Premium fuel with the 2.7?
Discussion in '4 Cylinder' started by 0311K1LL, Jul 11, 2016.
  1. Mar 17, 2017 at 8:09 PM
    #81
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
  2. Mar 19, 2017 at 5:42 AM
    #82
    Colgan
    Colgan Well-Known Member
    Just fueled up with 91 non ethanol and see what mpg I get. Last fill up with low grade 87 was 18 mpg city driving. Also removed the secondary air filter that had 150k miles on it.... truck seems to have a Lil more pep between the better gas and better air flow
    Ceedub53 likes this.
  3. Mar 28, 2017 at 6:05 PM
    #83
    2.7taco
    Texas
    Personally never saw an improvement removing the secondary charcoal filter. Mine tore so I removed it. No changes for me in performance or MPG.
  4. Mar 28, 2017 at 6:23 PM
    #84
    Colgan
    Throttle response seems a little crisper. Only issue I'm having is a slight low idle/hesitation. I'm on my second tank of 91 non ethanol and still does it a little bit.
  5. Apr 26, 2017 at 9:04 PM
    #85
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I've been running 87 octane Deathanol free all winter. Mileage stayed about the same. I'll switch to 91 Deathanol free soon when it gets warmer. I just got skinnier tires so that will probably help the mileage. I have always noticed that, for whatever reason, my Taco with the 2.7 just "seemed" to run better with 91 octane and the mileage "seemed" to be a little better. It was really hard to put a finger on it. I live at over 6000 ft so it would seem that 91 octane would make no difference at this elevation but it does while at the same time being almost in-discernible. I idle my truck so much that it's hard to tell what the real mpg is from week to week.
    Personally I don't care because I need gas to go where I want to go and the cost really means nothing when it comes right down to it. It's a necessity.
    Ritchie likes this.
  6. Jun 5, 2018 at 1:17 PM
    #86
    TwistedKicker22
    TwistedKicker22 Well-Known Member
    Manuel
    2015 Tacoma 2.7 5 Lug
    K&N. Magna Flow
    I got 40,000 miles on my 2.7L 2015.. I have been using premium 93 since I took it out of the dealership.. That 87 Octane is not touching my truck lol.. A mechanic explained to me in details.. Putting cheaper gas makes the motor run a little more because It's asking for more when you hit the gas.. Using premium.. The motor runs more freely if it makes any sense.. Meaning once you tap the gas the vehicle just goes with ease.. Depending how you drive and what size tires you got on your truck is another story ..Fuel treatment I go with Mystery oil or (Automatic Transmission fluid) yup. Old school.. (NONE Synthetic) Any regular transmission fluid no matter what type as long as It's NOT synthetic It's good.. I have been doing it since my truck had 10,000 miles.. Remember .. Automatic transmission fluid lubricates the system also.. So if you put a little too much, nothing happens..
  7. Jun 6, 2018 at 7:49 AM
    #87
    Gasturbine
    Gasturbine Well-Known Member
    Central Ohio
    2011 Regular Cab 2.7l 5-speed 4WD
    32" BFG KO tires on MT rims, Front lifted 2", N-Fab 12,000lb front pull point w/10,000lb red clevis, mud flap delete, tail pipe delete, 20" LED light bar, 2 Hella 500s, N-Fab light bar mount, tinted windows.
    Then you are throwing away money.
    Apparently, not a good one, who knows very little.
    Truly no disrespect, but that is utter hogwash. I have a degree in chemical engineering, and worked in the refinement field in the '80s. People have many misconceptions about the Research Octane Number (RON) in petroleum.
    First, the naming nomenclature. Calling fuel "regular" and "premium" is misleading. It make one sound superior to the other, and it is not. Regular fuel is just as clean and pure as premium is. The refinement process is the same, with the exception of octane level which is a hydrocarbon and an alkane mix, with the chemical formula C₈H₁₈, and the condensed structural formula CH₃(CH₂)₆CH₃.
    This is added to premium fuel to slow the burning process down (thats correct, "SLOW") to prevent detonation. The higher the RON in fuel, an engine manufacturer can safely make higher compression engines, and add more timing, in an effort to make more power. (better performance).
    Putting premium fuel in an engine designed for regular is not only a waste of money, but potentially can reduce performance because of the slower burn (incomplete) rate.
    Now, there are engine tunes you can program in many ECMs, and these tunes will adjust your timing based on the planed RON you intend to use. In fact, many of these tunes are named for the octane they are deigned for like "92" or "93".
    So, in a nut shell, unless modified, use the fuel recommended my the manufacturer. You are NOT getting ANY benefits for doing so, and are wasting money, pure and simple.
