Press in Heim joints?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Huckshot, Apr 18, 2018.
  1. Apr 18, 2018 at 12:12 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Meme credit : costalfabwerx
    mjp2[QUOTED] likes this.
  2. Apr 18, 2018 at 12:12 PM
    Huckshot
    Huckshot [OP] Well-Known Member
    Jared
    2000 tacoma 3.4v6 auto 4x4
    3" coil lift spacer in front. 2" block spacers in rear. 6lug to 5 lug adapters. 20" tundra rims with 33" mt tires
    Guess ill post the out come then.
    mjp2 likes this.
  3. Apr 18, 2018 at 12:12 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    These are specifically designed for ball joints. Apples-to-porpoises comparison to what's on your truck.
  4. Apr 18, 2018 at 12:18 PM
    Huckshot
    Jared
  5. Apr 18, 2018 at 12:22 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    It's a two way street brother. I don't think you are understanding us, either.
    If you have lifted it to the point where you need a "longer stem" to prevent the UCA from hitting the coil, you've screwed it up, and exceeded the limits of the suspension geometry. I'm guessing over 3". If that's the case, you need a kit like Procomp, which properly corrects the angles of your control arms, preserves your CV angles, etc...
    Stop trying to create your own "custom" lift here. Just buy aftermarket control arms and do a proper lift.
  6. Apr 18, 2018 at 12:23 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Are you trying to just design your own set of ucas? Thats take a fair amount of work. Were not trying to be complete dicks just save you time and stress fron doing something that may or may not fix your problem. Your best bet is just buy after market ucas so fix your problem then start working on your own ucas is you want
  7. Apr 18, 2018 at 12:24 PM
    jbrandt
    Justin
    Are you getting ideas for how to lift your truck from watching lowrider videos?
    lol
    Sperrunner likes this.
  8. Apr 18, 2018 at 12:47 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Btw if you look at any after market control arms for your truck with uni balls you will see that they are massive compared to the oem ball joints, so any benift you think you will get from swapping to uni balls is minimal to non, because the size uni ball that would fit is small
  9. Apr 18, 2018 at 12:59 PM
    jbrandt
    Justin
    I didn't even put 2 and 2 together until just now OP is the same guy from that other thread with the BJ spacers.
    @Huckshot, you've now posted 3 different threads about your ball joint spacer idea.
    "Converting" it to a uniball is not going to change anyone's answer for you. It's still a bad idea.
  10. Apr 18, 2018 at 1:04 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Lol yeah once i saw who the op was i knew how this was gunna go.
    If you some how manage to make super cool guy ucas with ball joints that actually work and correct your geometry then please post picks to prove us wrong. But simply swapping in some uni balls wont fix your issue
    jbrandt[QUOTED] likes this.
  11. Apr 18, 2018 at 1:06 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    But till you make these super cool guy ucas ill be waiting for the “help i broke my truck” post
  12. Apr 18, 2018 at 1:08 PM
    jbrandt
    Justin
    Pretty sure he's made 3 of those posts already...
    Sperrunner[QUOTED] likes this.
  13. Apr 18, 2018 at 1:10 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Why don’t you just get some balljoint spacers :anonymous:
    Edit:
    Dang... guess I was too late.
  14. Apr 18, 2018 at 1:13 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Just go buy an old toyota pickup with IFS, those you can use BJ spacers for a shoddy lift.
  15. Apr 18, 2018 at 1:15 PM
    #35
    JKO1998
    Utah
    I don’t remember who said it
    “Shade tree fuckery”
    Seems to fit just all three of his threads
    Speedytech7[QUOTED] likes this.
  16. Apr 18, 2018 at 1:16 PM
    #36
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Just take a moment to admire the bro truck
  17. Apr 18, 2018 at 1:44 PM
    #37
    mjp2
    NJ
    I cannot overstate what a horrible idea that is. You're going to kill yourself and/or your passengers if you try this.
    Awful on a low rider, but the stresses on the extension in that video are FAR less than on your truck due to tire/wheel size and weight differences. You're increasing lateral forces by some multiple and will collapse your front end on your first hard turn.
    How much did you pay for your truck? How much is the safety of you, your passengers, and other drivers on the road worth?
    I assure you, it's far more than the cost of upgraded aftermarket UCAs.
  18. Apr 18, 2018 at 1:44 PM
    #38
    jbrandt
    Justin
    I'd like to think we're providing some constructive criticism maybe with a hint of sarcasm for entertainment purposes.
    But I guess that gets thrown out the window when it's your third thread on the same topic, and it obvious you're not really listening or understanding the advice that's being given.
    So...
    carry on...
    Sperrunner and Speedytech7 like this.
  19. Apr 18, 2018 at 1:52 PM
    #39
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    One month later... “tacoma part out”
  20. Apr 18, 2018 at 1:54 PM
    #40
    JKO1998
    Utah
    I didn’t look at the video the first time but now I have.
    Holy shit
    :violent:
