PreRunner 4x4 Conversion Journey Thread
Discussion in '1st Gen. Tacomas (1995-2004)' started by dngrrngr, Feb 20, 2025.
  1. Apr 23, 2025 at 3:18 PM
    #181
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    You're probably going to want to mentally prepare to change those out for ABS or ASA. Looks like you got the contours right though!
  2. Apr 25, 2025 at 7:39 AM
    #182
    mjhenks
    mjhenks Well-Known Member
    So.Cal
    04 Jade Green TRD V6 DC
    Great Job. Reading this was a trip down memory lane. Glad i was able to passively help which of course is one reason to make a build thread. Really like your dash screen.
    Have fun with it.
  3. May 7, 2025 at 10:29 AM
    #183
    dngrrngr
    dngrrngr [OP] Well-Known Member
    Western NC
    2003 3.4L Auto XtraCab PreRunner 4x4 Conversion
    Haha man I haven't even gotten PETG dialed in on my MK4S yet, so I will die on the PLA hill until proven otherwise lol.
  4. May 7, 2025 at 10:30 AM
    #184
    dngrrngr
    Western NC
    Thanks for all your help! It was an incredibly fun and rewarding project, kind of sad it's mostly over haha
  5. May 7, 2025 at 10:39 AM
    #185
    dngrrngr
    Western NC
    Some mini updates, I received my 2 degree Tom Woods axle shims that will hopefully fix the slight vibration I'm getting at speed, presumably from the pinion angle. For anyone's reference, it's currently at roughly 4 degrees when comparing the rear diff flange face to the rear section of the driveshaft, so we will see how much the 2 degree shim affects it.
    In some more annoying news, I currently have a small leak of ATF where the transfer case mates with the trans, so presumably some issue with the output seal on the trans. I can't even describe how much it pisses me off given seals were something I was particularly diligent about during this process. My only thought is I may have either damaged or dislodged it a bit when trying to install the transfer case shaft. It's just a drop (for now), so I'm going to ignore it as long as I can as replacing that again will be a huge PITA. I also noticed a potential leak at my driver side front diff CV seal, which really doesn't make sense to me as there should have been no contact that would've dislodged it, and both of these seals were brand new OEM. I suppose that's just the way she goes..
    other than that, everything is going swimmingly. Trans has been driving great, wheel bearings and hubs are smooth. Still searching for some light off roading to really test it out!
  6. May 7, 2025 at 10:42 AM
    #186
    dngrrngr
    Western NC
    Area51Runner likes this.
  7. May 7, 2025 at 11:08 AM
    #187
    Toyoda213
    Toyoda213 Well-Known Member
    Jimmy
    SoCal
    2003 V6 dlbc Prerunner 4x4 converted
    I had that same leak on the transfer case when i did my swap. I replaced the seals with OEM ones. I left it as is and kept an eye on it but it never really leaked much to be honest. Nothing on the floor and the fluid level stayed where it should. Im not sure what was going on there.
    As for the front diff leak. When you installed the new seals did you install them all the way in? I believe those seals are suppose to be installed flushed. Kind of hard to explain but Ive seen many install these wrong and they get a leak.
  8. May 8, 2025 at 8:43 AM
    #188
    dngrrngr
    Western NC
    Good to know you had the same leak and it didn't end up being an issue. Same here that it's barely a drop, and hasn't affected my fluid level as I've been checking it regularly. For the front diff though, I'm quite certain I seated it flush (see pic)! The only thing I'm now remembering is when I was fussing with trying to remove the intermediate shaft from the A.D.D. system on that side, I was levering a pry bar, and there were a few small nicks as a result. I do remember being aware of this though and noting that none of the nicks were in the seal area but rather on the outer edge and I even sanded most of them down a bit to smooth it out. I'll have to take a closer look though as it was kind of difficult to tell exactly where the drip was coming from. Luckily with the manual hubs the CVs are rarely spinning, so it's not a constant leak for now.
  9. May 8, 2025 at 8:50 AM
    #189
    Toyoda213
    Jimmy
    SoCal
    Yea thats the good thing that those cvs are not rotating when unlocked. Thats one of the great things about having manual lock hubs. If you do see it leaking when in use then maybe it wouldnt hurt to just replace it with a new OEM seal.....again lol although replacing it on the truck will be much more challenging.
  10. May 8, 2025 at 8:55 AM
    #190
    dngrrngr
    Western NC
    Totally, it was a great luxury doing the seals for everything off the truck lol. But hey at least I have every single seal part # ready to go!
  11. May 8, 2025 at 9:07 AM
    #191
    Toyoda213
    Jimmy
    SoCal
    from the looks of that picture you posted of the seal the seal seems to be placed all the way in. Maybe its just the angle of the picture.
    check out the video below from timmy the tool man. Skip to 5:35
    Front Differential Axle Shaft Oil Seal Replacement
  12. May 14, 2025 at 12:08 PM
    #192
    dngrrngr
    Western NC
    Yeah I've seen that vid from Timmy! I just double checked again and it is indeed flush, so the mystery continues
  13. May 14, 2025 at 12:19 PM
    #193
    dngrrngr
    Western NC
    Finally got around to installing the axle shims today from Tom Woods. It was a bit of a mental exercise to figure out how to get the necessary space between the leaf pack and axle tube to insert the shims, but in the end my pinion angle is now ~1.3 degrees, compared to about 3.7ish before, which in theory should be well within the "good" range. I took it for a quick test drive and everything seems good, but will test it on the highway soon. FYI for anyone considering pinion angle, I researched doing a carrier bearing drop instead, which could be a perfectly acceptable route, however you will technically be worsening the angle of the front section of the shaft by doing that, so I opted to do it the "right" way and shim the axle, where I'm only improving the rear angle and not affecting the front angle at all.
