Premium fuel?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Qexler, Mar 20, 2017.
  1. Apr 4, 2017 at 12:10 PM
    #201
    2324fire
    2324fire Active Member
    2016 TRD OFF ROAD
    3" lift, 33" nitto trail grappler rubbers, strobe lights, sirens.
    Valero is the brand of fuel that at one time agreed to pay for engine rebuilds if you kept every fuel receipt.
    shakerhood[QUOTED] likes this.
  2. Apr 4, 2017 at 12:11 PM
    #202
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Don't like the sound of that, lol.
  3. Apr 4, 2017 at 12:13 PM
    #203
    2324fire
    2016 TRD OFF ROAD
    I didnt either and of course they didnt give details. That is why i use it only on a last resort situation.
    shakerhood likes this.
  4. Apr 4, 2017 at 12:13 PM
    #204
    Dannyblues
    Dannyblues Well-Known Member
    Danny
    New Milford Connecticut
    2016 Tacoma TRD sport 4x4 double cab black
    weather tech mats, mud flaps, black side rail step, cargo bed liner, roll up cargo bed cover, wheel locks towing package
    I get only 1 mpg more with Shell nitro premium 93 maybe 2 more mpg? Maybe. But I use the shell premium 93 toptier gas for its superior detergency. The minimal extra mpg is just a minor plus. Dannyblues
  5. Apr 26, 2017 at 9:33 AM
    #205
    Dannyblues
    Danny
    That's something I was never aware of! Overheating an internal tank fuel pump. Very interesting
    I was wondering why I couldn't locate the mechanical fuel pump on the front passenger side of the engine!
    I'm very old and could repair a 1957 Chevy v8 in the dark - asleep- with one hand tied behind my back but some of these threads have my brain reeling.
    I do appreciate learning so thanks
    Dannyblues
    Riding Dirty and nDub[QUOTED] like this.
  6. Mar 21, 2018 at 2:10 PM
    #206
    LAGUNABZRD
    LAGUNABZRD Member
    Robert
    2017 Tacoma TRD Off-Road
    I initially had the same question of what octane to use in the new 3.5 motor since the compression ratio is 11.8:1
    Considering that variable valve timing and ignition timing can adapt to take care of pre ignition or detonation to a certain degree I think the fact that
    the motor runs the Atkinson cycle that the actual compression ratio may be lower than advertised because I doubt they are taking the partially open valve
    on the compression stroke in to consideration adding total volume and reducing the actual ratio through what's actually pushed back in to the intake before the valve closes. My guess is the 11.8:1 is actually if the intake valve closed like a normal Otto cycle engine before the piston starts its compression stroke.
  7. Mar 21, 2018 at 6:43 PM
    #207
    bacon_st
    bacon_st Well-Known Member
    San Diego
    16' Taco TRD sport
    I was once in the group that it made a difference. Mostly because I bought into their marketing that higher octane 91 Shell gas had additive detergents that keep your engine and combustion chamber clean etc. But each time I gave my truck for service, I took every opportunity i got to chat w. a Toyota mechanic and they all said just regular fuel is all I need.
    phsycle and MOC221_ like this.
  8. Mar 21, 2018 at 6:44 PM
    #208
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Truth.
    I HAVE to run 91 now though :D
  9. Mar 21, 2018 at 6:52 PM
    #209
    The-Stig
    The-Stig Well-Known Member
    Kyle
    2017 TRD Off Road / Access Cab / Long Bed
    The most important thing is to use quality gas. If you see the tanker truck at the gas station, do not fill gas there. When they refill the tanks, it can stir up all kinds of gunk at the bottom of the tanks. Speaking of gunk, try not to run your trucks fuel tank too low, or you may suck up whatever is settled to the bottom of your gas tank. I try to just fill up with regular Shell gas, I've never had a problem with doing that.
  10. Mar 21, 2018 at 8:13 PM
    #210
    StreetTaco82
    StreetTaco82 Well-Known Member
    TRD OR DCSB
    Yes! Me too.
  11. Mar 21, 2018 at 10:41 PM
    #211
    FrayAdjacent
    FrayAdjacent Well-Known Member
    Matthew
    Austin, TX
    2017 Tacoma SR5 4x4
    First response nails it. You do not gain anything from using higher octane fuel than your engine is tuned for. Depending on the brand, you may get some detergents and additives, but you won't get more power.
    phsycle likes this.
  12. Mar 22, 2018 at 1:55 AM
    #212
    jtifm
    jtifm Well-Known Member
    2017 TRDORDCSB
    Recently switched to base grade as I am over 5,000 ft elevation. Pre-detonation has not been a problem yet.
    phsycle likes this.
  13. Mar 22, 2018 at 1:57 AM
    #213
    FT17
    FT17 Active Member
    17’ Tacoma TRD pro
    The sought after "benefit" doesn't outweigh the added cost of fuel, it' negligible at best.
    phsycle likes this.
  14. Mar 22, 2018 at 5:41 AM
    #214
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    A couple of old myths right there.
    There is very little gunk at the bottom of gas station tanks, and what does get in is filtered out just before the dispensing hose.
    There is also very little gunk getting in your tank in the first place, and the fuel pickup is always at the bottom of the tank so anything in your tank gets sucked up whether the tank is full or empty.
    I'll add running the tank low isn't bad on the fuel pump either, it is cooled and lubricated by the gasoline that flows through the pump not that the gas surrounding it. Now run your fuel tank dry and leave the ignition on run and you will burn up a pump fast. Otherwise, no worries.
    evolution_sfv likes this.
