PreRunner Front Spring options
Discussion in '1st Gen. Tacomas (1995-2004)' started by gzig5, Feb 16, 2023.
  1. Feb 16, 2023 at 7:18 AM
    gzig5
    gzig5 [OP] Well-Known Member
    Mequon, WI
    2002 Tacoma PreRunner 2WD
    I'd like to replace the front springs when I install new Bilstein 4600 shocks to match the new ones in the back. I want to keep the stock ride height with stock rate springs because it's a daily driver and won't see a lot of off road action at this time. The rear springs are stock and truck is sitting level with slight nose down even with 360lbs of sand in the front of the bed. I went to order stock springs from Toyota and found that the passenger spring has been discontinued and the parts guy was zero help on suggesting an alternate. So I started looking for aftermarket alternatives. Seems the OME springs all give a lift and have to be used with their shocks, so don't seem to be a solution for me. Moog 81082 seemed to get good reviews but all the normal sources are out of them so maybe they have been discontinued too? HUSKY SPRING SC20520 is the only one I've found so far that seems to be a proper substitute for my truck.
    Does anyone have an alternate source for the OEM Toyota or MOOG springs? Am I missing other alternatives? Any feedback on the Husky coil springs?
    Details: '02 PreRunner, double-cab, 3.4l automatic, 2WD Off-road suspension.
    Toyota parts:
    Driver side front coil spring 41832-AD170 available
    Passenger side front coil spring 41832-AD160 discontinued
    Moog 81082 currently unavailable
    Husky SC20520 available from RockAuto
  2. Feb 16, 2023 at 8:14 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Often times people will pair the 4600s with OME 880 springs. Wheelers off road can even pre assemble the coilover for you. It's a good option to consider. And I wouldn't worry about any spring rate difference with the 880 vs stock, as you're a v6 double cab, so you'll have a little more weight than say a 4 cylinder extra cab.
    MalinoisDad and gzig5[OP] like this.
  3. Feb 16, 2023 at 8:46 AM
    gzig5
    Mequon, WI
    I gave Wheelers a call and they don't carry the 4600 shocks and the guy said that they are not compatible with the 880 spring. But, they do have the 5100 shock pre-assembled with the 880 spring for $478 per pair. It's a little stouter than stock and he calculated it would give a 3/4" lift, which isn't terrible. Need to give that some consideration. He said it would be fine for what I described, but I tend to drastically over-analyze these kind of problems.:rolleyes:
  4. Feb 16, 2023 at 9:13 AM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    I have the 880 with OME shocks on a double cab v6 like you and it gave me 1.5" of lift.
  5. Feb 16, 2023 at 1:40 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
  6. Feb 16, 2023 at 4:25 PM
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    I vote do it. If you don't want any lift that you CAN avoid, keep the 5100s on the lowest setting, or 0. I'm pleased with my 5100s paired to 881 coils on my Prerunner. And I'm not a double cab.
  7. Feb 17, 2023 at 6:07 AM
    gzig5
    Mequon, WI
    I think I'd roll the dice with the Husky's before a mystery spring off ebay. If they completely suck I would still have a chance of returning them to RockAuto.
    I did find that it looked like the Moog spring could be special ordered with a two month lead time. Or at least it appeared so from their website.
    The 880 isn't out of the running yet, but it doesn't look like there are any other options outside of the generic ebay stuff so unless I can find an OEM spring NOS somewhere I shouldn't have to ponder too much longer.
  8. Mar 30, 2023 at 8:39 PM
    MONTYMTB
    MONTYMTB Member
    Alabama
    2001 Prerunner TRD DC
    What did you end up going with? I'm in the same boat, and would like to hear how it turned out.
  9. Apr 5, 2023 at 3:08 PM
    gzig5
    Mequon, WI
    I've been distracted by other projects and haven't pulled the trigger yet. I'm tempted to just put new shocks in it and leave the springs as is since it is sitting level. I know it needs shock at 170k miles, the rears were blown for sure.
