prerunner lift question?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 05yota, Dec 30, 2010.
  1. Dec 30, 2010 at 2:16 PM
    05yota
    05yota [OP] Well-Known Member
    Beaufort SC
    05 Dbl Cab Long Bed
    Alpine IVA-W205 Double din TV, 10in Memphis shallow mount sub, Rockford Amp, 23in Akuza Bounce Rims!!!
    ok so i have decided to lift my 05 tacoma dbl cab long bed and get rid of the big rims look... i have sat on here for the past 3 hrs and researched the site about spacers vs the 5100s so on and so forth... to get started its gonna be for looks i like the feel of a truck that sits up higher so i am looking for the right choice that wont break the bank but will last.. i was hell bent on the toytec 3" spacer but then i saw the 3" that had new coils with a spacer whats the difference??? then i saw alot guys on here running the 5100s??? i am so confused right now... all i want is my truck is about three inches of lift and to be able to put a thicker tire and still maintain a decent ride quality??? PLEASE HELP!!!!
  2. Dec 30, 2010 at 2:31 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    My suggestion is this. You won't need the DD though.
  3. Dec 30, 2010 at 2:53 PM
    tony92629
    tony92629 Well-Known Member
    Tony
    Dana Point
    2010 White Tacoma Prerunner
    5100's all the way around. Front set at .85. Camburg Spindles. Camburg Uniball 1.25 UCA's. Total Chaos LCA skid plates. Custom Deaver 10 pack rear leaf spring. BFG AT KO's 285/70/17, Weathertech floor liners, Wet Okoles. Midland CB/PA, Firestick.
    The 5100's are the best quality bang for the buck - the front's are adjustable and will had about 2.5 inches of lift. The ride quality is better than stock billies that come with the TRD package.
    The 5100's were the first modification I did. Then came the Camburg 1.25 Uniball UCA's and the Camburg Spindle lift - and now working on the rear leaf spring set up. Still riding the 5100's. I am sure that I will get some Fox Shox down the road, but for now...yes, I am hooked! I am happy with the set up and ride they have provided so far.
    If you are thinking about upgrading down the road, go with the 5100's on all 4 corners. You dont have to break the bank with the High Performance or LT coil overs and remote reservoir shocks - front set alone could cost over $1000. The 5100's are very respectable.
    On the other hand...If you are just looking for a little lift for the daily driver - Spacers and blocks will be the cheap and easy way to go. Rear blocks will run less than $100.00 and front spacers are less than $100.00 plus install.
  4. Dec 30, 2010 at 2:54 PM
    tony92629
    Tony
    Dana Point
    ^ x2
  5. Dec 30, 2010 at 3:01 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    The best ride and alignment lift for a 2 by is hands down new spindles but they come at a cost. The general consensus (as stated before) is that the 5100's are the best bang for the buck if you don't have a grand laying around.
  6. Dec 30, 2010 at 3:49 PM
    DriverSound
    DriverSound Señor Member
    SoCal
    15 DCSB OR 4x4 & 17 AC SR 4x4
    Too few to list.
    Who sells this set?
  7. Dec 30, 2010 at 6:58 PM
    romafern
    romafern Well-Known Member
    Rob
    Olympia, WA
    stock and very pissed about the issues
    Machine gun mount. Would love to blow the shit out of it since it has nothing but issues. QA at Toyota USA is shit. Start making them in Japan for Christ's Sake!
  8. Jan 8, 2011 at 9:58 PM
    T.J.
    T.J. Taco Jockey
    TJ
    North Port, FL
    05 PreRunner SR5 V6
    Century Truck Topper, custom made "Batman" center caps, satoshi mod (Thanks tons, TY!), Hella 500 grille lights, painted radio, climate control, and radio surround panels, painted rear bumper
    Not to hijack the OP's post, but if using this kit^, and wanting to run 285/70/17 tires, would wheel spacers be useable if lift was set to 3"? Or would their not be enough clearance?
  9. Jan 9, 2011 at 1:48 AM
    jackrules
    jackrules Well-Known Member
    Jack
    San Diego
    10 PreRunner Double Cab SR5 TRD Sport LB
    If im correct, i think that will work but you might have to do some cutting....
  10. Jan 10, 2011 at 1:03 AM
    T.J.
    T.J. Taco Jockey
    TJ
    North Port, FL
    05 PreRunner SR5 V6
    Already had to to get 265/70/17's under there with stock setting. Might be alright then with the lift. Thanks!
  11. Jan 10, 2011 at 6:27 AM
    NoMallCrawlTaco
    NoMallCrawlTaco © "HELL FUCK YEAH!" © COPYRIGHT FOR MY PROTECTION!
    Arizona
    4" Camburgs Icon AAL 3 Pac BLHM Tacoshi Grill More to come...
    Camburgs!
    Wait till you get ready to get new tires.
    It gets real crazy!
