Prerunner front wheel bearing same as 4wd???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by YOTACO, Oct 10, 2012.
  1. Oct 10, 2012 at 6:55 PM
    YOTACO
    YOTACO [OP] Active Member
    Bradford
    Birmingham AL
    05 PreRunner
  2. Oct 10, 2012 at 9:52 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    That is definitely 4x4 kit. Notice two seals. Bearing itself should be the same. I would look just for pure runner kit. Also you can get cheaper that bearing in some other websites.
  3. Oct 10, 2012 at 9:53 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Spindle and hub assembly I believe is the same. This would include the bearings.
  4. Oct 11, 2012 at 2:39 AM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    that looks like the 4wd bearing. The 2wd bearing has the center portion enclosed with a spacer to carry the load.
  5. Oct 11, 2012 at 5:31 PM
    YOTACO
    Bradford
    Birmingham AL
    05 PreRunner
    does anyone know of a website i can get an OEM wheel bearing for my pre runner? maybe a link to it?
  6. Oct 11, 2012 at 5:35 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
  7. Nov 11, 2012 at 1:41 PM
    myfirst06taco
    myfirst06taco Well-Known Member
    Clarke county ,VA
    06 SR5 4X4
    5100's eibach coils , Allpro leaf pack , roll up tonneau cover with led bed lights, hids, homertaco grill
    :confused: I'm ready to replace my wheel bearings on my 06 4x4. Prices vary soon much , I picked up a set from napa for $135 each plus $11 for seals. I checked rock auto and they start at $60 wtf. Can I get a whole assembly (bearing already pressed in) for around $200? Or can anyone help with a parts list with the best prices?
  8. Nov 11, 2012 at 1:49 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
  9. Jul 19, 2013 at 5:36 AM
    sirschwiegs
    sirschwiegs Member
    SL
    savannah
    06 Prerunner 4.0
    K&N intake
    Only place u can get prerunner hubs and bearings. The bearing are simple to find its the prerunner hubs that are mysteries. But blue pit will custom assemble the front assembley w/ hub and bearing fur under 400 which is a steal if u can't get Toyota parts on your own
  10. Jul 19, 2013 at 5:38 AM
    sirschwiegs
    sirschwiegs Member
    SL
    savannah
    06 Prerunner 4.0
    K&N intake
    Btw prerunner has 4x4 wheels but not axle so 4x4 hubs do not work and 2x4 Tacomas have 5 lugs while prerunners have 6 so u really get screwed with the Pre and the new hubs
  11. Jul 19, 2013 at 5:39 AM
    sirschwiegs
    sirschwiegs Member
    SL
    savannah
    06 Prerunner 4.0
    K&N intake
    Bluepitbearing.com
    Ask Andy about prerunner and he will make it happen. Got mine within days of ordering.
  12. Jul 26, 2013 at 10:23 PM
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    I can do a pre runner complete assembly for $325
    4x4 complete assembly for $205 :cool:
  13. Jul 27, 2013 at 4:44 AM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    I'm pretty sure the only difference is the hub. I think prerunners have like a plate on the back side where the axleshaft would be on a 4x4. It should just unbolt and then it would be just like doing the job on a 4x4. Honestly if you are mechanically inclined and have access to a press it's not a hard job at all if you remove the entire spindle. Then you can use the spindle to hold it and press the hub out. I wouldn't go for the cheapest bearing you can find either. I used SKF on the last 4 I did. Mine were done on my 05 at the dealer around 75k miles and I'm pretty sure they will be due again around 150k.
  14. Aug 20, 2013 at 8:30 PM
    nj636
    Kev
    Jersey
    you need the SST to remove & torque the nut on a pre runner hub.
