presistant p0420 code 2002 tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by seacraft23, Jun 20, 2009.
  1. Jun 20, 2009 at 12:46 PM
    seacraft23
    seacraft23 [OP] Member
    changed both 02 sensors and cat still getting this code. between 50 and 70 miles of reseting. any ideas ? is this a common problem ? thanks for any help
  2. Jun 20, 2009 at 7:35 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    mine tripped a week ago
    i found out certain brands of gasoline trip my sensors, especially shell gasoline, burn off your tank and refill with a different station/grade it may be an additive in the gasoline
  3. Jun 20, 2009 at 7:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Have you checked for exhaust leaks?
  4. Jun 20, 2009 at 7:50 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    try running a fuel system cleaner through your truck at your next fill-up
  5. Jun 20, 2009 at 8:14 PM
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
    That code is telling you that the ECU has diagnosed that the catalytic converter is worn out and needs to be replaced. It is not a problem with the O2 sensors.
    The cat is covered under the federally mandated emmissions warranty for 8 years or 80,000 miles. If you fit into that range, drive into your local dealer and have them install a new cat for you.
    Or;
    http://www.urdusa.com/index.php?cPath=66_170&osCsid=l4vuevhaeafq00s7mc7ecesoa7
    G
  6. Jun 20, 2009 at 8:58 PM
    seacraft23
    the cat was changed already. i have checked for leaks. :( the sensors were changes because they werent reading properly with a scan tool. i thought that would have fixed it. went a head and replaced one of the cats which looked healthy. and the code still keeps coming up .
  7. Jun 20, 2009 at 8:59 PM
    seacraft23
    PS that simulator is niceeeeeeeeeeeeeeeeeeeeeee lol
  8. Jun 20, 2009 at 9:09 PM
    XBrown
    XBrown Spartacus!
    Xavier
    Phoenix, AZ
    04 Tacoma SR5
    Yeah, a P0420 is a generic "catalytic efficiency" code. The computer gathers data from the upstream and downstream O2 sensors and compares them. The downstream should have a steady oxygen level, while the upstream O2 levels should wave up and down. When the downstream exhaust reads the same as the upstream, it indicates the cat isn't doing it's job. And, it takes 50-70 miles after resetting the computer for it to complete a full system check of the emission system.
  9. Jun 21, 2009 at 5:46 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Is the relacement CAT OEM?
  10. Jun 21, 2009 at 7:35 AM
    seacraft23
    front cat yes rear cat not OEM
