Premium gasoline
Discussion in '1st Gen. Tacomas (1995-2004)' started by Scoobarooo, Dec 3, 2015.
  1. Dec 3, 2015 at 7:58 PM
    Scoobarooo
    Scoobarooo [OP] Well-Known Member
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    3" OME/Bilstein, Retrofits, Custom Bed rack/Toolbox, Amsoil Everything, tons of others.
    Does anybody else use 92-93 premium fuel?
    Any real advantages anybody has noticed?
  2. Dec 3, 2015 at 8:01 PM
    Drew_05Tacoma
    Drew_05Tacoma Well-Known Member
    Drew
    Unionville, NC
    2008 Access Cab Tacoma 4x4
    Level
    I can't remember his name but one guy on here claimed he could correctly guess which fuel was put into his truck without knowing beforehand.
  3. Dec 3, 2015 at 8:03 PM
    Madjik_Man
    Colorado Front Range
    Completely unnecessary if you're not boosted or running a high performance engine.
  4. Dec 3, 2015 at 8:04 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I would use it, if it was available in my area. Unfortunately, the best we have here at ~7K feet is 91 octane.
    The only reason to run premium in our trucks is if you've upgraded to forced induction (e.g., supercharger).
  5. Dec 3, 2015 at 8:05 PM
    Madjik_Man
    91 octane in altitude is the equivalent of 93 or so at sea level.
  6. Dec 3, 2015 at 8:07 PM
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    So I should stop wasting an extra 8 bucks a tank and stick with 87?
  7. Dec 3, 2015 at 8:08 PM
    Norton
    I've heard that, but I'd still prefer something better than 91.
    Unless you have a supercharger, yes.
  8. Dec 3, 2015 at 8:13 PM
    Madjik_Man
    Yeah, with being boosted I'd imagine you want the highest octane possible. But I wouldn't worry about 91, it's high enough. I'd be more worried about running this shitty gas with ethanol in it.
    I'm up in Winter Park a lot in winter and always try to fill up at the Conoco up there. Ethanol free. I can seriously tell a difference driving it and I'm usually up 2-3 mpgs in economy as well.
    robssol and Norton[QUOTED] like this.
  9. Dec 3, 2015 at 8:26 PM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I run 91 just about all the time. I can't really put my finger on it but the truck just seems to run better with the 91. Right now it's been down around 10 degrees lately and I put 88 octane in it. Couldn't tell the difference. In the summer I do notice a difference but it is slight and the mpg does increase slightly from 20mpg to around 22mpg. I'll probably continue to run the 91 when it's warm and the 87/88 when it's really cold.
  10. Dec 3, 2015 at 11:24 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
  11. Dec 3, 2015 at 11:39 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I only ever use 87 unless the station has run out.
    I think it is a waste of money
  12. Dec 4, 2015 at 12:03 AM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Your ECU contains fuel mapping tables which have for example air mass or manifold pressure on one side, and engine load or speed on the other. The nexus of two values on this table will be a fuel trim amount, the amount of fuel that should be injected given the demands on the engine. These tables assume you are using 87 octane. The fuel trim can adapt to use 91 without pre detonation or rich running issues, basically by adjusting ignition timing.
    You will never get the full benefit from 91 in a Tacoma engine due to the compression rating. Unlike a BMW or Mercedes, which commonly have 11:1 or higher compression, there is enough air compressed to benefit form the higher detonation point of 91 octane. Like others have said, your engine cant make this happen without forced induction.
    Your truck may feel like it is running better with 91 octane. This is from the higher energy contained within the 91 octane fuel resulting in a more efficient and quicker combustion. Less is needed as your engine, without FI can only pull in a finite amount of oxygen (the biggest factor to this being the elevation rom sea level you are at). This is where fuel mapping would come into play. Any increase in power or efficiency will not be more than what you paid for the upgrade in fuel.
    Now you could flash some performance fuel mapping software to the ECU. Though again, this will result in a good amount of power in a AMG Mercedes that is already engineered for high octane and high compression (with variable valve timing as well). To a Tacoma engine, the benefit would be negligible.
    Madjik_Man likes this.
  13. Dec 4, 2015 at 2:30 AM
    Oey12
    Oey12 Well-Known Member
    Joe
    New York
    SOLD:2012 TRD Sport 2017 SR5 4Runner
    Toytec 1/2 spacers, A.R.E Z, Firestone airbags
    I posted this in a different thread but this is what I found out about my completely stock 2nd gen... I used ethanol free 91 octane gas from upstate NY and increased my mpg's significantly. I was towing over the weekend for 3 days and the same load and trailer 1st day Shell 87 octane 18.4 @ 60 miles an hour 2nd day Shell 93 octane 19.2 @ 60 miles an hour and 3rd day Stewart's 91 octane ethanol free 20.7 @ 60 miles an hour. In my opinion the added cost is worth every penny. I can't physically can't prove that the truck ran better but I feel the ethanol free gas improved throttle response and just felt smoother...I don't know if the extra mileage out weights the cost but I believe premium gas is not BS.
    flyfshrmn and MadDaddy like this.
  14. Dec 4, 2015 at 5:39 AM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    REAL gas is your best bet-do not waste the extra expense on higher octane. From my experience--it is a waste of $$.
    There is a NOTICEABLE increase in MPG with REAL GASOLINE
    Tarzan13, MadDaddy and Norton like this.
  15. Dec 4, 2015 at 7:22 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    I got 87 :anonymous:
  16. Dec 4, 2015 at 7:25 AM
    devinzz1
    devin
    2023 aclb trd or mt
    I emailed Jet performance once and all they could get out of a 91oct tune was 3-5hp
  17. Dec 4, 2015 at 7:34 AM
    Clearwater Bill
    Billy
    Largo Florida
    People are confusing two different fuel features in this and other 'premium' threads.
    Ethanol free and octane are not interchangeable terms.
    Running a higher octane (historically, as in 60 years or more, called premium) than is required to prevent detonation for the given tune of an engine is a waste of effort and money. If a stock motor designed to run on regular runs better on premium, something is wrong with the motor. Carbon deposits on the pistons, which both can artificially raise compression and absorb fuel (creating a lean condition), is one example.
    Running ethanol free gas will typically result in a 10% or so improvement in MPG. You have to do careful math to prove the extra cost is worth the benefit, but it may be. It's not impossible to have some performance improvement as well.
    Also keep in mind that winter gas formulations change in colder climates of the country. Oxygenated fuels come to market, and your MPG will fall.
    Norton, robssol and tan4x4 like this.
  18. Dec 4, 2015 at 7:46 AM
    Madjik_Man
    That's what I put in my truck. Mid grade.
  19. Dec 4, 2015 at 9:59 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I sometimes use higher octane to get my truck to stop pinging. But it only fixes it until the ECU recalibrates the timing.
  20. Dec 4, 2015 at 11:36 AM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    So higher octane fuel doesn't burn hitter therefore cleaning your injectors out or anything like that on a stock Tacoma engine? Just wondering
