Preparing , preparing , you're always preparing . OZ-T's "Just build the damn shop already build ".
Discussion in 'Garage / Workshop' started by OZ-T, May 16, 2020.
  1. Feb 12, 2021 at 5:51 PM
    #761
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
    My drywall bud couldn't make it out today , not sure if he's coming by on the weekend so interior finish is undetermined right now but I got my strapping wrapped around the building , should finish that tomorrow no problem
  2. Feb 12, 2021 at 5:56 PM
    #762
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
    Should’ve had Matt Risinger film this.
    Slashaar likes this.
  3. Feb 12, 2021 at 5:59 PM
    #763
    4x4spiegel
    4x4spiegel Well-Known Member
    @Qz-t & @23Skidoo what temp you guys have outside now
  4. Feb 12, 2021 at 6:04 PM
    #764
    23Skidoo
    Paul
    meme
    27 right now in Austin, on our way to 2 on Monday. We should be at 70 in two weeks. lol
    Fargo Taco likes this.
  5. Feb 12, 2021 at 6:07 PM
    #765
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    I think OZ has below freezing temps, 26 to 28F and is expecting wind and a decent dump of snow, almost a foot worth. Read power failures likely, as trees take out power lines.
  6. Feb 12, 2021 at 6:11 PM
    #766
    OZ-T
    Peter North
    British Columbia
    -5C which is about 23F I believe
    23Skidoo likes this.
  7. Feb 12, 2021 at 6:15 PM
    #767
    23Skidoo
    Paul
    meme
    We have a 1/4” of ice on everything. The power lines are being weighed down with tree branches, expecting power outages. We don’t know how to act in this weather, the stores are being cleaned out.
  8. Feb 12, 2021 at 6:15 PM
    #768
    OZ-T
    Peter North
    British Columbia
    yeah , my thermostat at the house here says its colder than they're forecasting , supposed to start snowing overnight , its colder than we usually are so snow might be a bit drier and lighter than our usually heavy slop
    Fargo Taco and VE7OSR[QUOTED] like this.
  9. Feb 12, 2021 at 6:18 PM
    #769
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Its gradually warming up here, in town -13C tonight, Wed. night it was -22C and breezy.
    OZ-T[OP] and 23Skidoo like this.
  10. Feb 12, 2021 at 6:22 PM
    #770
    OZ-T
    Peter North
    British Columbia
    Only if I get my own channel on The Build Show
  11. Feb 12, 2021 at 6:27 PM
    #771
    23Skidoo
    Paul
    meme
    And get some product sponsorship. ;)
  12. Feb 12, 2021 at 6:31 PM
    #772
    brow
    brow Well-Known Member
    Andy
    Minnesota
    2020 Dodge Ram 1500
    Keep your weather to yourself up there! We’re hitting -20 (-29C) at night pretty regularly and I’m tired of jumping crew vans at 7am
  13. Feb 14, 2021 at 1:51 PM
    #773
    OZ-T
    Peter North
    British Columbia
    Drywall complete , ready to prime & paint
  14. Feb 14, 2021 at 2:07 PM
    #774
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    So nice. Can't be a workshop.:rolleyes:
  15. Feb 14, 2021 at 2:35 PM
    #775
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    Coming together amazingly, @OZ-T!
    Tape off the trusses or freehand it?
  16. Feb 14, 2021 at 4:24 PM
    #776
    OZ-T
    Peter North
    British Columbia
    I'm not the greatest painter so I'll likely tape off the leading edge of the timbers where I'll be cutting in
  17. Feb 14, 2021 at 5:47 PM
    #777
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    are you staining, or otherwise sealing the timbers? In my mind, if the timbers were done first, then cleanup of water based paint on it would be easy?
  18. Feb 14, 2021 at 6:01 PM
    #778
    OZ-T
    Peter North
    British Columbia
    probably just sand and clear sealer
  19. Feb 16, 2021 at 6:38 PM
    #779
    OZ-T
    Peter North
    British Columbia
    Today I vacuumed out the shop getting ready for priming , and I removed any drywall dust / mud / hand prints etc from timbers with some soap & water . I'm thinking I might just sand timbers and not seal them at all
    SwampYota, Drainbung, POOLGUY and 2 others like this.
  20. Feb 16, 2021 at 8:02 PM
    #780
    svdude
    svdude Well-Known Member
    jonathan
    I gotta say, I really appreciate you posting all the details. It has been awesome to follow your shop build. It’s definitely above my abilities but I’m handy enough to really appreciate someone’s fine work. I feel like I can tell when someone makes something whether it’s just a job or a passion, it appears this is definitely a passion of yours. Kudos!
    For what it’s worth, the timber’s would look awesome with some stain on them.
    VE7OSR, Fargo Taco and OZ-T[OP] like this.
