Preparing for 1300 mile drive with my 2010, anything I need to do beforehand?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lunercrab, Jul 20, 2010.
  1. Jul 20, 2010 at 4:13 PM
    Lunercrab
    Lunercrab [OP] AKA "06tacosport"
    Beth
    Lehigh Valley area, PA
    2010 timberland mica dcab sport
    Ok so I'm making a a 1300 mile trip from pa to sc in august and I'm wondering a few things. Well my truck is a 2010 with almost 4k miles on it now and probably maybe about 4500 miles on it when I leave. I switched it over to full synthetic around the 2100 mile mark back in like April so I shouldn't need to be concerned with an oil change by then right? Or would it benefit it at all to change it maybe before I leave again. Also what about greasing the zerks on the driveshaft and such when should that be done for the first time on a 4x4? I mean like I said other then checking the tire pressure and filling up the tank anything else beneficial to do? Thanks guys :)
  2. Jul 20, 2010 at 4:30 PM
    kramer2k
    kramer2k Well-Known Member
    Jacksonville, FL
    08 DC PreRunner TRD OR
    If you just did a full synthetic oil change around 2K miles, you're fine until 12K or so. Don't waste your money.
  3. Jul 20, 2010 at 4:34 PM
    NetMonkey
    NetMonkey Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    put gas in it? :D
  4. Jul 20, 2010 at 4:36 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    me personally......no matter how synthetic the oil you used is....i wouldnt let it go over 5k miles...so i'd probably change it before you leave. make sure the air in the tires is set, lube the grease zerks later on...you should be fine.
    what part of SC you coming to?
  5. Jul 20, 2010 at 5:11 PM
    Lunercrab
    Beth
    Thanks guys. Yeah I was real iffy on the oil change. I would usually change it between 5-7k on my 2006. I mean it only costs like 30 bucks so it's not a huge expense. How many miles does it usually take for the engine to break in? Like aren't there small metal shavings and stuff in the oil till the engine sets properly? I'm heading to myrtle beach :)
  6. Jul 20, 2010 at 5:34 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    an engine is usually"broke in" a lil after you get it from the dealership...unless it has a super low amount of miles on it....like 12 or so. as fao when you start getting better mileage "broke in"..usually around 10 to 12k.
  7. Jul 20, 2010 at 5:43 PM
    Lunercrab
    Beth
    Yeah I can't wait till I hit that "better milage" peak cause my milage is fairly bad right now. I don't think I've hit more then like 280 miles on a tank yet
  8. Jul 20, 2010 at 6:21 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    give it some time...it'll get better.
  9. Jul 20, 2010 at 8:35 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    You should get about 22-23 on I95.
    Where you going and when you coming down? I'm heading up to NJ again first weekend in August myself.
  10. Jul 20, 2010 at 8:42 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    Really? Lately I been getting just over 300 miles a tank mostly city. Which is surprising because I have been mashing on it every now and then to hear my new wicked flow muffler. But other than that I do a pretty good job keeping it under 2k RPMs when driving. Have about 1550 miles on my truck right now.
    Check tire pressures, mark sure all your blinkers and brake lights work so the fuzz doesn't pull you over, and get plenty of beef jerky and corn nuts!!!
  11. Jul 20, 2010 at 8:45 PM
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    just remember to put gas in it!! :D
  12. Jul 20, 2010 at 8:46 PM
    Celtic
    Celtic Tactical Trunk Monkey
    Nick
    Willows, CA
    06 AC TRD 4X4 SR5 6spd
    BHLM, Devil horns, trimmed front flaps, Flowmaster muffler,
    Make sure you have radio presets good to go, or your ipod charged...its a bummer to on a long trip and not find anything on the radio when driving... Besides that you should be good to go, Full synthetic oil extends the life of oil changes by 2 at least... whole point is to reduce the amount of time you spend changing the oil and creating used oil waste. Plus you are on the right track, check oil level, tire pressure, coolant and wiper fluid. other than that... drive it like you stole it, Dude its a Toyata... mechanics buy them for a reason. :D Cause we hate working on our own cars. :D
  13. Jul 20, 2010 at 9:21 PM
    Lunercrab
    Beth
    Yeah the most I got so far is like 280 with mix of highway and city. I never go more then 65/70 and usually the rpms are under 2k. I only use nonethanol gas as well. The only thing I've change really since stock was my duratracs e rated (got a great deal) which makes me ask this. Max psi is like 80, so for the best say milage/wear factor what would u say psi should I do for this trip? I think I bumped them upto like 50 right now. I'm heading down there on the 14th of august. Trust me I'm not looking forward to the 12+ hour drive or being with the inlaws ;) for a family vacation, But yeah if I could get at least 20 mpg I'd be happy. Hey is there any benefit with driving on a trip like this to using a gas grade higher then 87?
  14. Jul 20, 2010 at 9:28 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    Depending on the size of the tire that could be a factor in your mileage. Funny thing is that I'm going to colorado on AUG 13.
  15. Jul 20, 2010 at 9:32 PM
    Lunercrab
    Beth
    Yeah forgot the tire is 265/75/16
  16. Jul 20, 2010 at 9:32 PM
    tacomakid89
    tacomakid89 Awesome Member
    William
    SoCal, CA
    2010 Black, 4x4, TRD Sport Tacoma
    Hard Wired GPS, Scan Guage II, URD Short Throw Shifter, AFE Pro Dry S Air Filter, LED Mag Lite on seat side,Tailgate Theft Prevention Mod, Removed Front License Plate, Tint Cover Over Rear License Plate, Removed Secondary Air Filter, 13" Shorty Antenna, 5% Tint Rear, 20% Tint Front, Bed Extender, TRD Cat Back Exhaust, Fog Light On Anytime Mod, Dual Halo Projection Headlights, Disabled Seatbelt Chime
    Well I had the same thing. But from VA to CA. lol. Make sure you have a spare gas can, water, maybe a little too box, snacks, top all your fluids off, make sure your tires are good, fill up before you leave and you should be good.
  17. Aug 3, 2010 at 9:10 PM
    Lunercrab
    Beth
    Hey guys not to drag up this topic again but I'm really confused on what psi I should run. As I've said I have e rated duratracs with max psi rating at 80. Now I know I don't have that much weight I'm gunna carry down with me so I don't need full psi. But for mpg purpose do u think is should run the most I can at a comfort level. I actually have Them set at 50 psi now. I do notice the ride is a bit stiff and bumpy but it's not bone jarring and it doesn't bother me. Do u think if I bump it upto like 60 that would be overkill?
  18. Aug 3, 2010 at 9:17 PM
    Larry
    Larry CARL
    CARL
    Have a safe trip...and enjoy Myrtle Beach.
    I've been there a few times, and always had fun on the Grand Strand.
  19. Aug 4, 2010 at 7:07 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Tire inflation guide is on driver's door jamb. It's in the 29-35 range. My 08 regular cab 4x4 is 29psi on all 4.
    I carry a tire plug kit. 4way tire iron, flares or warning triangles, water, on a regular basis, especially on long trips.
  20. Aug 4, 2010 at 7:16 AM
    Lunercrab
    Beth
    I thought those psi ratings only applied to the factory tires and not the truck itself
