prerunner into a 4x4
Discussion in 'Technical Chat' started by taco@you123, Oct 22, 2008.
  1. Jun 12, 2013 at 5:36 PM
    #121
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Bringing this back from the dead. I have been doing alot of research but i still havent got the answer to this question: (here we go)
    So mine is an automatic 2003 double cab pre-runner 2wd (4CYL 2.7L)
    -Can I convert this to a 4wd keeping it automatic? I guess im confused because i have seen 4x4 4cyl but they are 5 spd correct?
    and the only automatics 4x4 i have seen are the 3.4 V6
    school me up fellas. Thank you in advance
  2. Jun 12, 2013 at 6:45 PM
    #122
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Yes you can. I have the auto 2.7l in my truck.
  3. Jun 12, 2013 at 6:48 PM
    #123
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    whaaa? i thought you were a v6?
    what gears are you running?
    what gears would i run should i want...say...42s sometime in the future lol. would like it at least move a bit over 45 on the street haha.
  4. Jun 12, 2013 at 6:57 PM
    #124
    Supra TT
    Eric
    Indiana
    5.38 gears. I've had it up to 75. Takes a extra bit... I'd say 0-60 is only about 2 seconds slower than stock. The truck was never fast haha.
    And with 42's the 5.38s will work. You don't really wanna go too low. And if running 42's you ABSOLUTELY need a crawl box. I need one if I ever go bigger.
  5. Jun 12, 2013 at 11:03 PM
    #125
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    gotcha.
    thats my plan after school. I want to take the macho taco approach, just on my x cab. d60 with leafs and between 40s and 42s. I was thinking a super charger to move the tires but if the 5.38s will work to just drive around on then fuck the super charger, crawl box it is!
  6. Jun 13, 2013 at 9:25 AM
    #126
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Hey thanks bro, I was reading through your build yesterday. I think i want IFS. Dont have tons of money for a SAS, and it gets driven alot too.....What would you say the cost for something like this is? No labor, just parts
  7. Jun 13, 2013 at 6:59 PM
    #127
    Supra TT
    Eric
    Indiana
    Depends where you find your parts. A t-case can be found for $150. Get a shifter with it, if not maybe $50. The front diff with the axles and hubs and stuff can be found for probably under $500. A front DS can also be found for probably $100, along with shortening your rear DS which can cost about $150.
    What you really need to do is find a totaled 4x4 truck with a J-shift t-case and swap it in. It can be done for under $1000.
  8. Jun 13, 2013 at 10:19 PM
    #128
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Damn. That's not bad at all! Thanks brotha!
