys who I bought my Mustang parts from (and now Tacoma goodies) build race cars, and were telling me if I don't want to run 94, I could back down to 91, because ours is different. And on the Diablo site, the company that makes my programmer, they, too, say you can run a lowere octane. I've heard this countless times all over the place. I also know years ago I had a car that demanded premium, and when I filled up in the US, I could see a difference in the way it ran. So, is ours metric octane or something?
  12. Apr 3, 2012 at 6:34 AM
    #72
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Sort of. Octane ratings in the US are (RON+MON)/2, while most places outside the US are RON. If you're not up on those terms, find your favorite search engine and read to your heart's content :D.
  13. Apr 3, 2012 at 8:33 AM
    #73
    Creemore
    Toronto
    Not sure, but the only 94 available here achieves its high octane rating by having a higher ethanol content. So they can technically advertise the high number, but it doesn't mean your engine is going to see it that way.
    A few years ago, I had a BMW that I would run Sunoco Ultra 94 in exclusively. The exhaust pipe was always sooty black inside, which I never questioned. Eventually, I upgraded the exhaust, and my tuner told me that this particular car's knock sensor reacted to the 'sound' of ethanol combustion as though it was pre-detonation. He told me to switch back to 91 without ethanol. I did after I got my new exhaust system, and the tailpipe stayed clean for the next four years I had the car. One car, one story, believe it or don't. But it was a lesson in how there's more to fuel than octane, just as there's more to performance than horsepower.
  14. Apr 3, 2012 at 10:41 AM
    #74
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Just filled with premium cheveron at $4.16/gal vs $3.88/gas 87 oct. Wouldn't want it any other way.
  15. Apr 3, 2012 at 10:57 AM
    #75
    WheelinJ91
    Edmonton,AB
    2012 TRD DCSB
    haha yeah the diffrence in price is so small in reality that in can be personal choice as long as it doesnt hurt anyhting, and the conclusion is that it will not. :evil:
  16. Apr 3, 2012 at 12:35 PM
    #76
    Richard Cranium
    Richard Cranium The lice...they hate the sugar
    Ted
    Omaha, NE
    2013 Raven FR-S
    Forever sideways and smiling :D
    FWIW...I've run nothing but 89 w/10% ethanol the past year. I've got little/no knock and pretty decent MPG numbers. Spent the first 3 months I had the truck experimenting with dif octanes (87/89/91, a month each) and couldn't get a noticeable difference in performance/mileage so I stuck with the cheapest. Price this morning is $3.65 for 89w/10%eth vs $4.01 for premium. Hit my best MPG/tank last week...379.9mi 19.9mpg w/2.05gal remaining.
    Feel free to check my Fuelly in my sig...I'm calling ambient temps as the biggest factor as mentioned already by Chris.
  17. Apr 4, 2012 at 5:13 AM
    #77
    Creemore
    Toronto
    +1
  18. Apr 4, 2012 at 11:11 AM
    #78
    tacom08
    tacom08 Well-Known Member
    Isaac
    Simpsonville, SC
    08 DCSB 2WD Rugged Trail Edition
    Flowmaster Super 10, K&N CAI, bumpers, LED taillights
    Premium on V6
