Premium gas
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Signatureinc, May 17, 2022.
  1. May 25, 2022 at 1:09 PM
    #41
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    19-20 mpg? Impossible.
    You added a bunch of unsprung weight, rolling resistance and you are lifted 6”. Can’t argue with physics.
    ToyoTaco25, zoo truck and hiPSI like this.
  2. May 25, 2022 at 1:10 PM
    #42
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    nah, premium fuel does make a noticeable difference, especially with heavy loads. just not worth the price for most people
    CusterFan likes this.
  3. May 25, 2022 at 1:12 PM
    #43
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    I am tuned and running 93. I’m
    A bit heavy too, about 400 pounds of extra weight plus E load skinny 33s and 2” lift. If I drive very conservatively, I can get stock MPGs.
    The dude is lifted 6”, got 35s, and has got about 800 pounds of extra weight. Higher octane is great but it’s not magic. Physics man.
  4. May 25, 2022 at 3:17 PM
    #44
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    he must be driving really slow
    Junkhead likes this.
  5. May 25, 2022 at 3:19 PM
    #45
    JSmith501
    JSmith501 Well-Known Member
    San Antonio, TX
    2017 Off Road 4x4
    I run non-ethanol gas, but that is mostly because i hardly drive. I just started doing this, so i can report if i see any improvements.
    CusterFan and Junkhead like this.
  6. May 25, 2022 at 3:21 PM
    #46
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    You must never go below 20 or over 55, which is the only way you possibly could do what you say. Math is hard.
    ToyoTaco25 and Junkhead like this.
  7. May 25, 2022 at 3:36 PM
    #47
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    And downhill with a tailwind.:)
    ToyoTaco25 likes this.
  8. May 25, 2022 at 6:19 PM
    #48
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    If you run inside air with the a/c on with my truck it builds up mold in the evaporator core box and blows fresh cow shit stank out the vents. Not good to breathe.
  9. May 25, 2022 at 6:31 PM
    #49
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    3/4 of the responses in this thread are incorrect. Probably yours. Not worth my time to get into arguments though. :rolleyes:
    :anonymous:
  10. May 25, 2022 at 6:39 PM
    #50
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
  11. May 25, 2022 at 7:36 PM
    #51
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    as i stand by mine.
  12. May 25, 2022 at 8:35 PM
    #52
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    I try to fill up when I get to a quarter of a tank. Filled up today with 87 Octane. About 15 gallons was $75 dollars. Pretty soon my fill up dollar amount will be a larger number than my Octane.
  13. May 26, 2022 at 5:18 AM
    #53
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Question you should ask yourself why is my truck pinging. Its either crummy low octane fuel your using that isn't what its claimed to be, or something isn't right with the truck. Even with 87 octane i can not make my 3.5 ping under any condition. Your getting ripoff if you need to run premium all the time.
  14. May 26, 2022 at 5:27 AM
    #54
    zoo truck
    None
    I had a gen1 tundra that use to tow an enclosed trailer with 2 sleds, plus one in the trucks bed to canada. I ran premium at times in that 4.7 v8 vs 87 octane just to see the difference....yeah there's more btu's in higher octane fuel pulling that load, but the actual mileage results were only minor gains using premium.
  15. May 26, 2022 at 8:45 AM
    #55
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    The higher the octane, the slower the burn. That’s why high compression engines need it, won’t go off just touching the hot spots in the combustion chamber, ie, pre ignition, ie, pinging.
    zoo truck and cryptolime like this.
  16. May 26, 2022 at 8:58 AM
    #56
    S2KON2
    S2KON2 Well-Known Member
    So Cal (SFV)
    +1 on this.
    Stock with 91 was meh, not worth it.
    Tuned (not for 91) with 91 was not meh, and definitely worth it, as far as smoothing out everything. In terms of MPG improvement over 87, negligible to me.
    ktbell444[QUOTED] likes this.
  17. May 26, 2022 at 4:22 PM
    #57
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Fuelly don't lie bro
  18. May 26, 2022 at 4:28 PM
    #58
    shotgunbilly420
    I use gps on my hu to track mileage. My od is off a bit
  19. May 26, 2022 at 4:31 PM
    #59
    saint277
    saint277 Vigilo Confido
    Theres actually slightly less btus per gallon in premium fuel, it has more additives, more additives means less gasoline, less gasoline means less btus. General rule is the more refined a petroleum product is the less btus it has per unit of volume, that why diesel has more its much less refined.
  20. May 26, 2022 at 4:31 PM
    #60
    shotgunbilly420
    Psi when tires are warm
