Premium fuel with the 2.7?
Discussion in '4 Cylinder' started by 0311K1LL, Jul 11, 2016.
  1. Jul 13, 2016 at 11:26 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    I run 91 octane " premium" in my 02 double cab just because I'm running a supercharger and need the higher octane
  2. Aug 29, 2016 at 3:27 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Any ideas on how many tanks it takes before it adapts to the higher octane fuel?
  3. Aug 29, 2016 at 3:44 PM
    sogafarm
    sogafarm Well-Known Member
    GA
    2012 tacoma reg cab spruce mica
    31" Falkon wild peak AT's, fat bobs lift, mud accents
    I use non ethanol from a small commercial tank and it makes a difference in my 2.7 with better start up and smoother running. Mpg's are slightly better than when I buy from a retailer. I got the best mpg when I was in the mountains in Colorado last summer using 85 octane. Go figure?
    Ritchie likes this.
  4. Aug 29, 2016 at 3:45 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    I may be wrong, but I believe at higher altitude you need less octane.
  5. Aug 29, 2016 at 3:50 PM
    sogafarm
    GA
    Must be. I was up in vail at around 8000 ft and all they have is 85 for the first grade. Pushed the 2.7 pretty hard to maintain speed up the passes, so wasn't babying it. Got 23mpg average. I'm lucky to get 18 here in GA at 400 ft.
  6. Aug 29, 2016 at 9:56 PM
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    I felt like I saw a difference 1-2 maybe 3 full tanks later. It never felt "bad" in between just felt better by the end. Now I, as many, would claim I can feel the difference.
    BassAckwards[QUOTED] likes this.
  7. Sep 6, 2016 at 7:08 AM
    snefo
    snefo Well-Known Member
    Just to be fair, I tried 91 octane ethanol free this time. About 5 gallons on top of 5 gallons on 87 octane e10 and my fuel economy jumped up way more than expected. (Looking at my Ultragauge) I may try a full tank to see how it goes.
  8. Sep 15, 2016 at 8:49 AM
    Indy
    Indy Master of all I survey.
    Yep. I lived at 6500' 91 was the highest you would ever see and you can run high compression at 85. Now I'm at sea level, 91 is mid grade and 94 is everywhere.
    NAAC3TACO[QUOTED] likes this.
  9. Sep 19, 2016 at 8:27 PM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I've got a friend of mine that's been hauling gas for over 20 years. He says if your going to run a cheaper brand of gas always get premium because it is more refined and has less garbage in it. I'd say all premium is more refined with less garbage in it. But then, that's just an opinion since I'm no fuels engineer. My 2.7 seems to run better on 91. Mileage only barely increases but it just seems to run smoother and has better throttle response. The improvement is so slight though that is is almost not even there. I do run premium in mine in the summer. 91 octane. In the winter I was running 87 last winter and will probably do it again this winter. I'm also at 7000 feet so 87 is really all I should be running but the 91 does "seem" to improve the way it runs and I "think" it's a little cleaner than the regular.
  10. Sep 19, 2016 at 8:34 PM
    TRVLR500
    Wyoming
    One tank probably isn't enough to let the computer re calibrate for the higher octane.
  11. Sep 22, 2016 at 12:08 PM
    tgear.shead
    tgear.shead Well-Known Member
    That isn't entirely true. Combustion is a CHAIN reaction. In order for the reaction to continue, the unburnt fuel needs to be heated enough to ignite. Higher octane means that it ignites at a higher temperature, which takes slightly longer to achieve since it doesn't burn any hotter. However, that isn't the objective of the higher octane, it is a side-effect.
    Um, not quite.
    The primary difference between preignition and detonation is WHEN it occurs.
    Pre-ignition occurs BEFORE the spark (hence "pre"), triggered by a point source of heat somewhere within the combustion chamber. Aka, a "hot spot".
    Detonation occurs AFTER the spark, triggered by the pressure waves that ripple through the air/fuel mixture AHEAD of the flame front.
    Now if you think about it, you simply CANNOT stop preignition through retarding the ignition timing, because the ignition happens BEFORE the spark even happens!
    But you CAN stop detonation, because detonation is triggered *by* the ignition.
