prep for chrome painting
Discussion in 'Detailing' started by Lentsnh, Dec 10, 2008.
  1. Dec 10, 2008 at 4:05 PM
    Lentsnh
    Lentsnh [OP] Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    im painting the toyota emblem on the front of my truck and ow do you prep it and can you use a quality (Rustolium...i thinm is what its called) spray paint?
  2. Dec 10, 2008 at 4:06 PM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    Adhesive promoter
  3. Dec 10, 2008 at 4:10 PM
    Lentsnh
    i thought that was to PUT it on.
  4. Dec 10, 2008 at 4:11 PM
    TacoCo
    Colorado
    Adhesion promoter I mean :p
  5. Dec 10, 2008 at 4:12 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    i didnt do anything to mine...i just cleaned it off real well and then sprayed a couple coats on it
  6. Dec 10, 2008 at 4:14 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    for painting my emblem............i washed and scrubbed it real good with dawn dish soap and a scotchbrite pad.(use hot water) let it dry overnight, unless you have an air compressor handy. then when painting it......use a few coats of adhesion promoter and whatever paint you want to use. i used duplicolor flat black. here's how mine turned out.
  7. Dec 10, 2008 at 4:15 PM
    Lentsnh
    spray paint? can i sand it down a bit to make the paint stick better? or is that just going to make the finished product look bad?
  8. Dec 10, 2008 at 4:20 PM
    rick
    rick `
    x2
  9. Dec 10, 2008 at 4:22 PM
    Lentsnh
    adhesion promoter? where do you get it? Lowes? that looks good
  10. Dec 10, 2008 at 4:28 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    walmart.........4 dollars for the can. i did about 4 coats of the adhesion promoter, then about 5 coats of the black. its still in awesome shape, and its been done for a few good months.
  11. Dec 10, 2008 at 4:29 PM
    Lentsnh
    ok i will most likely do that then.
  12. Dec 11, 2008 at 11:39 AM
    hashemg
    hashemg Well-Known Member
    Eastern MA
    08 Black Reg Cab 4x4
    3" Lift, Camburg Coil-Overs and UCA, 3" All Pro Leafs and OME rear shock, 33X12.5R17 Mickey Thompson on teflon coated American racing rims, Black headlight mod, Black taillight mod, tourneau cover, cargo divider, door sil protecors.
    would you reccoment doing it on the chrome grille surroud...or is it too big of an area??
  13. Dec 11, 2008 at 11:51 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah, and if you get the grille cleaned and prepped the right way, and definitely use the adhesion promoter.......it'll last and look good for a long time! go for it man!!
