Preparing for sub-zero driving...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Duckman, Dec 15, 2016.
  1. Dec 15, 2016 at 9:06 AM
    Duckman
    Duckman [OP] n00b Extordinaire
    Somewhere on the River
    17 White TRD ORDC TECH 4X4
    Being from Arkansas that really doesn't happen. I have to go get my son in Madison WI next week.
    By the way UW and Madison.... what a beautiful place. Great people, great food!
    I'm thinking of draining the washer fluid and making sure what ever I replace it will take the cold...
    BUT is there anything else I need to be concerned with?
    Thanks for the time.
  2. Dec 15, 2016 at 9:09 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    tire pressures...check fluid levels...get your battery checked. most everything here in the states is ok. If you lived in Alaska you'd need a block heater.
  3. Dec 15, 2016 at 9:14 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Clean and Rain-X the windshield so that snow and ice come off easier and have a great trip! Edit: and maybe some one piece beam style wiper blades (if you have the open metal frames) that won't freeze up solid
    Duckman[OP] likes this.
  4. Dec 15, 2016 at 9:22 AM
    Duckman
    I'm sold on Rain-X. I ALWAYS use their washer fluid. Just haven't replaced it yet from the factory fill. I was going to check the temp range first... but I was going to refill with that.
    digitaLbraVo likes this.
  5. Dec 15, 2016 at 9:24 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Warm blankets water just in case you get stuck in an accident
    digitaLbraVo and Steves104x4 like this.
  6. Dec 15, 2016 at 9:33 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    I am a little worried about your tires, though. It would be nice if you could borrow a set of snow tires (or something a little more aggressive)
  7. Dec 15, 2016 at 9:38 AM
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    Put some weight in the back end for better traction.
    If you get in to slippery conditions, test traction every once in a while by a quick stab of the brakes. I mean in a straight line with no one behind you. Quickly apply and release moderate brake force. If the abs goes off....you know to slow down and be careful. If it doesnt....you know that you are OK to drive a bit more quickly. Conditions can change within a few miles, so pay attention. 4wd gets you going and masks the slippery conditions.....but it won't help brake.
    Pittrider and JoeyDel like this.
  8. Dec 15, 2016 at 9:42 AM
    schwiner
    schwiner Member
    someguy
    16 tacoma Sr5 lb
    Cap
    Windshield washer fluid if you get premixed 1 gal jug. Make sure it's rated -25 below zero. (Currently about zero in wi) doing that truck should be fine for cold should. If you have fwd is good. Wouldn't hurt to have a set of jumper cables, a shovel, warm clothes gloves and boots in case you get stuck/ break down. It can take hours to get help if your in a blizzard, and break down, or road closed because of accidents. tow trucks get backed up. Having lived in wi for 60+ yrs And a retired over the road truck driver, I have seen a lot of things happen. JMHO.
  9. Dec 15, 2016 at 9:42 AM
    Downtown952
    Downtown952 Well-Known Member
    Jim
    2017 TRD Sport DCSB 4x4
    I grew up 10 minutes north of Madison, and went to UW Madison. All the above tips are good. Stop at DLUX on the square for a burger while you're there.
    Spare Parts likes this.
  10. Dec 15, 2016 at 9:51 AM
    Duckman
    YES.... And I have fallen in love with Dottie's for burgers too. Their fish fry on Friday is the best along with the tarter sauce and it's always about the tarter sauce. For some reason, burgers in WI are special. If I could figure out how to make a living there AND pay your taxes I'd move. Simply a beautiful place. Actually been looking at Black Earth or Sauk City
    Thanks so much guys. Was bringing a jumper box already but the shovel... I din't think of that.
    What about extra weight in the bed over the wheels??
  11. Dec 15, 2016 at 9:53 AM
    Duckman
    Sorry this came in as was typing....
  12. Dec 15, 2016 at 9:56 AM
    vuTron
    vuTron Well-Known Member
    SF Bay Area
    2016 Quicksand TRD O/R DCSB AT
    its been mentioned, but worth a repeat... bring a shovel.
    just drive slow. your truck is more than capable. you'll see honda civics driving around just fine.
