prerunner non trd ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BAMFTACO, Jul 1, 2010.
  1. Jul 1, 2010 at 1:33 PM
    BAMFTACO
    BAMFTACO [OP] Another day another beer
    Jośe
    Woodlandland hills , CA
    Taco
    Lift- king 2.5 with light racing uppers,tc coil bucket gusset, 4 in spindles,timbern bumps all around ,wheelers 3 addaleaf, ato shackle flip kit with 6 inch HD shackles. Armor- tire gate, custom tube bumper, kr fab rear bumper,trail gear wiy 78 in sliders Performance-intake manifold spacer, hps silicone hoses Random stuff- kenwood head unit,b&m t shifter, hood bug deflector, rear dust lights with custom bed bar and hi lift mount.
    I've done reseacrh but still not sure wat size the rear end on my truck is?
    Does anyone have a lock right automatic locker on prerunner non trd model tacomas if you do how much did it cost and wat size diff does the rear end have?
  2. Jul 1, 2010 at 1:36 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    IIRC, it's an 8.4"
  3. Jul 1, 2010 at 1:40 PM
    BAMFTACO
    Jośe
    Taco
    do you how much the locker cost
  4. Jul 1, 2010 at 1:41 PM
    MotoXdoer
    MotoXdoer taco?
    Nate
    San Luis Obispo, Ca
    06 Prerunner 4.0 a/c beast
    k&n cai 63 series intake, blacked out headlights, blacked out tailights, magnaflow pro offroad 17115 dumped, URD competetion y-pipe, total chaos 3.5" long travel, fox 2.5x8" remote resevoir shocks, allied 4" spindles, toytec 2" AAL, 20% tint up front and 5% rear, satoshi grille, ddm 50w 6000k hid's. wet okole custom trd seat covers with heaters. 4:56 nitro gears with arb rd129 air locker, arb ckmta12 dual air compressor.
    toy 8" right? lsd are 8.4 e locker and non trd are 8" i belive
  5. Jul 1, 2010 at 1:52 PM
    BAMFTACO
    Jośe
    Taco
  6. Jul 1, 2010 at 1:55 PM
    jhodge83
    SC
    17 XLT Sport
    i thought the open/LSD shared the same rear diff?
  7. Jul 1, 2010 at 1:58 PM
    BAMFTACO
    Jośe
    Taco
    I think the open/lsd dif are 8.4" and the trd with electric locker has the 8"
  8. Jul 1, 2010 at 2:01 PM
    MotoXdoer
    MotoXdoer taco?
    Nate
    San Luis Obispo, Ca
    i dunno? i dont want to end up gettn the wrong locker
  9. Jul 1, 2010 at 2:11 PM
    BAMFTACO
    Jośe
    Taco
    Check out this site help me out
    Home.4x4wire.com/erik/diffs/
  10. Jul 1, 2010 at 2:15 PM
    jhodge83
    SC
    17 XLT Sport
    from^^^^^
    This diff commonly and mistakenly called an 8.4" or 8.25" diff, possibly to imply its extra strength. The ring gear actually measures 8". The extra strength of this diff comes from the bearing cap/truss and large diameter pinion gear shaft.
    LSD's available is the TRD/Kazuma clutch-type 3-pinion LSD, the OEM 4-pinion Tundra TRD LSD, and the Detroit Trutrac.
    Lockers available are the Powertrax "Lock-right," "No-Slip," ARB Air Locker, Detroit Softlocker.
  11. Jul 1, 2010 at 2:24 PM
    BAMFTACO
    Jośe
    Taco
    Hopefully answers peoples questions and I'm gunna buy the locker but I won't be able to install it till next month but ill post it up when I get it
  12. Jul 13, 2010 at 2:58 PM
    BAMFTACO
    Jośe
    Taco
    I just got my lockright locker and I'm getting it installed this monday and people who want to get this I recommend not to get because it is cheap and good if your on a budget but this locker just found out that its a good product the only thing bad on it is the springs that make it activate after 2 or 3 years and off roading you do the springs loose there tension and the locker won't function
  13. Jul 13, 2010 at 5:20 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    The sr5 and the TRD offroad use the same rear axle. The '8.4' or '8.25' or whatever you want to call it. The sr5 is open. They all use an '8-inch' ring gear, like the e-locker rear, but you need to buy a locker specific to that rear end.
  14. Jul 13, 2010 at 5:38 PM
    BAMFTACO
    Jośe
    Taco
    There really is a point on worrying about wat size dif because when your ordering from some where just say wat kind truck you got
  15. Jul 20, 2010 at 9:24 PM
    BAMFTACO
    Jośe
    Taco
    Finally got my posi installed today and it is awsome I did a hill that I couldn't do before and its a little weird driving on the street but I'm getting used to it
