Prerunner rear diff noise help
Discussion in 'Technical Chat' started by zkdawg, Feb 27, 2018.
  1. Feb 27, 2018 at 1:20 PM
    zkdawg
    zkdawg [OP] Greenville Taco
    zach
    Mauldin, Sc
    06 DCLB TRD Sport
    Fog light mod, JBA LT headers, drop-in k&n filter, energy bushings, tried fold topper, 2nd air filter removed, all new stereo system minus subs, plastisol the wheels.
    Recently I went through a auto carwash that sprays the underside of the truck and while leaving the wash, there was a metal clicking that increased with speed coming from the mid/rear under the truck. The next day, it was gone. Now, a few weeks later, there seems to be alot of backlash in the gears as I can grab the drive shaft and rotate it probably 1/12 a turn back and forth. Doing so, I can hear the gears click/tap together. I hear the sound when going from drive to reverse while holding the brakes and when going from a stop. It's getting worse and this is my only vehicle so I can't have down time.
    Any idea why it is doing that?
    Could water have gotten in through the diff breather and damaged it?
    Plz Help! I can upload a short video later tonight when I get off work. And I have the LSD.
  2. Feb 27, 2018 at 3:21 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Did you intend to say 1/12 of a rotation? That’s totally normal. If you meant 1/2 rotation, that’s a little excessive, I would be concerned that the pinion pre-load is out of spec. Not sure how that would be caused by a car wash though.
    Water may have entered through the diff breather, I would recommend draining the diff and seeing if there is any water/metal shavings/small furry animals in there. Pretty easy to do and could give you a lot of information on the situation.
  3. Feb 27, 2018 at 3:40 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    Are you sure it's not a u-joint?
  4. Feb 28, 2018 at 7:13 AM
    zkdawg
    zach
    Mauldin, Sc
    06 DCLB TRD Sport
    Yeah, 1/12 turn.
    The sound is coming from the diff for sure. I replaced one u joint a few years back and they are all still good. It honestly sounds like there is alot of space between the gears. I will be tarring it apart on Sat so I will post back what I find and load a vid tomorrow. Thx
  5. Mar 1, 2018 at 6:56 AM
    zkdawg
    zach
    Mauldin, Sc
    06 DCLB TRD Sport
    Well, I have some time today so I'll be tackling the diff and post back what I find.
  6. Mar 12, 2018 at 3:23 PM
    sparkystaco
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    What did you find,,,,, inquiring minds want to know
