prerunner 2wd vs standard 2wd w/2.7l
Discussion in '1st Gen. Tacomas (1995-2004)' started by nobra25, Mar 2, 2023.
  1. Mar 2, 2023 at 11:11 AM
    nobra25
    nobra25 [OP] Member
    Smitty
    would a standard 2wd with a 2.7l have the same suspension, brakes, etc as a 2.4l
    looking at a 2001 std cab with vin 5TENM92N11Z763802. owner hasn't been much help.
  2. Mar 2, 2023 at 11:21 AM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    If I remember correctly the 2.4 only came in 5-lug 2wd trucks. The 2wd prerunner which could come with the 2.7 is a 6-lug truck.
    5lug trucks have entirely different suspension and brake components than the 6lug and they do not directly swap over
    MalinoisDad, SH10151 and Area51Runner like this.
  3. Mar 2, 2023 at 12:03 PM
    nobra25
    nobra25 [OP] Member
    Smitty
    this could be a option than for the 2wd truck, maybe the 2.7l comes w/6 lugs prerunner or not
  4. Mar 2, 2023 at 12:06 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    5 lug and the Prerunner are completely different front Suspension
    With vehicles this old a 5 lug with a 2.7 swapped in is quite possible.
  5. Mar 2, 2023 at 12:49 PM
    nobra25
    nobra25 [OP] Member
    Smitty
    thanks for the reply. this rig has the 6 lug wheels, which thru me as to what else was different. the vin# says its a base trim and came with the 2.7l
    Bivouac likes this.
  6. Mar 2, 2023 at 3:33 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    Say you had a totaled 4x4 with a good drivetrain and an undamaged PreRunner with high mileage and a tired engine and/or transmission. The swap would be relatively easy, as a PreRunner is basically a 4x4 without the transfercase and front diff. Literally everything else is the same. Standard 2WD Tacomas have a 5-lug bolt pattern instead of 6, and a different rear axle and suspension.
  7. Mar 2, 2023 at 5:10 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    No.
    The 2.7 came standard in Prerunners or 4x4s.
    The 3.4 was an option in 5 lugs.
    The 2.4 came standard in 5 lugs.
    Bivouac likes this.
