Premium gas
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Signatureinc, May 17, 2022.
  1. May 17, 2022 at 2:06 PM
    Signatureinc
    Signatureinc [OP] Well-Known Member
    Doug
    Flat Land, Ontario
    2019 TRD OR Access Cab
    Hey you guys, anybody notice a significant difference using premium gas and does it help when A/C is running? Might just try it but with the price of gas up here…
  2. May 17, 2022 at 2:10 PM
    saint277
    saint277 Vigilo Confido
    need an ecu tune to see any benefit.
  3. May 17, 2022 at 2:12 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    My AC runs all year (Arizona desert). Feedback will likely vary based on who you ask. Personally, I tried premium fuel fully stock and noticed nothing. I tried the premium octane OV tune after running the 87 octane OV tune and noticed nothing except worse mpg. Happiest with the 87 octane OV tune. Throttle response feels best with the 87 octane tune to me as well.
    I've noticed it helping on other cars, but not on this. Was worth the $10/tank extra to test but didn't feel any benefits from it. My daily Scion tC, on the other hand, felt much better with 91 even before tuning for it.
  4. May 17, 2022 at 2:14 PM
    kauaihunter
    kauaihunter Well-Known Member
    Jay
    2021 SR Dbl Cab 4x4 and 2017 SR5 Dbl Cab 2wd
    Kicker speaker upgrade Tint Trimmed air dam Taco Tunes amp and sub 275/70/17 Wildpeaks
    Save your money.
  5. May 17, 2022 at 2:18 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
  6. May 17, 2022 at 2:21 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Don't waste your money. You will not see the difference you think you will...
    https://youtu.be/ryqyTPfNj1Q
  7. May 17, 2022 at 5:18 PM
    Signatureinc
    Doug
    Flat Land, Ontario
    Thanks you guys I also think premium most times is a pile of and many consumers can be suckers !!
  8. May 17, 2022 at 5:48 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    It is needed in some vehicles. The Tacoma does not benefit at all.
    VanGo3, BSFord, MGMoverland and 3 others like this.
  9. May 17, 2022 at 5:50 PM
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    +25 hp with cat back and CAI installed
    davidstacoma likes this.
  10. May 17, 2022 at 5:57 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    The Tacoma can definitely benefit from premium fuel. The 2GR-FKS engine was initially made to run on premium, but the stock tune in the taco takes some of the benefits away. Getting a tune can bring back those perks by a significant (notional) amount.
    With that being said, the stock tune knocks quite a bit, even to the point it's mentioned in the manual. Running premium octane without a custom tune can eliminate some of that, but won't remove it all. Some users have also reported premium octane does drive more smooth. Is it enough to justify the cost? That's up to the driver.
  11. May 17, 2022 at 6:00 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Isn't premium E0 in Canada?
    Try it.
    stealthmode likes this.
  12. May 17, 2022 at 6:04 PM
    venezian
    venezian Well-Known Member
    Los Angeles
    2022 7545E
    More like +25 on the cool sounds scale.
    Namdis, Vmax540, davidstacoma and 2 others like this.
  13. May 17, 2022 at 6:12 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 1999 Corvette 6MT
    Building a Broja
    This is why I run 93, even at additional cost. While I understand the manual states it's normal / fine, I really, really dislike hearing the active pinging when I'm driving. My 2013 with the 4.0L would ping like crazy too. Toyota actually released a TSB to solve that but I could never get the dealer to apply it for me.
    Yes, my experience is anecdotal at best, but I can absolutely attest to what you've said.
    chiefcrunchy, VaToy, Junkhead and 3 others like this.
  14. May 17, 2022 at 6:45 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Most newer vehicles use computers to tweak engine performance as you drive. Running premium CAN improve performance even though the engine is designed for 87 octane. The difference is small, and I observed a very slight improvement in fuel mileage. Not enough to offset the additional cost, but it does ease the pain some.
    I'd suggest giving it a try just to see for yourself. Keep detailed records, and don't give up after just one tank. I'm not one to run my tank down much below 1/4 tank and for me it would be the 3rd fill-up with premium before I would have nothing but premium in my tank.
    What I observed is just enough power gain to reduce the amount of downshifting when driving in hilly conditions. Particularly when towing. Based on my research running premium will also help reduce engine and transmission temps when towing. Even though the truck may be rated for 87 octane
    And the newer the vehicle the greater the gains. A 3rd gen should see more of an improvement than my 2nd gen truck.
    Another observation concerning buying fuel. Virtually all stations where I live only advertise regular fuel prices. I found that most of the stations with the lowest advertised regular fuel, had the highest prices on premium. Often $.70 to $.80 per gallon higher. But by shopping around there were several stations where I could get premium for $50/gallon more than the cheapest regular fuel.
  15. May 17, 2022 at 6:47 PM
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    My Tacoma doesn’t run any better that I can tell with Super. Got gas today and reg is $4.65 and Super is $5.25/gal. So since I can’t notice any difference, Im going to use the most economical fuel.
    My other car that requires 91, absolutely and knocks/pings when I use Regular, so thats where I stick with Super.
    MGMoverland, Mr-Paul and venezian like this.
  16. May 17, 2022 at 7:27 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    the ecu will advance the timing a lot more on higher octane fuel. when i go back to 87, the timing is retarded.
  17. May 17, 2022 at 7:39 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Higher octane fuels are for higher compression engines. It will not give you any sort of benefit in these engines and you'll just be throwing away more money (especially these days).
    BSFord, ToyoTaco25 and Taco_mike73 like this.
  18. May 17, 2022 at 7:53 PM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    not true, the ecu will advance/retard timing depending on the knock-resistance of the fuel
  19. May 17, 2022 at 7:58 PM
    RedWings44
    Michigan
    Your ECU is designed to adjust to many different conditions. There have been many demonstrations and studies which show there is no benefit to running a higher octane in an engine not designed to run said higher octane.
    AtomAnt and ToyoTaco25 like this.
  20. May 17, 2022 at 8:53 PM
    Beer Snob
    Beer Snob Well-Known Member
    Eric
    Windsor, CO
    2016 MGM DCTRDOR
    I haven’t noticed much difference whatsoever when switching between 85 87 or 92 octane.
    Where I do notice a difference is when I switch to ethanol free. I usually live in the 17.5-17.9 mpg world but when using ethanol free fuel I get around 19-19.5
