preparing for winter driving (tires/weight in back)
Discussion in '1st Gen. Tacomas (1995-2004)' started by gman88, Sep 7, 2010.
  1. Sep 7, 2010 at 8:49 PM
    gman88
    gman88 [OP] Active Member
    Gary
    Pittsburgh
    I'm the new owner of a 2003 double cab, TRD Tacoma. The truck has 44K miles. This is the first true pickup truck I have owned. I don't count my Subaru Baja. The truck rides great, however, I'm not impressed with driving performance in the rain / wet roads. I believe it is probably the tires. They are Cooper Discovery H/T, with probably 10K miles on them is my guess. I will replace with Michelin, but I would like to get the winter out of them. Do you guys recommedn adding weight to the bed in winter time? I don't know if the poor wet driving is a function of the tires, or a function of needing some weight in the back end or both? Thanks for the input. Many years ago, I owned a 1990 4Runner that was a maintenance nightmare. It appears that this truck is very solid.
  2. Sep 7, 2010 at 8:56 PM
    gusotto
    gusotto gusotto
    Gary
    Iowa
    2001 Tacoma 4X4 SR5 Extended Cab
    You didn't let us know if it was 2WD or 4WD.
    It makes a difference.
    I've driven 4WD with crappy tires and it wasn't the tires. Always got around.
    I never needed weight in the rear but I always had 4WD.
    If anything is added to the rear, make sure it's secured.
    In the event of an accident, everything will just keep coming forward and take your head off.
    It happens.
  3. Sep 7, 2010 at 9:01 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I am not familiar with the tread pattern on your coopers but one thing that can help in these situations is adding siping to the tread. Siping adds bitting edges that will help immensely in slippery conditions.
    If you are not familiar with tire siping, check out this link:
    http://www.discounttire.com/dtcs/tireSiping.dos
  4. Sep 7, 2010 at 9:01 PM
    gman88
    Gary
    Pittsburgh
    Thanks gussotto. Yes, my truck is 4WD. Good point about securing any weight.
  5. Sep 7, 2010 at 9:14 PM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    ^ just get some goodyear wrangler duratracs. $800 and they'll give you 40k miles of solid safety....oh and its the tires you have now...I remember when i had the stock tires on my truck...damn they were borderline dangerous
  6. Sep 8, 2010 at 6:06 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    I never add any weight to mine in the winter just use's more gas.
  7. Sep 8, 2010 at 6:15 AM
    gusotto
    gusotto gusotto
    Gary
    Iowa
    Same here.....
    4WD gets me all over the place.
    40+ years of owning 4WD trucks and never need any extra weight to get around.
  8. Sep 8, 2010 at 1:15 PM
    trailinTaco
    trailinTaco Well-Known Member
    Bel Air, MD
    2000 Tacoma SR5 TRD 3.4L 4x4
    3 inch suspension lift, 33 inch bfgoodrich mud terrain tires, toytech diff drop, Procomp alloy wheels, hella fog lights, black projector headlights with 8000k HID's, blacked out tail lights, two 12 inch subs, 20% tint, pioneer head unit and speakers
    Well you are going from a Subaru that's all wheel drive to a pick up. I've driven a forester and it has excellent traction. But you just have to remember a rear wheel drive pick up can slip alot more. All of them do. But it works great in 4wd when you need it.
  9. Sep 8, 2010 at 1:41 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    ive never had to add any weight, 4wd works awesome in the snow. plus having good tires has a major effect to.
  10. Sep 8, 2010 at 2:42 PM
    Madjik_Man
    Boulder, CO
    1998 Ext Cab 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
    ^This
    And on a side note I only add a 40lbs bag of cat litter to the back (directly between the wheel wheels) if I'm going up and over the passes in shitty conditions. Probably don't need to, but it makes me feel more secure mentally
  11. Sep 8, 2010 at 2:47 PM
    Razorecko
    i used to use a couple 50lb bags of salt in the old crown vic i used to drive years ago. That way if i got stuck i had something to get myself out with =)
  12. Sep 8, 2010 at 2:53 PM
    memario1214
    memario1214 Vivid Illumination Vendor
    Colton
    Gillette, WY
    05 Dub Cab TRD Sport 4x4
    Yeah, I gots boost
    If you are in fact planning on getting new tires, and you just need these to get you through the winter, siping is a great option! It increases traction quite well, and it isn't all that expensive to get done. Only downside to them is that the tire wears out quicker. If you are only using them in the winter, this increased wear effect won't matter.
