Prerunners with Camburg spindle lifts ???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bizjettech, Dec 16, 2011.
  1. Dec 16, 2011 at 8:09 PM
    bizjettech
    bizjettech [OP] Well-Known Member
    San Antonio, TX
    2013 MGM DCSB 4x4 TRD OR
    undercover flex bed cover
    Ive seen several pics of guys with Camburg spindles on 2008 - 2012 Prerunners but all of them running 285/70's have spidertrax spacers and the wheels stick out pretty far. Is this needed to run this size tire without rubbing?
    Id like to do the camburg spidle lift but I dont want the wheels to stick out.
    I like to keep them in the wheel wells.
    what do you camburg spindle lift guys have to say?
  2. Dec 17, 2011 at 7:15 AM
    bizjettech
    San Antonio, TX
    anyone?
  3. Dec 17, 2011 at 7:24 AM
    fishntaco
    fishntaco Well-Known Member
    Josh
    Mobile Al
    08 Silver Streak DCLB Prerunner Sport
    Most guys that run spindles do not have wheel spacers. It is the spindle itself that pushes the wheel out a little bit.
  4. Dec 17, 2011 at 1:33 PM
    racer1x
    racer1x Well-Known Member
    campbell ca
    05 Taco
    Too many
    No spacers on mine, the spindle is 3/4" wider per side. I think it looks much better a little wider.
  5. Dec 17, 2011 at 8:05 PM
    dira1987
    dira1987 Well-Known Member
    David
    Chandler AZ
    2003 LT Prerunner
    Metal.
    i am running 285/75/16 with no spacers and no problems at all. It is true that the spindle does push out the wheel a little bit farther for a wider stance. but its not by that much.
  6. Dec 18, 2011 at 5:16 AM
    bizjettech
    San Antonio, TX
    Thanks guys!