    I really need to get out and test the 4WD properly now. For anyone familiar with the Brown Mountain OHV trails in western NC, any advice on if a stock height 4x4 1st gen will have any issues? It's supposedly a beginner trail, but I've literally never off roaded before so I'm admittedly a bit gun shy, especially because I don't have an experienced 4x4 buddy to drag with me.
    I'm also starting to compile the footage from my installation process of all the 4x4 stuff! I've got about 2.5 hrs worth as of now, and once I get some test run footage of the 4x4 I should have everything I want footage wise to get the youtube vid together.
  14. Jul 27, 2025 at 4:52 AM
    #194
    dngrrngr
    Western NC
    I was finally able to get a decent 4x4 test done on the sands of the outer banks! I was admittedly a bit nervous as I really didn’t want to get stuck, but after airing down and slapping her in 4LO, I was cruising on the beach with ease. Everything worked really well and it was so rewarding to finally experience the 4x4 capability. I’d like to hit some light trails soon too. I’m still editing my YouTube vid (I’ve got about 2 hours of footage so trying to make it more digestible) but hoping to finish that soon.
    some lingering annoyances from the project are still a small leak where the transfer case meets the transmission (it’s leaking a tiny drop of ATF), and my drivers side CV seal on the front diff is leaking. I don’t think I’m going to bother with the trans leak since it’s so negligible and would require so much effort to address. For the CV seal, I tried seating the axle further into the diff, but ultimately I think I need to just try replacing the seal again, I’ve got the new part, just waiting for the ambition to get in there again.
    I’m also still trying to resolve some minor vibration issues, after installing the axle shim, it seems to be better overall, but I still get a minor vibration at ~60mph that I really want to fix. If anyone has any ideas let me know, I might try balancing my tires again as I noticed a couple of my stick on weights fell off. U joints are all tight, carrier bearing is centered and tight, and all driveline angles are about as optimal as they could be.
    lastly, I’m not sure if this has to do with this conversion project, my valve cover job (with new plugs, coils, and wires), or anything else, but on my OBX drive I averaged over 20mpg for 1,000+ miles, which is by far the best fuel economy I’ve ever gotten
  15. Jul 27, 2025 at 2:01 PM
    #195
    Toyoda213
    Jimmy
    SoCal
    Good stuff thanks for sharing. I never was able to figure out my transmission leak but always kept an eye on the fluid level. For some reason it never read low. I was thinking maybe when I did my 4x4 conversion I may had over filled it? Im not sure. For the cv axle leak i would do the same.replace that seal again. As for the vibration, I had a slight vibration but at 65/70 mph. I did e everything balance tires, checked angles, shims and nothing. I just learn to live with it as the vibrations weren't that bad.
  16. Jul 28, 2025 at 6:24 AM
    #196
    dngrrngr
    Western NC
    You know what I never thought about the possibility that I overfilled it, I wonder if that’s the case? I guess that would be the most likely place for it to spill out if so. It’s also possible I dislodged it a bit or something when getting the transfer case seated, it was a bit of a struggle. Yeahh I think I might need to live with the vibration but it annoys me so much just knowing there’s probably a way to fix it lol
  17. Jul 28, 2025 at 7:52 AM
    #197
    Toyoda213
    Jimmy
    SoCal
    Trust me man I was the same way and finally decided to throw in the towel and just live with it. I mean I tried everything to correct it. So at least we've tried our best. I dont think its worth the stress unless the truck is acting up or driving really strange. Another thing maybe to check. Im sure you did this but check the drive shaft slip yoke to make sure theres grease in there. Aslo greasing up the u joints. Sorry if you did do this and stated on your posted earlier but just thinking of other things to check.
    dngrrngr[QUOTED][OP] likes this.
  18. Aug 5, 2025 at 6:50 AM
    #198
    dngrrngr
    Western NC
    Couldn't help myself...e-locker swap incoming! Picked it up yesterday, it's in much better shape than I expected, so while I planned on a full rebuild of the axle just because, I will most likely just strip it for cleaning and painting and then run it until further repairs are needed. It's from a clean '04 (that was unfortunately wrecked) that had 220K, so more mileage than I hoped for, but the actuator, axle, and all wiring itself is pretty much pristine minus a bit of dirt. The guy I bought it from also gave me nearly the entire frame harness (I believe I've identified the harness as part number 82164-04621) plus the OEM locker ECU and switch, so I'm currently trying to figure out what I need to do to get it ready. My current thought is to just swap in the entire rear frame harness and then I won't need to mess with any retrofitting. Going to start a new thread for this particular build though.
  19. Aug 5, 2025 at 7:37 AM
    #199
    Toyoda213
    Jimmy
    SoCal
    Good stuff man. Sweet project you got going on here. Seems like your are doing it the right way which is nice to see. I say keep it going under this thread.
  20. Aug 6, 2025 at 12:20 PM
    #200
    dngrrngr
    Western NC
    YouTube videos of the conversion are up!
    Part one & Part two
    Like and subscribe if you feel inclined :)
    Tyler. and Toyoda213 like this.
