prerunner with rear locker diff
Discussion in '1st Gen. Tacomas (1995-2004)' started by 06toyoboy, Nov 5, 2011.
  1. Nov 5, 2011 at 1:55 PM
    06toyoboy
    06toyoboy [OP] Well-Known Member
    I have an 03 Tacoma prerunner and was wondering if I could put a rear locker? I thought it could b possible so I went to a junkyard to see how much parts run and the shop manager said that I wouldn't b able to do it. Is this true?
  2. Nov 5, 2011 at 5:05 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yea you can. I think it even came as an option for some.
    You don't even have to worry about matching gear ratios as you don't have a front diff lol
    So yes, you can put the locker on. don't see why not
  3. Nov 5, 2011 at 6:07 PM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    Hm I don't think you can without replacing the entire axle. So you would need an axle out of a TRD truck, the locker actuator, and wiring harness I believe.
    At that point, you may as well just go for an aftermarket like ARB or Detroit or something.
  4. Nov 5, 2011 at 6:10 PM
    tacomalex
    tacomalex Well-Known Member
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    yeah just go with an ARB air locker. the onboard air will come in handy for other things as well.
  5. Nov 5, 2011 at 6:19 PM
    zomg
    zomg Well-Known Member
    NOLA
    08 PreRunner SR5
    TRD CAI, Ultra-Gauge, All Weather Floor Mats, Rear Spring TSB, Avid Offroad Sliders, Spidertrax, Dynomax Superturbo, Bolt-on Grille
    Powertrax no-slip $4-500 + install. Mine works f'n great, but an ARB is unbeatable if you want to spend $1500+.
  6. Nov 5, 2011 at 6:26 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well thats what i meant. You'll have to swap the whole axle for a TRD locker. The open diffs are different then the TRD ones.
    Or yes you could just get an ARB. Much more expensive but stronger and OBA is cool and nice to have. should be around 800-1200 bucks.
    TRD axle will run anywhere from 200-500 bucks.
  7. Nov 5, 2011 at 6:37 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    The e-locker 3rd won't fit in a stock trd axle..without modifying the housing.
    You'll need to modify the housing or buy the entire axle assembly..or at least the housing and the 3rd member. Don't quote me but I'm 95% sure the splines are the same on the carrier for the e-locker as the splines on your trd axle shafts.
    ARB is $1000
  8. Nov 5, 2011 at 6:44 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea but you can get used 8.4'' housings already tapped for 850 used. On TTORA all the time.
  9. Nov 5, 2011 at 6:51 PM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    Rofl $850 used for a housing modified for a e-locker? just the housing? if so fucking rip off lol, if it's entire axle..that's a DECENT price if it's in good condition and has gears in it..if not, complete rip off.
    I can have a buddy do it for $100 and you can find e-lockers for $200-400 with the actuators..
    Marlin and Pirate FTMFW.
    and Pull and Save :D
  10. Nov 5, 2011 at 7:49 PM
    06toyoboy
    yea the guy said i would have to swap out the entire axle and do some other things but i guess i can go for an aftermarket one. I saw some companies you mentioned but not sure what to go with. What do you guys recommend for me, i dont do trail very much the truck is a DD so what would you recommend i go with as far as the aftermarket lackers are concernd
  11. Nov 5, 2011 at 7:52 PM
    04LTtacoma
    04LTtacoma Well-Known Member
    Morty
    Outer Space
    Yep, you will need these items.
    You will also need the harness.. Good luck!
  12. Nov 5, 2011 at 8:00 PM
    06toyoboy
    its possible but i might just go with an aftermarket one
  13. Nov 5, 2011 at 8:02 PM
    04LTtacoma
    Morty
    Outer Space
    ^Why go aftermarket?
  14. Nov 5, 2011 at 8:26 PM
    06toyoboy
    it seems to me like there is more work i must do with finding the trd parts than by just going aftermarket, and it also seems cheaper to go aftermarket or am i wrong
  15. Nov 5, 2011 at 8:51 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    lol no you can get an ARb 8.4'' for 850 dude..
    And yes i kno. he needs the full axle for a TRD swap. Again, id never pay more then 500 for a full axle.
  16. Nov 5, 2011 at 9:16 PM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    Oh, that's about right.
    I can find 8.4 ARB 3rds for $700-850..just gotta look :D
    I'd never pay more then $300 lol.
