Prerunner lift - spindles or ????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bizjettech, Feb 15, 2012.
  1. Feb 15, 2012 at 8:10 AM
    bizjettech
    bizjettech [OP] Well-Known Member
    Sunny Florida
    Been reading a lot about the spindle lifts for the 2nd gen prerunner. I just dont want to move the front wheels any further outboard like the spindle lifts do.
    That said, what are others doing to lift their 2nd gen prerunner?
    I have a 2011 and want to lift it around 3 inches. I dont plan any off-road.
    All highway. Looks only.
    Why are the spindle lifts so popular?
  2. Feb 15, 2012 at 8:12 AM
    TurfTaco
    TurfTaco Is there a long john silvers on the island?
    URE
    07 Deer Collector
    285/75-16 BFG KM1's, AVS vent visors, AVS hood shield, pioneer avic F900BT, pac steering wheel control adapter, Boyo rearview camera, pac ipod interface, tinted windows, Toytec 1.5 AAL, Bistein 5100s (front set to .85) Eibach coils, Black headlights, grillcraft black billet insert, N-fab light bar, 4 Hella FF700 lights & color matched grille, Sockmonkey bedside decals. 16x8 MT sidebiters, Weathertechs, Fabtech spare carrier.
    I have 3" of lift via 5100s @ .85, 1/4" top plate spacer and eibach coils. Running 285s. If I had it to do over again, I would run spindles for more lift.
  3. Feb 15, 2012 at 8:14 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    spindles will give you more clearance (who cares its for looks right? lol)
    spindles are your best bet, or you can go to a.... drop bracket for a 6 inch lift:( what size tires are you wanting to run?
  4. Feb 15, 2012 at 8:20 AM
    bizjettech
    Sunny Florida
    Looking to run 265/75/16 or 265/70/17......both are around 31.5 diameter and 10.5 wide
  5. Feb 15, 2012 at 8:25 AM
    TurfTaco
    URE
    07 Deer Collector
    You don't need a 3" lift to run a 265. You can run 5100s set at 1.75" and keep your stock coils.
  6. Feb 15, 2012 at 8:27 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    You can fit both of those at stock height.
    Spindles are so popular because they do not change any of the suspension geometry or the ride characteristics from stock. All they do is move the wheel hub down 3.5-4".
  7. Feb 15, 2012 at 8:28 AM
    97yota4wd
    Eric
    Mesa, AZ
    31.6s and spindles would look goofy.... if your just getting those id get billies set at .85
  8. Feb 15, 2012 at 8:31 AM
    bizjettech
    Sunny Florida
    what is the most popular tire size for the 4 inch spindle lift?
    I dont want a really wide tire, tall is OK, just dont want super wide
  9. Feb 15, 2012 at 8:31 AM
    TheGloryFades
    TheGloryFades Well-Known Member
    Seth
    Arizona
    '13 toaster
    255/85/16
  10. Feb 15, 2012 at 8:46 AM
    97yota4wd
    Eric
    Mesa, AZ
    spindles only push out your tires like 3/4 of an inch, its not like long travel or anything..