    Our stock 2.7s are designed to run on 87 octane, use it.
    LeakyAC, vern650, gavia and 4 others like this.
  8. Jun 6, 2018 at 8:02 AM
    #88
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    Literally none of this is accurate.
    Higher octane fuel is more stable under pressure and during combustion. Higher performance engines require this in order to have stable fuel in a high compression motor. The 4L is a high compression motor (not a turbo of course but high compression none the less)
    LeakyAC likes this.
  9. Jun 6, 2018 at 12:44 PM
    #89
    Gasturbine
    Central Ohio
    Good post, but just to clarify, combustion ratio and boost are 2 different things. In fact, it is common engine building practice to LOWER the combustion ratio when applying forced induction verses normally aspirated engines, however, many after market forced induction "kits", do not "include" requiring lowering that ratio, and are able to work well with good EMC programming, and can still offer good/great performance gains.
    Im not trying to pat myself on my own back here, but me and my father have built many high performance engines over the years (mostly for boats). Mostly American big blocks, with forced induction of various types, including roots style (6-71/8-71), centrifugal units, and of course turbos, and know a little bit about race gas and octane.
    Just trying share some long earned experience/knowledge, thats all. :thumbsup:
    Peace!
  10. Jun 7, 2018 at 10:38 AM
    #90
    digitaLbraVo
    I see the distinction you're making, yeah you're square on.
    Gasturbine[QUOTED] likes this.
  11. Jun 10, 2018 at 7:59 AM
    #91
    Woofer2609
    Woofer2609 Getting better all the time.
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    Good read. Thanks!
    Porsche, who have a long history of forced induction, have a recent patent on a variable compression ratio engine (higher compression before the turbo spools up). Be interesting to see if it hits production.
    I'm unsure of where this myth that higher octane (unless it is non ethanol) is a "better" gasline came from. I file it between "My car runs better after changing the oil" and " The problem seems to have gone away/fixed itself" in my filing cabinet of WTF?
    Of course there is truth to the fact that a vacuumed and washed truck runs better...right?
    Edit: obviously use whatever octane the manufacturer asks for in the literature provided.
  12. Jun 10, 2018 at 8:05 AM
    #92
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    91 is the required minimum in my 2.7 :D:burnrubber:
  13. Jun 10, 2018 at 8:09 AM
    #93
    Woofer2609
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    Edited my post to reflect manufacturers recommendation. 94 octane in my wr250x FTW:bikewheelie2:
  14. Jun 10, 2018 at 2:36 PM
    #94
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    i run 89, as i get a slight bit of knocking or "kick" when i run 87 at lower rpms under load.
  15. Jun 14, 2018 at 5:37 AM
    #95
    dirtdigginjoe
    dirtdigginjoe Resident meth-head
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    Always ran 93 in my truck, even before I turbo'd it. Every so often (~6mo.) I'll Seafoam it, and use Amsoil P.I additive every 2-3 months.
    Never had an issue with hesitation, pinging, or knock...even with the turbo.
  16. Jun 23, 2018 at 7:54 AM
    #96
    casey2012
    casey2012 Well-Known Member
    mark
    yota
    none
    no difference i use none ethanole
  17. Jun 9, 2023 at 11:55 AM
    #97
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    i get about 20 mpg with 87 and 24.5-25.5 with 93. reset all the learned values between switching octanes so I wouldn't have to go through 5 tanks before noticing a difference.
  18. Jun 11, 2023 at 7:20 PM
    #98
    Ceedub53
    Ceedub53 Active Member
    NW Arkansas
    2006 Tacoma Prerunner Access Cab
    Recently switched to 91 octane/no ethanol. Engine seems to idle much smoother and has more "umph" going up and down the hills here in the Ozarks/NW Arkansas. Haven't calculated MPG yet, waiting a few more weeks after running multiple tank fill ups.
    JGO likes this.
  19. Jun 12, 2023 at 4:21 AM
    #99
    JGO
    JGO Well-Known Member
    South Central Kentucky
    '14, 4 Cyl, A/T, Silver A/C
    I use the alcohol free in my tractor and small engines. I paid $4.87/gallon last week. Regular gas (Shell) here was $3.19/gallon. What is yours costing you?
    Ceedub53[QUOTED] likes this.
  20. Jun 12, 2023 at 9:12 AM
    #100
    Ceedub53
    NW Arkansas
    Premium 91 with no ethanol about $3.99 gal (Phillips 66/NW Arkansas). Regular 87 runs around $3.04 (Walmart).