  13. Dec 15, 2016 at 9:58 AM
    swordfish
    swordfish Well-Known Member
    Jon
    CT
    ‘25 MT6 Off-Road
    Go to your local Home Depot/Lowes/whatever and grab a couple of the tubes of sand. An extra 150# over the back axle will help keep you planted and will also offer some extra traction if you get stuck on some ice.
  14. Dec 15, 2016 at 10:07 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    the_dau and Duckman[OP] like this.
  15. Dec 15, 2016 at 4:17 PM
    Duckman
    Thanks everyone for the time. I do appreciate it
    Let alone Subaru's... They have Subie dealerships bigger than Chevy in the south. That has to be one of the most secure rides I have ever driven in snow. Their AWD is crazy.
    I never use straight up rainex... Using the washer fluid is kind of a light version of a straight rainex coat. Straight rainex is so hydrophobic you can't even use the wipers without a heavy rain.
    And to your video... I should look it up here. there is a guy that uses extra fine steel wool on his windshields. Technically bar for XF steel wool is a whole lot softer than a windshield. I don't think i'm there yet for that one.
  16. Dec 15, 2016 at 9:37 PM
    jkcashin
    jkcashin Well-Known Member
    Jamie
    Ottawa, Ontario, Canada
    2017 TRD OR AC MT
    If it were a diesel, I would be telling you to leave with a partially empty tank, and fuel up on arrival in the north. In the winter, northern states, and Canada put additives in diesel fuel to prevent gelling... diesel fuel will literally turn to a gel at very cold temps! Gasoline too has some additives for winter, but it's not as critical, but I would still plan to refuel at destination. Actually experienced this ourselves when driving from the very southern end of North Carolina to Ottawa in September and ran into severe cold, unseasonably cold weather. But it was not the car that got the shock... it was I, who left the Carolinas in 90 degree weather only to get out of the car in upstate New York to refuel, still in my shorts and T-shirt, only to find it was down to near freezing. Brrr....
  17. Dec 15, 2016 at 9:38 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Take a jacket
  18. Dec 16, 2016 at 5:37 AM
    Duckman
  19. Dec 16, 2016 at 6:09 AM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    don't forget to bring Long Underwear
  20. Dec 16, 2016 at 6:21 AM
    Minny Taco
    Minny Taco For the Horde!
    Minnesota
    2015 TRD Off Road DCSB
    - Dobinsons shocks and leaf pack - Level 8 MK6 wheels - 265/70/17 Goodyear Wrangler Duratracs load C - SPC UCA - Moog LCA - TRD Pro headlights - Bullet Proof Fab skid plate w/ Line-X - 3M Matte Black roof vinyl - Astrostart remote - Debadged - Black shifter bezel - Front window tint 50% - Color matched grill surround - MESO LED red/white map lights - Osram Super Bright H4 bulbs - Headlight Services upgraded wiring harness - Auxito LED reverse lights - Zulu Nylon Gear MOLLE visor cover - Truxedo Lo Pro QT tonneau - Weathertech floor mats - Weathertech vent visors - Redline Tuning Elite hood struts - OEM bed mat - AJT Design custom shift knob - AJT Design custom climate knobs - Center console organizer - Salex glove box organizer - 1" driver seat spacers - AntennaX 14" antenna - AVS door sill protectors - Trimmed OEM mud flaps - Candyapple red tow hook - Painted pinch weld and radiator frame - Custom radio knobs from Hondo Garage - Xtunes black tail lights - Black LED third brake light - Ruff Tuff Kryptek Typhon seat covers - ACEkraut license plate relocation bracket - Cali Raised Side Shooter ditch lights w/ lo-pro mounts - Subaru tweeters + Rockford Fosgate speakers - Thinkware F800 Pro dash cam - Stickers n shit
    Just bring some boots and gloves, maybe a blanket in case you run in the ditch. And if you drive by Lambeau stop and pee on it for me! SKOL!
    Zoop likes this.
