Prerunner, SR5, LSD, TRD, 4x4, long bed..... So many options
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ownage, Feb 18, 2013.
  1. Feb 18, 2013 at 7:13 AM
    Ownage
    Ownage [OP] Member
    none
    I am specifically referring to 05+ Tacomas.
    There are so many variations of Tacoma. I thought I had my facts straight until I took a look at one yesterday. Correct me if I'm wrong on anything.
    4x4
    4x4 can come long or short bed. Regular, extended, and crew cab. It can have automatic, 5 speed, or 6 speed. It can have SR5 and\or TRD packages. Not sure if they have an open diff if non TRD. Is LSD an option without TRD or stock? I believe TRD offroad implies having an e-locker. Not sure about later models, see the e-locker section bellow.
    Prerunner
    4x4 suspension without the xfer case. Has front coilovers. There is no such thing as a 4x4 prerunner. Regular, extended, and crew cab. It can have automatic, 5 speed, or 6 speed. It can have SR5 and\or TRD packages. I thought non TRD were open diff but I looked at a non TRD prerunner 4 door long bed and the rear end said "LSD oil only". Was LSD an option in non TRD or was it stock. Like 4x4 vI believe TRD offroad have an e-locker.
    4cyl
    E-locker & LSD
    E-locker came stock or was an option for TRD offroad. After 2009 only a pseudo locker exists that uses the ABS to pulse the rear brakes. Not sure if an LSD exists. Not sure exactly which trims do\dont have LSD or e-locker.
    Manual Trans
    Exists on all variants & trim except for 4 door long bed.
    Non prerunner
    All 4 door non prerunner are 4x4. Other variants can be either
    SR5
    Some interior trim? Nothing performance related.
    TRD offroad
    Offroad suspension + elocker. Not available in 4-door long bed.
    TRD sport
    Stiffer suspension
  2. Feb 18, 2013 at 7:21 AM
    4runner4now
    4runner4now Active Member
    Also you can't get a long bed with TRD Off road, only sport.
  3. Feb 18, 2013 at 7:29 AM
    HIst8ofMIND
    HIst8ofMIND Defend Hawaii
    PJ
    Maui
    2013 MGM DCSB TRD-OR
    Then there's the XRunner, XSP, TX, Baja....
  4. Feb 18, 2013 at 7:32 AM
    Ownage
    Ownage [OP] Member
    none
    So that means no such thing as an E-locker on a 4-door long bed?
    I'll try to create a spreadsheet later.
  5. Feb 18, 2013 at 7:34 AM
    TexAggie
    TexAggie Well-Known Member
    Eric
    Houston, TX
    OME Lift
    Tow package!
  6. Feb 18, 2013 at 7:34 AM
    97T
    97T Resident T100 guy
    Melt
    Littleton, CO
    97 T100 xcab 5spd 2wd
    soundstream 550.2 amp, 2 eclipse 10" subs, 4% tint rear window, 20% sides, 6" sunstrip, clear bumper lenses, avital 4103 alarm with keyless, BF Goodrich Rugged Terrain T/A 235/75/15, 15X7 6-5.5 0C Unique 298 rims
    i thought the 4dr's werent avail with a manual at all till one came into my work 2 months ago, i think it was a prerunner
  7. Feb 18, 2013 at 7:35 AM
    4runner4now
    Correct. unless you install an aftermarket one.
  8. Feb 18, 2013 at 7:35 AM
    TexAggie
    Eric
    Houston, TX
    OME Lift
    Yes. However I think you can get a long bed with a manual.
  9. Feb 18, 2013 at 7:56 AM
    ViperJay
    ViperJay These are the voyages...
    El Paso, TX
    05 Radiant Red DCLB Sport 4x4
    URD CAI, DTLT Headers, Vibrant Ultra Quiet Resonator, Aero 2540i muffler, NST Pulleys, URD MAF Calibrator, Icon 2.5 Coilovers , Bilstein 5100s in rear with All Pro 3" Leaf pack, Total Chaos UCAs, 2 Kicker 12" CVT Subwoofers w/Kicker ZX350.2 Amp, JVC KD-AVX77 stereo, ARE Camper Shell, 1 20" LED bar and 2 7" LED bars in front, 4 KC 6" HID Slimlites mounted on Bajarack roof rack, sliders, Cobra 29 XLR CB Radio, Icom IC-207H UHF/VHF Radio, Bed Lighting, Fog light mod, Projector Retrofit Headlights HID 5000k, HID fog lights 4300k, BHLM, LED taillights and turn signals, Glassworks front fenders, Blue Sea Fuse Box, Mil-Spec Battery Terminals, Odyssey PC2150 battery, Satoshi Grill, All-Pro Front Bumper
    Nope only auto, at least thats how it was when I got mine.
  10. Feb 18, 2013 at 8:03 AM
    Ownage
    Ownage [OP] Member
    none
    KBB does not list 4d long beds with manual.
  11. Feb 18, 2013 at 8:56 AM
    Ownage
    Ownage [OP] Member
    none
  12. Feb 18, 2013 at 6:33 PM
    jrogers329
    jrogers329 Well-Known Member
    Huntsville, AL
    2011 Prerunner TRD DCLB-TRADED!
    Gelo760 is correct. I deliver to the Toyota Motor plant in AL. The security services drive a non prerunner 2wd 4dr. Saw it tonight as a matter of fact. When I see it next, I'll try and get a pic.
  13. Feb 18, 2013 at 6:52 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    2005 thru 2008 TRD Sports came with a mechanical limited slip differential. I believe you could also get it as an option on 2005 thru 2008 SR5 models also. Post 2008, Toyota went to an Auto LSD which is just a brake activated LSD (uses the brakes to mimic limited slip, no more mechanical LSD).
    The TRD Off Road package is the only package that has the e-locker.
  14. Feb 25, 2013 at 2:38 PM
    jrogers329
    Huntsville, AL
    As promised...4 door 2wd non prerunner
  15. Feb 25, 2013 at 3:37 PM
    Larry
    Larry CARL
    CARL
    and fog lights for better driving in fog performance...and back-up camera for driving in reverse performance...
  16. Feb 25, 2013 at 3:38 PM
    HIst8ofMIND
    PJ
    Maui
    My friend has one. 4 cylinder gas saver. I told her she had a cute truck.
  17. Feb 25, 2013 at 4:34 PM
    sde780
    sde780 Well-Known Member
    After 2009 they still came with e-locker. Using ABS to pulse the brakes is known as TRAC or ATRAC, AKA electronic LSD. Not the same as an e-locker.
  18. Feb 25, 2013 at 7:56 PM
    Larry
    Larry CARL
    CARL
    back in the day, we did it the old fashion way...
    manually :D
