Prerunner to 4x4 conversion parts
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Timbo's Customs, Feb 19, 2019.
  1. Feb 19, 2019 at 5:23 PM
    Timbo's Customs
    Timbo's Customs [OP] Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    was going to solid axle my tacoma but decided to trade it in later this year. Going to build a different trail rig in the toyota family still.
    For a 05 to 15 prerunner 4.0.
    Tail housing off a 4x4 transmission inchworm adapter to prerunner transmission. 4x4 transmission mount. Have all the hardware for the adapter.
    $500 plus shipping. Sold
    Stock fj case with shifter. 350 plus shipping
    Shoot me a offer need this stuff gone.
    Edit: also have a rear 4x4 driveshaft
    5 Lug Fury and Daria like this.
  2. Feb 19, 2019 at 5:36 PM
    Nimble9
    Nimble9 visit squareonecreations.com Vendor
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
  3. Feb 19, 2019 at 7:53 PM
    kez329
    kez329 Well-Known Member
    06 DCSB TRD OR/Pre
    Just these parts will make a prerunner to a 4x4?
  4. Feb 19, 2019 at 7:55 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    You will need a front driveshaft. Front diff, cv axles, 4x4 bearings and a modified transmission crossmember also. This is just the transmission stuff that’s needed @kez329
  5. Feb 19, 2019 at 8:03 PM
    seoulja99
    seoulja99 Well-Known Member
    E.J.
    Oahu
    2012 DCSB 4x4 V6 TX Baja (1GR-FE)
    all things mall rated
  6. Feb 19, 2019 at 8:37 PM
    socalexpeditions
    socalexpeditions IG: @socalexpeditions
    Is that single FJ from an automatic?
  7. Feb 19, 2019 at 8:38 PM
    Timbo's Customs
    Timothy
    Lakeland FL
  8. Feb 19, 2019 at 8:39 PM
    socalexpeditions
    Roger that, I will PM you soon if interested. I am on the fence about the swap to the single stick.
    Did you plan on shipping freight?
  9. Feb 19, 2019 at 8:40 PM
    BotoSlap808
    BotoSlap808 JAHblessed
    Kaneohe,HI
    2015 sport DCSB
    Faka you supposed to be working on getting a regear group buylol
    seoulja99[QUOTED] likes this.
  10. Feb 19, 2019 at 8:46 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    Would be freight on a small pallet.
  11. Feb 20, 2019 at 2:07 AM
    seoulja99
    E.J.
    Oahu
    I already ordered from ECGS. Just waiting for them to arrive. LOL!
  12. Feb 20, 2019 at 3:07 AM
    ilubtimmyhos
    ilubtimmyhos Brewer
    Adam
    Haymarket, VA
    2012 Blue Tacoma 4x4 Pre-Runner
    4x4 Conversion w/ FJ T-Case, King 2.5 Extended Travel Coilovers w/ JBA UCAs, King 12" 2.0 Smoothies w/ BAMF relocate in the rear, OME Dakar leaf pack, 4.56 gears w/ ARB air locker, Archive Hammer Hangers w/ crossbar brace, ARB Snorkel, Custom Bed cap w/ Roofnest Sparrow XL, Retrofit Headlights, Wrapped in 3M Satin Perfect Blue
  13. Feb 20, 2019 at 5:26 AM
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    Timbo's Customs[OP] likes this.
  14. Feb 20, 2019 at 7:18 PM
    Timbo's Customs
    Timothy
    Lakeland FL
  15. Feb 23, 2019 at 2:18 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Interesting! So you need an adapter still to bolt the 4x4 tail housing to the prerunner transmission? Different bolt pattern or is it just a spacer because of the slip yoke and output shaft length?
  16. Feb 23, 2019 at 2:20 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    I think it’s because the 2wd transmission output shaft is longer than the 4wd version.
  17. Feb 23, 2019 at 2:22 PM
    TireFire
    Olympic Peninsula
    In other words you get the output shaft from the 4x4 trans and don't need this adapter?
    Downside is that swapping those shafts means pretty much tearing down the whole thing huh?
  18. Feb 23, 2019 at 2:25 PM
    jowybyo
    Joe
    Baltimore, MD
    That is my understanding. Though maybe it’s not that simple. When I did my conversion, I swapped the output shaft but I have a 4cylinder. The A750 trans behind the v6 may not be that straightforward. Even with my swap I initially missed that the speed sensor rotor was different. Took like 6 weeks to get that part from Japan.
  19. Feb 23, 2019 at 6:52 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    The adapter takes the place of the tail housing of the 2wd and allows you to bolt up a 4wd housing. Then you can bolt the t case up to your 2wd transmission.
    Sale is pending and I have a deposit on the adapter/ tail housing/ motor mount
  20. Feb 23, 2019 at 8:28 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    Conversion stuff sold
    Still have rear driveshaft and a fj case
