Prerunner Slotted & Cross Drilled rotors 2005-2009
Discussion in 'Buy / Sell / Trade' started by vorteil, Jan 13, 2010.
  1. Jan 13, 2010 at 5:10 PM
    vorteil
    vorteil [OP] Member
    Irvine, CA
    04 SC PreRunner
    TRD Supercharger URD Fuel Upgrade Recaro Trend Seats
    I have a set of aftermarket slotted & cross drilled rotors for sale. Brand new, still in the box. Fits the 2005 & up Prerunner 6 lug & the 4x4. Rotors are 12.5" diameter. Looking for $80. I can ship it USPS Priority flat rate medium box for $11 each so for both it's $22. It would come in 2 boxes. If there's a cheaper way to ship it thats fine too. Form of payment would be paypal or cash for local buyer. Loacted in Irvine CA.
    [​IMG][​IMG]
  2. Jan 13, 2010 at 7:21 PM
    TacomaTSP4
    TacomaTSP4 Go Big or Go Home!!
    Travis
    Rohnert Park, CA
    why does it say prerunner? cant it fit a 05-09 trd offroad 4x4 tacoma?
  3. Jan 13, 2010 at 7:51 PM
    RAD
    RAD RAD Vendor
    THE RAD
    Socal
    2007 | TRD |1ST 2012+ CONVERSION
    2012 CONVERSION | A LOT OF TOTAL CHAOS & ICON DYNAMICS
    Whats the benefits of these rather then our OEMS? Can I replace my stock ones and what would be the best brake pads to use?
  4. Jan 13, 2010 at 10:12 PM
    vorteil
    vorteil [OP] Member
    Irvine, CA
    04 SC PreRunner
    It will fit all the 6 lug tacoma's. As far as the pads there are pros & cons when you use ceramic vs semi metallic. Its a personal choice. I have a set of ceramic pads that are new for $25.
    "Cross-Drilled and Slotted brake rotors can tremendously reduce brake fade during daily driving or racing situations. These rotors also improves rotor cooling, again defeating brake fade. On Cross-Drilled and Slotted rotors, temperatures can be reduced by as much as 200 degrees during extreme braking when compared to stock rotors. The cross drilled & slotted rotor’s help reduce the cracking caused by repeated, high stress, high temperature brake applications".
  5. Jan 13, 2010 at 10:19 PM
    ROCKSLINGER
    ROCKSLINGER Zombie Response Team
    Robert
    Reno Nv
    14 MGM DBL CAB 6 SPEED
    Fox Coilover with reservoir, Fox Remote Rear reservoir, Wheeler's 3 pack AAL, Grillcraft Grille color matched, Rampage 50" LED Light Bar, Relentless 1/4" IFS-Mid and Transfer case Skids, Relentless High Clearance Rear Bumper, Kenwood 1800 watt Amp, 12" Rockford Fosgate P3 Shallow Sub, 1 Farad Capacitor, Redline Hood Struts, Weathertech Floor Mats, Doug Thorley Long Tube Headers, Flowmaster Delta 40, URD MAF Calibrator, URD Short Shifter, CST Black Leather W/Red Stich, On Board Air, Train Horns,
    what brand are these? do you have part numbers. Im interested just want to double check make sure they fit.
  6. Jan 14, 2010 at 6:55 AM
    TacomaTSP4
    Travis
    Rohnert Park, CA
    im guessing these are just front?
    I had a big brake kit upgrade on my evo and it made a huge difference. I know these are the same size just cross/drilled but they will make a difference im just worried bout offroading and have a rock or something get caught in one of the slots or drilled holes and ruin my brakes.
  7. Jan 14, 2010 at 9:48 AM
    vorteil
    vorteil [OP] Member
    Irvine, CA
    04 SC PreRunner
    There's alot we can do to improve our breaking system & one can say every little mode would make a difference. As to how much & can it be felt is a whole other issue. I'll give you an example of mine.
    I upgraded the brakes on my 97 BMW Me that was supercharged pushing more the 400 horsepower. I did the brembo big brake kit upgrade on it & can say i wasnt that impressed. What I should have done was just change the pads, rotors, steel brake lines & add synthetic brake fluid. The brakes looked sweet but the cost was steep. I'm not pushing these. If someone wants them fine. If not to each his own.
  8. Jan 14, 2010 at 9:52 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Bump for you. This is a good price.
  9. Jan 14, 2010 at 10:07 AM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    X2
  10. Jan 14, 2010 at 10:30 AM
    ROCKSLINGER
    Robert
    Reno Nv
  11. Jan 14, 2010 at 10:36 AM
    06WHITETRD
    06WHITETRD Gotta Love my Taco!!!!
    So Cal
    06 Toyota Tacoma OFF-ROAD
    Tinted windows, window visors, XDI True Flow intake, White Devil Emblem, sport white grill, stubbie 6' antenna, TRD license plate frame,TRD Exhaust, weathertech floor front & rear, LED map/dome & license plate lights,Black Grille,T-Rex eyebrows,black Skid Plate,Lower bumper cover,Black emblems,white TRD Emblem,lamin-x yellow,Slotted & Cross Drilled rotors,Redline shocks(hood),HID 6k,more to come
    hey Mark, I want some brake pads
  12. Jan 14, 2010 at 10:48 AM
    06WHITETRD
    So Cal
    Ima install them rotors on saturday.
  13. Jan 14, 2010 at 11:29 AM
    06WHITETRD
    So Cal
    Anyways. I already got my set. Thanks MArk.
  14. Jan 14, 2010 at 11:37 AM
    vorteil
    vorteil [OP] Member
    Irvine, CA
    04 SC PreRunner
    I'm just offering a set of rotors that I felt was a reasonable deal. I was paying $70 per rotor for the dealership & that was suppose to be 10% over cost. My friends a mechanic there. I run these rotors and just wanted to pass it on, thats all. It is an OE replacement that has been sent out to a machine shop that slots & drills the rotors out.
  15. Jan 14, 2010 at 11:39 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    You are offering a good deal. Keep it up, someone will be along to clean up the thread.
  16. Jan 14, 2010 at 11:44 AM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    +1. I removed my comments. Hijacking threads is not polite. I apologize.
  17. Jan 14, 2010 at 12:02 PM
    06WHITETRD
    So Cal
    x2
  18. Jan 19, 2010 at 3:36 PM
    06WHITETRD
    So Cal
    i just install them rotors this past weekend. I feel the differents, it feels great, no more vibration on the steering wheel when im stoping. I put new front brake pads. It was all worth it. thanks mark.
  19. Jan 20, 2010 at 7:14 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    That's great but FYI, any new rotors will stop the vibrating steering wheel compared to your warped ones. The c/s did nothing to stop the vibrating. Any new thicker unwarped ones with new pads will also make the truck stop better too. Glad the sale went well & you're happy with your purchase!
  20. Jan 20, 2010 at 8:23 AM
    06WHITETRD
    So Cal
    im just saying. its a great deal. and i believe ppl should jump on it.thats all im saying. thanks.
