Prepping for Sound Deadening
Discussion in 'Audio & Video' started by PVT Pablo, Aug 18, 2015.
  1. Aug 18, 2015 at 4:38 PM
    PVT Pablo
    PVT Pablo [OP]
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Hi TW,
    I am going to be getting my shipment of sound deadener and sound deadening foam soon. I plan on covering as much of the doors and rear as 36 square feet will get me.
    My question is what chemical is good for prepping the surface of the inside of the doors for the sound deadener adhesive? All I can think of is rubbing alcohol but its kind of expensive per ounce for what it is. Any other better options?
    Thanks!
  2. Aug 18, 2015 at 6:36 PM
    Zonktified
    Zonktified Well-Known Member
    Rob
    Wisconsin
    Tacoma TRD Sport
    Paint thinner or Naptha come to mind...not sure of the cost to volume ratio though.
  3. Aug 18, 2015 at 7:07 PM
    PVT Pablo
    PVT Pablo [OP]
    Paul
    Kitsap County, WA
    Aren't the inside of the doors painted? I would think paint thinner would cause a sticky gooey mess instead of cleaning the surface.
    I don't mean to say that rubbing alcohol is expensive, but when its like 10 bucks for 16 ounces, there has got to be something better. If not I don't mind buying it, it just seems surprising.
  4. Aug 18, 2015 at 7:28 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    I just wiped everything down with a wet rag. The stuff I used had no problem sticking like crazy to anything it touched.
  5. Aug 18, 2015 at 7:29 PM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    anything that cuts grease/oils and provides a clean dry surface
  6. Aug 19, 2015 at 6:54 AM
    Zonktified
    Rob
    Wisconsin
    Tacoma TRD Sport
    Paint thinner will probably have no effect on paint, unless the paint is still wet. This is from the DIY website and was my understanding as well...it us primarily used to dilute or clean up wet, oil based paints. Naptha will clean up most oily residue as well and dries really fast without leaving a residue. I guess you could try ammonia too, but the fumes are potent and not all that pleasing. I would avoid mineral spirits because I believe it may leave an oily residue behind when dry.
    BTW....I just got my deadener in the other day and was planning on using Naptha...unless someone else has a better recommendation...I'm staying tuned as well.
  7. Aug 19, 2015 at 4:54 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    You can use mineral spirits, it is often called paint thinner. Turpentine will leave a residue....do not use lacquer thinner. Windex is ok if the surface is just dirty, not oily or greasy.
  8. Aug 19, 2015 at 5:12 PM
    PVT Pablo
    PVT Pablo [OP]
    Paul
    Kitsap County, WA
    After doing a bit more research, I ended up buying denatured alcohol, for 4 dollars a quart.
    I chose it because it evaporates quickly, does not leave a residue, and will not soften paint.
    DrFunker likes this.
  9. Aug 19, 2015 at 5:19 PM
    DrFunker
    DrFunker Well-Known Member
    That would work. Was going to say Acetone too, but that would be more 'spensive.
  10. Aug 19, 2015 at 5:23 PM
    PVT Pablo
    PVT Pablo [OP]
    Paul
    Kitsap County, WA
    I have acetone, it just happens to be in my wifes makeup bag. Last time I used the whole bottle and caught a little heat haha. Couldn't believe that little bottle was 10 bucks.
    DrFunker[QUOTED] likes this.
  11. Aug 19, 2015 at 5:26 PM
    DrFunker
    Yeah, shit is expensive. Works well at cleaning though. :D
  12. Aug 19, 2015 at 5:26 PM
    DrFunker
    You planning to do a whole write up here?
    Would love to see the progress pics. :)
  13. Aug 19, 2015 at 5:27 PM
    DrFunker
    Hey, we have the same truck. :thumbsup:
    :cheers:
    PVT Pablo[OP] likes this.
  14. Aug 19, 2015 at 5:29 PM
    DrFunker
    Whoa :eek:
    and you have a badass job!
    Be safe, man.
  15. Aug 19, 2015 at 5:40 PM
    PVT Pablo
    PVT Pablo [OP]
    Paul
    Kitsap County, WA
    Well when you put me on the spot haha. Yeah I might as well do a little write up. I know a lot of guys that have done sound deadening with dynamat, raammat, ect., but i haven't seen a lot of installs with sound deadening foam. I want to add the foam to see if I can not just get rid of vibration, but block out some road/tire noise. Here's what I got on the way.
    Stinger Roadkill
    http://www.amazon.com/gp/product/B001HHP59G?psc=1&redirect=true&ref_=oh_aui_detailpage_o03_s00
    Noico Automotive Insulation Pad
    http://www.amazon.com/gp/product/B00URV8MFC?psc=1&redirect=true&ref_=oh_aui_detailpage_o02_s01
    Thanks man! I got nine more months of boarding deep draft and then hopefully I move on to some more of the more specialized operations. Put in my acceptance package today! :D
  16. Aug 19, 2015 at 5:44 PM
    DrFunker
    Good luck on the advance. :fingerscrossed:
    Wow! That deadening project looks intense. I think the foam will cut a lot of vibes down. You may even notice a temp difference in the cab. :laugh: That would be awesome.
    Can't wait to follow your work on it.
    No presssure. :devil:
  17. Aug 19, 2015 at 6:14 PM
    PVT Pablo
    PVT Pablo [OP]
    Paul
    Kitsap County, WA
    Thanks!
    I was really excited to find the foam. The biggest headache is going to be cutting it to fit. The foam essentially has to create an entire wall between the interior panel and the metal door panel to be effective. Who knows, maybe I can become a TW entrepreneur and start selling a template so you can just cut the foam and stick. :cool:
    If I get a temp difference that will be an added bonus. The A/C could definitely use a break in this 90 degree heat!
    I should start the install sometime next week when my stuff gets here. I will post up some pictures.
  18. Aug 19, 2015 at 6:16 PM
    DrFunker
    Nice. :thumbsup:
    Been near 90s here too. But that is not common here, as I am sure it is there.
    Can't wait for the install:popcorn:
  19. Aug 21, 2015 at 12:22 AM
    shaneckc
    shaneckc Fyntünd Designs Vendor
    Shane
    Thousand Oaks, CA
    2014 SR Package DCLB 4x4
    Acetone.
  20. Aug 21, 2015 at 2:36 PM
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    Purple power. It's cheap and it works great as a degreaser without any fear of harming your paint. Also good and cleaning up dirt. Sprays on and wipes off.
