Premium Gas
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wingspar, Jul 20, 2022.
  1. Jul 20, 2022 at 5:49 PM
    wingspar
    wingspar [OP] Well-Known Member
    Oregon
    2011 Tacoma 4x4 Access Cab
    I found a thread on this, but it was for the Gen3's, so decided to start a thread here. 2011 Tacoma I bought brand new in 2011. It has the 4 cylinder engine. I’ve always run regular gas in it, but there is no regular gas in this small town right now. Is it ok to run premium gas in it? The tank is about half full and I try to never let it get below ½ tank as I do most of my driving in very remote areas with no cell service.
  2. Jul 20, 2022 at 5:50 PM
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    Yes it will be fine and cause no issues
  3. Jul 20, 2022 at 5:50 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    No harm, just wasted money.
    6 gearT444E and Key-Rei like this.
  4. Jul 20, 2022 at 5:51 PM
    eon_blue
    Azusa, CA
    Premium gas won't hurt anything. Your truck doesn't require premium to run but higher octane won't hurt it.
  5. Jul 20, 2022 at 5:51 PM
    Thatbassguy
    Thatbassguy Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    It won't hurt it. The only reason not to run it is that it's expensive and your performance won't benefit from it. But, if it's your only option, there's no reason not to run it.
  6. Jul 20, 2022 at 6:01 PM
    wingspar
    Oregon
    Great! Thanks for the quick replies. This was a couple of days ago that all stations in town were out of regular. Maybe they are back in stock now, but if not, I’ll splurge for premium.
    ABA180 and Thatbassguy like this.
  7. Jul 20, 2022 at 6:15 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    No point in premium on such a low compression engine, an argument can be made for ethanol free though.
    I run ethanol free but it's not necessary I'm just extra.
    6 gearT444E and amyracecar like this.
  8. Jul 20, 2022 at 6:27 PM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
    In my city, if the station runs dry on regular, they sell premium at regular prices. You may see that.
    Thatbassguy likes this.
  9. Jul 20, 2022 at 6:38 PM
    tacobp
    tacobp Well-Known Member
    Bob
    North Carolina
    09 Tacoma, 2.7 automatic
    Installed a Pop n Lock,,That's it !..Bone stock
    no problem running premium but you sure dn't need to...so no worries for you
  10. Jul 20, 2022 at 6:49 PM
    amyracecar
    amyracecar suck it up buttercup
    Virginia Applejack
    SouthEast USA
    2013 AC V6 MT OR Spruce/Mica
    you can always run higher octane, just a waste of $$ if you have choice, but you can/t go the other way
    if your automobile needs premium [usually 91 or 93 octane] you can't be running 87 in there - it can cause all kinds of engine issues
    my 128i needs the good stuff, and i try to avoid ethanol gas as well b/c i want that car to last forever so i maintain it to a T
    the taco was designed to run on 87 so that is what it gets - if it were a bit older, i might avoid ethanol as well - just don't feel like it is as picky as my car is about that stuff
  11. Jul 20, 2022 at 7:00 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    A lot of stations “accidentally” order way more Regular gas than they can hold and they tell the driver to just put the rest in the Premium holding tank. When you pay extra for Premium, odds are you’re actually paying extra for partially-to-mostly Regular anyway haha.
  12. Jul 20, 2022 at 7:14 PM
    DingleTower
    DingleTower My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
    That's not how it works. The stations don't order a set amount. Like your own fuel take the delivery truck fills the holding tank until it's full. There's no extra fuel that needs to be dumped into another tank.
    Maybe some unscrupulous stations are filling premium tanks with regular sometimes, I don't know, but I wouldn't say "odds are" you're filling with regular from the premium pump.
    6 gearT444E and Thatbassguy like this.
  13. Jul 20, 2022 at 8:06 PM
    ZMan2k2
    Richard
    Under a tinfoil hat
    When I was a “Petroleum Transfer Technician”, I had to measure the tanks with the dip stick, getting the depth of gas in the tank. Call the delivery company with the volume needed, they show up with the semi with the divided tanks on it, and they fill ‘er up.
    Steves104x4 likes this.
  14. Jul 20, 2022 at 8:14 PM
    studunk1
    studunk1 Well-Known Member
    stu
    jeff city, MO
    13 Access Cab sr5
    running boards, bug deflector, window deflectors, tail gate liner, bed mat
    Here is what an ethanol plant manager told me.....
    Choose one and stay with it. If you switch back and fourth, when you go from pure gas, which has some impurities that can cling along the fuel lines, injectors,etc. Then when you switch back to ethanol blend, which is actually alcohol, that alcohol is a solvent and will loosen that debris and could plug things up.
    But I have switched back and forth with no problems but just a tank ot two. However I would not run premium for a couple of years then switch to ethanol. Same is true with my small engines, they get only premium because the ethanol /alcohol will dry out the rubber fuel lines, rubber and plastic carb parts, etc.
  15. Jul 20, 2022 at 8:47 PM
    wingspar
    Oregon
    I can’t recall ever seeing a gas station around here run out of regular and selling premium at regular prices isn’t something many would do. Went to get gas a little while ago and they had regular. Not cheap either, but I’ll remember this thread and realize that if I have to have gas and they are out of regular, there is no harm in running premium.
  16. Jul 21, 2022 at 12:26 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    As mentioned, premium in an 87 recommended vehicle won't hurt anything other than your wallet. The other way though, she'll be hurting!
    https://youtu.be/Tp8INMugpf0
  17. Jul 21, 2022 at 7:51 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Technically you will gain a little horsepower n torque due to the adaptive timing nature of the ECU's on our trucks. Its not much.
    That stated, zero hurt to the truck whatsoever.
