prerunner into a 4x4
Discussion in 'Technical Chat' started by taco@you123, Oct 22, 2008.
  1. Nov 1, 2008 at 9:22 AM
    #61
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    Whew... That one is a quick and dirty. I think I need a shower just after reading those two posts. :p
    Ok, yeah... now you are just showing off. :cool:
  2. Nov 1, 2008 at 9:37 AM
    #62
    jtaco
    jtaco Well-Known Member
    07,trdOR,DC,4x4,v6,saw2.5s,OMEdakars,LRarms
    saw2.5s,AEMshortair,skyjackershocks,LRa-arms,OME dakars,Alpine,JL audio 6x9 3 way in front doors
    ok is this because water or mud(wet) touched something and shorted it out? what could it get to ?
  3. Nov 1, 2008 at 4:28 PM
    #63
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Trail debris can grab and yank off whatever it can get ahold of. For the record, My D0dge Dakota had an electric transfer case, and it never left me with out 4 wheel drive. Many Tacoma owners have never had an issue with their electric Transfer cases. BUT, If given the option, I choose a manual one.
  4. Nov 1, 2008 at 4:47 PM
    #64
    jtaco
    yea but then no warrranty and no 4.0L and all that comes with a 06-08 taco, with rear diff locks and 4x4 one has got to get u out, and if elocker goes out then it stays locked so u get out either way. then repairs of course. i just have looked for about 3 years and everything(4x4) under 05 is in such horrible condition, oh they look good on the outside but thats it by far..
  5. Nov 1, 2008 at 4:50 PM
    #65
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You can still have the 4.0. The warranty, thats a big grey area. Personally for me, It can be better to fix an issue myself, rather than waste my time at a dealer ship.
  6. Nov 1, 2008 at 6:39 PM
    #66
    jtaco
    3.4 is the v6 under 05, and i havent ran into an 05 or under yet that was still under warranty and i have looked and looked and looked, its all good to me if they do it for free.rather then me spending all types of money for parts, then finding and having to pay someone to install. my health is not good for all that jazz.
  7. Nov 1, 2008 at 6:40 PM
    #67
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    ^If thats a question then the answer is yes. If not then sorry.
  8. Nov 1, 2008 at 6:42 PM
    #68
    jtaco
    i was sayin that 3.4 is all u get under 05
  9. Nov 3, 2008 at 10:44 AM
    #69
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K02 AT’s RCI skid Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
    I didn't see that you had a later model truck, sorry about that. At least it gives you an idea of how much it costs though.....:rolleyes:
  10. Apr 9, 2009 at 12:39 PM
    #70
    chabro
    chabro Well-Known Member
    Houston
    2011 SR5 4x4 DC
    I have been hunting around for parts for a prerunner conversion. A few questions I'm trying to find answers to:
    Is the A340F a straight swap for the A340E? I know I'll need to cut the floor for the shifter but I was mainly concerned about cooling lines, linkage, wiring etc.
    Can the RZ bellhousing on the A340E be used to replace the VZ housing on a A340F?
    Does the A340F use the same crossmember to support it as the A340E but just a different mount?
    Are A340F drive shafts different sizes depending on access cab and regular cab? ie are they interchangeable?
    Can a ADD front diff be used for the conversion?
    Can ADD be disconnected to be made manual?
  11. Apr 9, 2009 at 12:57 PM
    #71
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Your best bet is to not use an ADD front end. There are plenty of 2000 year front ends with manual hubs. Not sure on the tranny questions, though.
  12. Apr 9, 2009 at 1:08 PM
    #72
    chabro
    Houston
    2011 SR5 4x4 DC
    Thanks for that Chris. Any suggestions on finding one? Not having much luck so far. Found a transmission and transfer in Phoenix which I thought was going to be the hard part.
  13. Apr 9, 2009 at 2:06 PM
    #73
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    check a junk/wrecking yard. They are out there. :)
  14. Apr 9, 2009 at 2:06 PM
    #74
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Also, check on TTORA.com and ask some people that have done SAC's...they may have their old front end parts.
  15. Apr 9, 2009 at 3:10 PM
    #75
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    i second the idea about watching on TTORA...someone should be cutting off their IFS soon and selling the parts you need
  16. Apr 9, 2009 at 4:58 PM
    #76
    chabro
    Houston
    2011 SR5 4x4 DC
    I put an ad up over at TTORA. Until parts start showing up I'll just install my ARB rear locker and new 4.88 gears:)
  17. Apr 29, 2009 at 10:57 AM
    #77
    chabro
    Houston
    2011 SR5 4x4 DC
    Found a wrecked 2000 4cyl 4x4 with 44000 miles. Able to get front diff non ADD with 430 gears (same as mine), ATransmission and Manual transfer case, front spindles with manual hubs and drive shafts for $2700..gulp. Actually price isn't so bad I guess for low mileage parts and exactly what I want...all manual. The price includes delivery to the door and one-year warranty on parts.
    Does this seem reasonable? Would be good to get the complete package in one. Could probably find parts cheaper but it take a lot of time and searching. Comments??
  18. Apr 29, 2009 at 2:33 PM
    #78
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I think thats a good deal. Especially being all manual. :)
  19. Apr 29, 2009 at 2:47 PM
    #79
    chabro
    Houston
    2011 SR5 4x4 DC
    Thanks Chris. Like I said, I could spend the next year looking and buying a little at a time. Could prob save a grand if I'm lucky but time is money! Thanks again!
  20. Apr 29, 2009 at 4:36 PM
    #80
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Haveing a all manual front end fall in your lap like that is worth the extra 1K. :)
