PreRunner Add a leaf question
Discussion in 'Suspension' started by harshest, Jan 16, 2009.
  1. Jan 16, 2009 at 7:54 AM
    harshest
    harshest [OP] I am the Sofa King
    Michigan
    05 PreRunner SR5
    Fog Light On, Hidden Garage Door Opener, Scanguage II, Weathertech Liners, Cig lighter always on, Door buzzer removed from dash- Upcoming: 5100s for front and rear, set fronts to 2.5" and Toytec AALs.
    I have an 2005 AC TRD Sport PreRunner with the stock suspension. My dealer won't to the rear leaf TSB since I am out of my warranty (that is a whole other thread). My question is, is there an AAL system that I can add with out to much hassle or without having to buy a whole new leaf pack? If I do an AAL do I need to upgrade the shocks all around or can i just do the AAL?
    My main goal is not necessarily to any kind of lift but I want it for the added stiffness when hauling heavy loads.
    Thanks
  2. Jan 16, 2009 at 7:56 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
  3. Jan 16, 2009 at 8:28 AM
    Bearskill
    Bearskill Well-Known Member
    Sac
    06 Access cab PreRunner Sport
    FlowMaster 40 duals out the back, T-Rex grill, Color matched TRD Nerf bars, Icon coilovers set at 2'', 2.75" OME Dakars spring packs, OME Nitro-Charger extended rear shocks, Carrier bearing drop kit, Wheeler's Extended break Lines, Total Chaos UCAs, Mojave Teflons and 31 1/2" Toyo Open Country A/Ts, Pioneer single din unit, Yakima roof rack, Malone roof basket with X2 KC 130w long range Slimmlights mounted to it, Garmin 255w nav, Fire bottle mod, Air Force standard First Aid kit mod, Hidden Muchette mod (don't ask), and 1 huge OCD about my truck.
    I was in the same exact boat as you. I even have the exact same truck except mines an 06. I got the Toytec "long" 2" AAL. $80. Had a shop put it in for me. $75. Have had 0 probs. Totaly satisfied! truck sits nice and level. I have even had some pretty heavy loads in the bed. no bottoming out at all. Can't say enough.
  4. Jan 16, 2009 at 8:29 AM
    OU812
    OU812 ban the term murdered out
    danusa
    Kilroy was here
    13 DblCab LB 4X4
    Nothing yet, brand new!
    I'm in the same boat. I was thinking allpro leaf pack or deaver pack for nice ride with slight lift and firestone air bags for weight hauling. Haven't made up my mind yet. :confused:
    BTW: I liked the previous avatar better :cool:
  5. Jan 16, 2009 at 8:34 AM
    Beefed Taco
    Beefed Taco Taco Vending Machine
    Brian
    My Metal Shop
    99 Taco
    streetacos.com parts!
    If you do a AAL and lift the rear around 1.5" to 2" you don't need longer shocks for normal pavement driving, but if you're gonna go off road and do any kind of articulating you'll want to get some shocks that are a few inches longer because you'll have more drop out than the shocks are long. Too short of a shock isn't good for the shock or the mounts.
  6. Jan 16, 2009 at 10:46 AM
    harshest
    Michigan
    05 PreRunner SR5
    Do you have any pictures of your truck?
    So did I, I changed it back
