PreRunner B.S.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlueTaco07, Mar 7, 2011.
  1. Jan 5, 2019 at 6:31 AM
    #6301
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    You will gain 1" of ground clearance
    The 285s will rub. Likely going to need a cab mount chop and hammer the front pinch weld and then cut some plastic and the rear portion of the front fender well
  2. Jan 5, 2019 at 6:32 AM
    #6302
    05prerun82
    05prerun82 Your local friendly Taco Mule TTC#0202
    Brandon
    Fredericksburg
    2006 aclb prerun
    Memphis sound system volant cold air intake
    Now if I understand not all prerunners have an elocker so if that'd the case then the prerunners without an elocker is just a 5 lug taco with 4x4 suspension
    BassAckwards likes this.
  3. Jan 5, 2019 at 6:34 AM
    #6303
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    No....6 lug with the electronic LSD
  4. Jan 5, 2019 at 6:34 AM
    #6304
    BassAckwards
    The prerunners w/o an elocker are just 6lug 2wd trucks that have 4wd suspension. The 5lugs are all 2wd but they sit lower, im sure youve seen this
  5. Jan 5, 2019 at 6:34 AM
    #6305
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    Why would you even want
    No not all prerunners have lsd
  6. Jan 5, 2019 at 6:35 AM
    #6306
    BassAckwards
    Right they added the auto lsd in 2009
  7. Jan 5, 2019 at 6:35 AM
    #6307
    Plain Jane Taco
    USA
    Anything '09 and up....might actually be '08 and up have the electronic LSD
  8. Jan 5, 2019 at 6:35 AM
    #6308
    BassAckwards
    Throw a locker in it and its a beast mang
  9. Jan 5, 2019 at 6:36 AM
    #6309
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    Elocker and auto lsd same thing
  10. Jan 5, 2019 at 6:37 AM
    #6310
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    I know I love my elocker it saved my ass even with dem.hiway tires
    BassAckwards[QUOTED] likes this.
  11. Jan 5, 2019 at 6:37 AM
    #6311
    BassAckwards
    No.. while the auto lsd has worked good for me like in sand for example, having the locker was a night and day difference
  12. Jan 5, 2019 at 6:37 AM
    #6312
    Plain Jane Taco
    USA
    Nope....different animal
  13. Jan 5, 2019 at 6:38 AM
    #6313
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    What I thought
  14. Jan 5, 2019 at 6:38 AM
    #6314
    BassAckwards
    These trucks are impressive with a locker, some good tires, sliders, and a heavy foot
  15. Jan 5, 2019 at 6:39 AM
    #6315
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    So Suburu and them Evo Lancers have lsd
    jboudreaux1965 and BassAckwards like this.
  16. Jan 5, 2019 at 6:39 AM
    #6316
    BassAckwards
    I think most of those are AWD w/ lsd's, yes
  17. Jan 5, 2019 at 6:40 AM
    #6317
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    Im.guessing the way that works is one wheel spins the other one unlocks abd spins to understand power of the engine
  18. Jan 5, 2019 at 6:41 AM
    #6318
    Plain Jane Taco
    USA
    The electronic LSD uses the ABS sensors to detect wheel slip. When it senses slip in one wheel it will apply the brake to that wheel and transfer power to the other side (open diff). Works pretty good. Sometimes I just turn it completely off by holding down the TC button for 5 seconds
    BassAckwards and 05prerun82 like this.
  19. Jan 5, 2019 at 6:41 AM
    #6319
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    So awd technically is better then 4wd
  20. Jan 5, 2019 at 6:42 AM
    #6320
    BassAckwards
    Not sure exactly how it works. I do know its great for traction though. My moms fj cruiser is AWD, and you can always put the power down, its awesome, even when its wet
