Prerunner hubs and bearings
Discussion in 'Wheels & Tires' started by sirschwiegs, Jul 12, 2013.
  1. Jul 12, 2013 at 11:32 AM
    sirschwiegs
    sirschwiegs [OP] Member
    SL
    savannah
    06 Prerunner 4.0
    K&N intake
    I need to replace a front bearing on my 06 Pre.
    The problem is that prerunner use the 6 lug hubs, like an an 06 4x4, while regular 2WD use a 5 pattern.
    Do I buy 4x4 hubs and bearing assembly?
    Or 6lug hubs and 2wd bearings?
    Any other thoughts or advice?
  2. Jul 12, 2013 at 11:44 AM
    Tacorriendo
    Tacorriendo Well-Known Member
    Fred
    Texas
    2009 DCSB 4x4 Off-Road
    Front lift, ride rite air bags, side steps, rear camera switch.
    I just ordered rear wheel bearings for my 4x4 from partsgeeks.com (cheapest after extensive searching) they specify application on their website for the different tacoma models. Eg. Prerunner, 2wd, or 4x4. Check them out.
  3. Jul 12, 2013 at 1:15 PM
    sirschwiegs
    SL
    savannah
    06 Prerunner 4.0
    K&N intake
  4. Jul 12, 2013 at 4:36 PM
    Tacorriendo
    Fred
    Texas
  5. Jul 13, 2013 at 8:28 PM
    sirschwiegs
    SL
    savannah
    06 Prerunner 4.0
    K&N intake
    If I have an extra hub with new bearing already pressed in, I can do the job in less time and w/o the press. Then get the old hub fitted with a new bearing assembly, which would then be on standby till the other front wheel bearing goes. I appreciate the help but there is a way to do this I just need to know if 4x4 front hubs and bearing would work on a 2x4 prerunner. Im fairly certain the answer is yes but fairly don't mean much.
  6. Aug 23, 2013 at 6:17 AM
    BamaToy1997
    BamaToy1997 ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    4X4 bearings are identical between the Prerunner 6 lug, and the 4X4 Base Tacoma 6 lug. However you can't properly use the 4X4 assemblies on a prerunner because of the way the bearing and hub assembly is held together. They are held together in two different ways.