    So imagine this; your piston reaches TDC, the ignition sparks, the fuel begins burning. The pressure wave instantly blasts through the entire combustion chamber AHEAD of the flame front, somewhere ahead of the flame front, a compression wave triggers a second point of ignition. Now you have two flame fronts travelling towards each other. When these flame fronts collide, that is when you get a "ping". Now what you do to stop this from happening, is you wait a tiny bit longer until the piston starts its trip back down and the pressure is slightly reduced. NOW when the ignition sparks, the pressure isn't high enough for the compression waves to cause a detonation.
    Note that dieseling can only be caused by preignition.
  12. Sep 22, 2016 at 12:23 PM
    tgear.shead
    At higher *elevation*, you *don't need as high* octane. Subtle, but important distinction.
  13. Sep 22, 2016 at 12:25 PM
    tgear.shead
    The difference between 87 and whatever is higher than it, has nothing to do with refinement. They ADD a combustion inhibitor to the 87 to turn it into whatever.
  14. Sep 23, 2016 at 8:24 PM
    TRVLR500
    Wyoming
    That's just what my buddy told me and it's probably hearsay. I do know that they add Butane to increase the octane when they make premium. How that works I have no idea but I know that for a fact since I hauled propane and butane for a few years. They also add butane to propane in the summer time for use as a automibile fuel.
  15. Dec 10, 2016 at 11:48 AM
    #35
    Gun guy
    Gun guy Tacoma Fanboy
    05 Trd Off road AC MT & 08 Tacoma 2.7 AC MT
    I put almost 300,000 miles on a trd off road using the cheapest gas I could buy every tank, never had an issue.
    Pretty sure these engines and most modern engines are designed to run the cheap stuff.
  16. Dec 10, 2016 at 8:32 PM
    #36
    TRVLR500
    Wyoming
    I suspect you're probably right.
  17. Dec 20, 2016 at 7:56 AM
    #37
    JL911
    JL911 Psshh
    PA
    5 spd 4 bngr
    I've been tracking my fuel mileage since I bought the truck two years ago. I almost always run mid-grade fuel (89 octane).
    I have run 87 octane for weeks at a time as an experiment to see if the higher octane actually made any difference.
    I generally get 2 mpg more using mid-grade over regular.
  18. Dec 20, 2016 at 2:46 PM
    #38
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Yes most modern gasoline engines are designed to burn 87 octane "regular" grade, which might be 85 octane at elevation. Point being that premium is not required.
    I'm happy to hear of the mileage and (assuming) good performance you got from plain old regular gas. And like you, I'll probably get minimum 300k miles burning regular the entire time :)
    Indy said the manufactuer's minimum octane requirements have a buffer built in, which is true. If I fill up with 85 octane (at elevation) and then drive downhill to a much lower elevation where regular grade is sold as 87 octane, my engine is not going to explode running the 85. Whether it's ARCO, Safeway, Rotten Robbie, Farmer John's Gas & Go... these 2.7 engines will burn just about any gas, crap or otherwise. I even had a couple gallons of very old yellowed gasoline from a dirt bike I hadn't ridden since April. Drained the bike and poured it into the Tacoma (which had about 1/4 tank) and it ran just fine. Sure it wasn't much, I'm just saying it made literally zero difference in the engine's normal operation. Love it!
  19. Dec 29, 2016 at 6:26 PM
    #39
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    My truck may just be odd. I loose about 5 MPG with 87. Using premium (93) or mid (89) I see no difference in performance or MPG so I stick to mid grade. Borescope inspection recently showed a very clean combustion chamber and the back of the valves were pristine after 194k.
    cryptolime likes this.
  20. Jan 28, 2017 at 4:51 PM
    #40
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    I'm not an expert, but wouldnt higher octane fuel allow timing to be advanced further than 87 which would equal more power.
    I live in the mountains and tried 91 and was amazed that it pulled the 7* grade and actually accelerated, normally I would slowly loose speed till I got to the top.
    Ran 91 for 10 tanks then thought maybe it's just me, and switched back to 87. Truck went right back to loosing speed on the grade.
    I've been running 91 ever since. Mpg has been unaffected, and flat land driving is pretty much the same.
    Maybe on the 3rd gen 2.7 it is different. But I'm pulling 35's right now, and it's not ideal with stock gearing, but I keep up with traffic no problem.
