prerunner rides stiff, any suggestions?
Discussion in 'Suspension' started by adamstoy, Sep 22, 2010.
  1. Sep 22, 2010 at 8:07 PM
    adamstoy
    adamstoy [OP] Well-Known Member
    adam
    Manchester NH
    09 DBL CAP PRERUNNER
    2.5 inch spacer, black headlight mod, tonnou cover,chrome bull bar and step bars motometal 958 chrome w/ cooper zeon ltz 285/60R18 TRD OR suspension angle eye projectors with hid 6k's
    I have an 09 dblcab prerunner with 285-60-18 tires and currently have trd offroad coils and stock billies all around with a 2 inch spacer to clear the wheels. I know that spacers give a stiffer ride but its almost as if if i ran over a quater i could tell if its heads or tails. the shocks and struts only have about 8k miles on them and I know the "off road" coils are stiffer than sport or stock. could i go back to stock coils and 5100's up front and still clear the tires, and would air bags in the rear give a smoother ride with the bed being unloaded most of the time. Any input would be great..thanks
  2. Sep 23, 2010 at 10:43 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    You should get rid of the spacer and TRD coils. Put the stock coils in with a set of Bilstein 5100s set at 2.5" of lift. Then get a 3 leaf AAL set for the rear.
  3. Sep 24, 2010 at 10:19 AM
    BMiller421
    BMiller421 FMLYHM
    Brandon
    Bakersfield, CA
    05 Pre-runner
    LT, Kings, Fabricated Trucks Worldwide For The Win, K&N and Doug Thorley LT Headers
    You know what helped me a bit..lower your PSI in your tires..just a few (2-3 PSI or more if you like..)
  4. Sep 24, 2010 at 6:27 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Yah... you can control it all just by adjusting the tire pressure! What are you running, the max. rated for that tire (or more) ?
    Your truck is light, specially in back... it doesn't need the max. pressure if you don't have the max. load on it.
  5. Sep 24, 2010 at 10:41 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    No no no, go beat on the truck a bunch until it rides like a caddy!
  6. Sep 24, 2010 at 10:46 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    Spacer lift is you're answer... really any lift, anytime you change the suspension geometry, you're going to affect the ride.....
    However, the real answer? If you want a caddy ride, go buy a caddy, not a truck.
  7. Sep 24, 2010 at 11:08 PM
    01taquito
    01taquito "thats what she said"
    joe
    san antonio
    01 pre-runner sr5 quad-cab
    Bilsteins 5100's front and back. Wheelers add a leaf
    get a fatter ass... sorry i've been drinking :) alot
  8. Sep 25, 2010 at 11:37 PM
    noSKills858
    Alex
    Poway, CA
    My taco rides like a caddy, what are you saying?
  9. Sep 26, 2010 at 12:11 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Just go with 5100s in the front. The spacer lift is your problem.
