prerunner lift?
Discussion in 'Toyota Trucks & SUVs' started by Swampmonkey, Sep 28, 2011.
  1. Sep 28, 2011 at 6:51 PM
    Swampmonkey
    Swampmonkey [OP] Well-Known Member
    Wes
    Fairhope, AL
    2011 Prerunner TRD DC
    UWS black low profile toolbox, TRD intake, TRD exhaust, TC uca's, Rear 2" toytec aal, OME Front and Rear shocks, OME 885s, NFABs
    What is a good 2" lift for a prerunner? readylift, daystar
  2. Sep 28, 2011 at 7:38 PM
    Swampmonkey
    Wes
    Fairhope, AL
    been seeing a lot of that in posts. can i just use 5100s front and back?
  3. Sep 28, 2011 at 7:40 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    Ur gonna need new springs and leafs too...
  4. Sep 28, 2011 at 7:41 PM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    yes.
    they have adjustable 5100s for the front that can be used to lift the front of your vehicle and make it level with the back, and regular 5100s to replace the rear shocks for a better ride.
    take a peek around downsouthmotorsports.com
    they have a great price on billies and great customer service.
    if you want to lift the back a tad as well (to keep some factory rake) then you can get an add a leaf.
    edit.
    damn i was beat to it.
  5. Sep 28, 2011 at 7:41 PM
    J0hnMata
    J0hnMata Well-Known Member
    Orange County
    09 PreRunner
    BHLM, bilstein 5100's, satoshi grillcraft grill, k&n cold air intake, tinted windows all around, interior map and dome light led's, hid fog lights and headlights, yellow fog light lenses, black lower valence.
    in front yes the 5100 will bump you up a couple inches, you can use them in the rear but they wont give you any lift. You are going to need an AAL (Add A Leaf) kit which isnt expensive either.
  6. Sep 28, 2011 at 7:42 PM
    J0hnMata
    Orange County
    09 PreRunner
  7. Sep 28, 2011 at 7:53 PM
    Swampmonkey
    Wes
    Fairhope, AL
    what about leveling front to stock back. can that be done with billys at front set on .85
  8. Sep 28, 2011 at 7:58 PM
    Swampmonkey
    Wes
    Fairhope, AL
    so the billy 5100s are even a better ride than my brand new trd billy shocks. and i could go 265 70 16s in future with those
  9. Sep 28, 2011 at 8:00 PM
    hudhawk
    hudhawk #texasforever
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    set billies at 1.75 and you should be farily level with stock back. you can go to 265/75-16 on a stock suspension. 265/70-16 is stock size
  10. Sep 28, 2011 at 8:01 PM
    Maverick904
    Kameron
    Northeast Florida
    Yes the truck can be leveled to the sock rear height... not 100% sure on the setting. The front may ride a little stiffer due to the preload on the coils, yet it will ride better than say spacers or a procomp 3" lift such as I have.
    You should be able to run the 265/75/16 tires on your stock suspension so there will be no problem with the truck leveled.
  11. Sep 28, 2011 at 8:10 PM
    Swampmonkey
    Wes
    Fairhope, AL
    Level to the rear will give me the look I want. Will I need any kind of alighnment
  12. Sep 28, 2011 at 8:13 PM
    hudhawk
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    yes you will need an alignment
  13. Sep 28, 2011 at 8:14 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    I was nose high when I set the fronts to 1.75" with stock rear
  14. Sep 28, 2011 at 8:19 PM
    hudhawk
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    ive actually seen two tacomas, both with stock rears and front billies at 1.75 and one was level and one looked a tad nose high.:confused: i guess it depends on how sagged your rear leafs are
  15. Sep 28, 2011 at 8:35 PM
    Maverick904
    Kameron
    Northeast Florida
    did they have the same cab?
  16. Sep 28, 2011 at 8:35 PM
    TexasTacoma37
    And motor?
  17. Sep 28, 2011 at 8:48 PM
    hudhawk
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    yes they were both double cab V6
  18. Sep 28, 2011 at 8:54 PM
    Maverick904
    Kameron
    Northeast Florida
    nothin a 1" aal cant fix lol
  19. Sep 29, 2011 at 8:20 AM
    Swampmonkey
    Wes
    Fairhope, AL
    Could I put the shocks on myself then align or do you guys recommend getting it all done. Also bought a warranty with the truck and this stuff will probably void it but I can't stand how cool all of the tacos are in here
  20. Sep 29, 2011 at 12:39 PM
    hudhawk
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    Yes you can put the shocks on yourself, most do. Then get an alignment. Your warranty should be fine.
