PreRunner B.S.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlueTaco07, Mar 7, 2011.
  1. Jan 5, 2019 at 6:43 AM
    #6321
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I would argue yes if you have the ability to lock the center diff
  2. Jan 5, 2019 at 6:45 AM
    #6322
    05prerun82
    05prerun82 Your local friendly Taco Mule TTC#0202
    Brandon
    Fredericksburg
    2006 aclb prerun
    Memphis sound system volant cold air intake
    Now how does the new 4wd work without locking hubs
    BassAckwards likes this.
  3. Jan 5, 2019 at 6:47 AM
    #6323
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    Cause when I was in high school my 83 cheby blazer had locking hubs and if you wanted 4wd you had to get out and physically lock the front wheels
  4. Jan 5, 2019 at 6:48 AM
    #6324
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    There are different types of LSD. Our Tacos use an electronic system using the ABS and braking system. It works by taking advantage of the tendencies of an open diff.
    Other LSD systems use a viscous coupling. That's a fluid that almost instantly thickens during slip allowing the wheels, either side to side or front to back, to essentially lock together. That can happen at either axle, though usually just the rear or front to back if the center diff is a LSD.
    Most full time AWD use some sort of electronic or viscous coupling center diff and some also have the same setup in the rear diff
  5. Jan 5, 2019 at 6:52 AM
    #6325
    Plain Jane Taco
    USA
    And drive on pavement. Not possible with 4WD because there is no center diff to "differentiate", hence the term, between the wheel speed of the front and rear axles. You will experience "binding" in 4WD on a high traction surface if you turn
    BassAckwards[QUOTED] likes this.
  6. Jan 5, 2019 at 6:54 AM
    #6326
    Plain Jane Taco
    USA
    The hubs are always locked. It's decoupled within the front diff.
  7. Jan 5, 2019 at 6:55 AM
    #6327
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    That's why Suburu and lancer have that wheel speed controler that controls speed between front and rear wheels
  8. Jan 5, 2019 at 6:55 AM
    #6328
    BassAckwards
    In the FJ, it has a twin stick that you use to lock the center diff. You drive normally in High unlocked. Then you can select High or low with the center diff locked, which forces the front and rear power split to be 50/50
    With the center diff unlocked, its a 40/60 power split front/rear
    Plain Jane Taco likes this.
  9. Jan 5, 2019 at 6:56 AM
    #6329
    BassAckwards
    correct!
  10. Jan 5, 2019 at 6:57 AM
    #6330
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    Chet driving on payment with elocker on a pain in the ass
  11. Jan 5, 2019 at 7:02 AM
    #6331
    Plain Jane Taco
    USA
    In some ways the 6-speed AWD FJs had the perfect system. It was a permanently engaged system that allowed normal driving on all surfaces. All 3 diffs acted like regular open diffs under most circumstances. But when slip was detected it could begin to lock up the rear and center diffs. Plus you could actually lock the rear and center diffs to perform just like a 4WD vehicle in low traction situations.
    The AWD FJs were only available with the 6-speed manual. Autos had the regular part time system...much like the Tacos
  12. Jan 5, 2019 at 7:04 AM
    #6332
    BassAckwards
    Couldn't agree more! The FJ's were done right from the factory. Made in Japan, and the difference in quality shows imo.. Just a much better design
  13. Jan 5, 2019 at 7:04 AM
    #6333
    Plain Jane Taco
    USA
    Yep. On a high traction surface the rear wheels will fight each other in a turn. The outside wheel has further to travel than the inside wheel in the same time frame....so it spins faster. The lockers purpose in life is to prevent that.
    05prerun82[QUOTED] likes this.
  14. Jan 5, 2019 at 7:07 AM
    #6334
    Plain Jane Taco
    USA
    I don't think being made in Japan had anything to do with it. I think it was the design and nature of the vehicle
  15. Jan 5, 2019 at 7:33 AM
    #6335
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    Dont they have a plant in North Carolina
  16. Jan 5, 2019 at 9:15 AM
    #6336
    ChadsPride
    Sponsored by TacomaWorld.com
  17. Jan 5, 2019 at 10:23 AM
    #6337
    ripcalifornia
    ripcalifornia Trok
    Cal (Kyle)
    HB CA
    2014 AC
    patches
    so much talk about 4x4 and AWD in the prerunner thread, blasphemy if you ask me:eek:
    Looking sweeet as always man :broccoli:
  18. Jan 5, 2019 at 10:27 AM
    #6338
    christian06
    christian06 Well-Known Member
    Cali
    Stockish 06 sport prerunner
    Grille, floor mats, navi, heated seats, bed cover, fj wheels, custom door cloth.
    that's what I was thinking, nobody cares about your pt cruzer or your suburu. this is a prerunner forum,
    ChadsPride likes this.
  19. Jan 5, 2019 at 10:31 AM
    #6339
    ripcalifornia
    ripcalifornia Trok
    Cal (Kyle)
    HB CA
    2014 AC
    patches
    aLL wHeEl dRivE bRo
    dumontrider and ChadsPride like this.
  20. Jan 5, 2019 at 10:42 AM
    #6340
    christian06
    Cali
    That's nice, but not a prerunner, maybe the guys in the pt Cruzer forum might enjoy that
    ChadsPride and 05prerun82 like this.
