Preparation for long road trip
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cdavis, Sep 23, 2010.
  1. Sep 23, 2010 at 11:23 AM
    Cdavis
    Cdavis [OP] Active Member
    OME 2.5" Front, Rear add-a-leaf with extended shackles, Downey Super-clutch, 33" BFG MT
    Hey guys, I'm new to the forum but I thought I'd take a poll from y'all about something:
    I am about to embark on 2 very long road trips in my 2001 taco. I will be driving from NC to NH, through Montreal, to Michigan and back to NC. A few months later I will be driving it to Yosemite from NC, then back at the end of the summer. I'm already at 189,000 with no serious problems yet. I've been pretty diligent about routine maintenance, and have been running full synthetic amsoil in it. So here's the question: what sort of preventative measures would you guys want to be sure you did to your vehicles before taking off on these sorts of long trips?
  2. Sep 23, 2010 at 11:35 AM
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    full fluid change; coolant, all oils (motor, trany, diff etc), how old if your brake fluid?
    check your brakes, lube all joints
    when was your timing belt last done?
    water pump? and thermostate?
    full tune up; air filter, plugs etc
  3. Sep 23, 2010 at 11:37 AM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    this^^^
  4. Sep 23, 2010 at 11:38 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
  5. Sep 23, 2010 at 11:39 AM
    gunner_20
    gunner_20 .....
    Nixa, MO
    '10 Tacoma DCLB Sport 4x4
    Fly.... Thats a lot of driving :eek:
  6. Sep 23, 2010 at 12:58 PM
    Madjik_Man
    Colorado Front Range
    Assuming you changed your timing belt at 90K, you might think about that considering you're past 180K
  7. Sep 23, 2010 at 1:23 PM
    Cdavis
    Good advice- I am thinking about switching over to full synthetic in my diffs, you think it's worth it? My brake fluid isn't that old, I replaced the master cyl and did a full bleed of the brakes less than 20k ago.
    I wish I could fly- going on extended climbing trips though so the need for my gear and a way to get around outside of the cities is a must, and I definitely don't leave home without the AAA card. I'll be in New England for about 2 weeks, then Yosemite for about 2.5 months!
  8. Sep 23, 2010 at 1:24 PM
    Cdavis
    Also thinking about switching out my MT tires for something a little more highway-friendly and leaving them at home for when I return...
  9. Sep 23, 2010 at 1:34 PM
    vantaco
    ya i'd definetly put highway friendly tires on...will not only reduce road noise but i'm sure fuel
  10. Sep 29, 2010 at 5:05 PM
    gunner_20
    gunner_20 .....
    Nixa, MO
    Lucky you! I have never been to Yosemite. I couldn't imagine spending 2.5 months there... heaven
